ADC gives wrong results
9 posts / 0 new
First time programming an Atxmega A. Here's my code:
ADCA.CTRLA = 1; //Start ADC
ADCA.PRESCALER = 0b111; // Prescaler=512
ADCA.REFCTRL = 0b11; //Bandgap as reference
_delay_ms(1);
ADCA.CH0.MUXCTRL = 0b00110000; //ADC6 as input
ADCA.CH0.INTCTRL = 0b10; //Medium level interrupt enable
ADCA.CH0.CTRL = 0b10000001; //Single ended input, start conversion
ISR(ADCA_CH0_vect) {
Send_Intln(ADCA.CH0RES);
The ADC6 input is connected to a 1k+180Ohm resistor divider from the 3.3V supply, it reads exactly 0.5V on my DMM. The atxmega ADC gives me around 2230 which translates to 1/4096*2230=544mV. When reading the internal Vcc/10 input, it gives me 3.8V even though the supply is 3.3V. Changing the voltage reference gives different results, but the scale of error seems to remain the same. I've kind of run out of ideas on what's causing this :(
Which actual model of Xmega is this? The Atxmega128a1 for example rather famously has an ADC that is totally FUBAR (which is why it was phased out and replaced by Atxmega128a1u)
Sound like it is working fine...You say you gave 0.5V & it is indeed reading 0.544
That seems within the +/-10% adc tolerance , plus +/- your resistor divider tolerance.
Why do you question it?  How good is your DMM?
If you gnd the pin , do you read zero?
If using Vcc ref, do you red 1023 when tied high?
In that mode the measurement result is offset by about 200.
Measure the GND level and correct the result.
Adjusting for about 160 offset gave me proper results. Why does it have an offset though? :\
forgot about the Xmega weirdness, compared to the "classic" AVR ADC....here is some good info with a lot of explanations:
http://embedded-lab.com/blog/xmega-adc/
The usual advise is:
Remove all calculations and work with the raw ADC values untill you are sure the ADC works properly.
Just adding a potentiometer and try different values. Does it seem to be linear with voltage?
Are there offsets?
A nice way to verify the working of your ADC is with a capacitor and a current source.
You should get a nice straight line out of your ADC values. (if sampled at regular intervals).
Paul van der Hoeven.
http://www.hoevendesign.com
I'm no XMega man, but a look in the sheet gives this:
Since the ADC is differential, the input range is VREF to zero for the positive single-ended input. The offset enables the ADC to measure zero crossing in unsigned mode, and allows for calibration of any positive offset when the internal ground in the device is higher than the external ground.
Similar to single supply opamps...if you REALLY want a zero in/out (0.0000...), you need dual +/- supplies (or "split" a single), pure single will only get you 99.43% of the way there since an output can't go all the way to gnd.  Here, they fake a negative supply voltage with the offset.
