Atmel-ICE Jtag cable
5 posts / 0 new
Hello all. My name is Sri and I am new to micro-controllers.
I live in India and ordered Atmel ICE PCB thinking that I can get the cable locally here in India.
It turned out that the cable is not easy to find here. I ordered a AVR programming cable from a site called thingbits.net  but it is too big to what is needed (Picture attached).
Question is, is there a place where I can buy this cable cheap enough preferably in India to avoid customs again??
Mouser has an office in Bangalore :
https://www.mouser.in/contact/
The cable :
https://www.mouser.in/ProductDetail/Microchip-Technology-Atmel/ATATMEL-ICE-CABLE/?qs=KLFHFgXTQiBUHQFAyfEWHQ==
1.27mm (50mil) pitch cables are common.
Adafruit has distributors in India.
https://www.adafruit.com/product/1675
https://www.adafruit.com/distributors
http://new.microchipdirect.com/product/search/all/ATATMEL-ICE-CABLE
Atmel-ICE Target Connectors Part Numbers
http://www.microchip.com/webdoc/GUID-DDB0017E-84E3-4E77-AAE9-7AC4290E5E8B/index.html?GUID-A0302E02-2F2B-4AED-B3B0-6150ED875E0F
Thanks a lot for the pointers. I think, I found the cable from the same website (Indian)  where I ordered wrong cables before.
Here is the right cable (1.27mm/50mil) one.
https://www.thingbits.net/produc...
Thanks again.
Make sure you have the correct connector on the target.
And watch out for the cable pin1 re-definition (i.e. error) in the ICE connector.
    See the following:
http://www.avrfreaks.net/forum/a...
https://electronics.stackexchang...
Note especially:
FYI, the 10-pin half-pitch connector on the Atmel ICE intended for ARM Cortex parts is almost standard - essentially it is the standard pinout, but for some reason they did it with the notch on the wrong side. So it's actually a 180 degree rotation of the standard and requires a cable with as similarly rotated end. – Chris Stratton Jan 7 '17 at 8:13
David (aka frog_jr)
Chris,
Thanks for heads-up. I will make sure the pin config is right on the target. I already ordered 5mil adapter cable along with the adapter break out board shown in following link.
https://www.adafruit.com/product...
I will re-wire it with standard  2x5 connector and use that configuration to match up the target.
-Srikar
