I2C and UART on one port XMega
7 posts / 0 new
Hi all!
I'm using Xmega256a3u in this project.
Before closing the scheme, would like to know if someone checked (hopefully successfully ) option of using I2C and UART on same port.
I assume, there should be no problem.
I will check it probably in few days, but meanwhile...
Thanks for you help!(not only in this discussion)
Thanks!
Dan
What do you mean by, "on the same port" ?
It should be clear that you can't do both I2C and UART simultaneously on the same pins...
EDIT
Datasheet: http://ww1.microchip.com/downloads/en/DeviceDoc/Atmel-8386-8-and-16-bit-AVR-Microcontroller-ATxmega64A3U-128A3U-192A3U-256A3U_datasheet.pdf
currently still at Atmel Rev E, 09/2014.
Tables 32-3 to 32-6 on pages 62-63 show you the Ports C-F Alternate Function options - including UART and I2C.
So just pick ones where the I2C and UART functions don't "collide" on the same pins
Thanks, awneil,
It is more then clear, they can't be on same pins.
For example, PORTE.
More specifically, PORTE PIN0 - SDA, PIN1 - SCL, PIN6 - RxD, PIN7 - TxD
Thanks!
Dan
see my edit to #2 while you were typing!
Thanks, again!
if someone checked
But I was looking for confirmation from the real world)
In any case, I just found a way to separate this channels.
Thanks!
Dan
I have used the following usage at PORTF of xmega128a1u.
It worked perfectly.
PF0:SDA
PF1:SCL
PF2:UART0-RXD
PF3:UART0-TXD
PF6:UART1-RXD
PF7:UART1-TXD
Thanks a lot, kabasan!
Thanks!
Dan
