Atmega128 ISP programming ERROR
11 posts / 0 new
Hello everyone,
I want to program atmega128 through AVRISP MK2, but getting error
My Hardware connections are:
MOSI >> PE0(PDI)
MISO >> PE1(PDO)
SCK   >> PB1
RESET>> RESET pin
VCC   >> Vcc pin
GND   >> Gnd pin
PEN   >> FLOATING
SS    >> FLOATING
XSTAL >> external >> 7.372800MHz
AVCC >> VCC
AREF  >> VCC
AGND  >> GND
AVRISP MK2  >> FIRMWARE FULLY UPDATED
FUSE BIT Settings are
NOW, the strange part is, the chip only first time entered in programming mode, it did erase, Load hex onto flash, fuse bits, and then suddenly, it gave me above error of picture 1, afterwards,  I repeatedly tried to re-enter into programming mode, but it failed to enter again.
Kindly Help
Hello
So then we'll make a guess that the connections are OK.
The symptoms sound like a missing clock source.  Do you have a crystal?  With proper specs, and proper load caps?  Do you see oscillation on XTAL2?
There is a Tutorials forum article on "recovering from a locked-out AVR" that might be useful.
With CKSEL 3-0 programmed you have selected external CLOCK not external CRYSTAL and you have no clock now. So you need to inject a clock into the chip and program the correct fuse vales.
That is the classic symptom of incorrect clock fuse for the hardware you actually have.
With all 4 of the CKSEL bits set (eg, "0"), you have selected "External Clock". External Clock is a stand-alone oscillator that runs whether or not the micro has power. This is not the same as "External Crystal or Resonator". Do you have an external clock on your board and connected to the micro?
<EDIT>Argg, Johan beat me to it!</EDIT>
Johan beat me to it
No he didn't. cheeky
Ooops, not Johan but js. Sorry!
Yep, one is royalty the other hates kings.....devil
Thankyou Everyone!
I have noted one of my error I have made, which is related to clock fuse setting, I did two iterations but unsuccessful
then I tried to run it with internal oscillator (I did not remove PCB tracks for external crystal oscillator)
On reset circuitry, I have 10k resistor, with 100nF cap.
On Oscillator , I have 18pF cap with 7.372800MHz crystal
I unchecked the CKOPT to get greater output swing for crystal, results unchanged for the checked one.
With all this, I still getting this error
Hello
I checked my Xstal2 and Xstal1 pin using oscilloscope, there is no frequency on it, All connectivity is fine.
Kindly, let me know if there is a way to check that Chip is alive or is deteriorated by any mishandling.
Hello
Have you followed what people said and fed the chip with an external oscillator (not a crystal)? Without one you cannot change the fuses.
Thankyou Everyone on this forum! With your help I figured out that I wrongly  programmed the clock fuse bits, due to which the controller need TTL clock input and it was connected to crystal, So when I put external TTL clock, it was working fine, Now I reprogrammed it on factory setting and everything is working fine !
Regards
Hello
