Attiny 1634 Self Programmable Flash Problem
2 posts / 0 new
I'm trying to make a bootloader over wifi (uart from ESP8266).
From a web page I'm able to open a ".hex" file and transmit it to my mcu.
I copied the function "boot_program_page" from the code exemple in the "boot.h" file.
But I don't hunderstand how lenght must be the "buf" string.
I tryed different size (16,32,64,128) but the flash writen is splited and not complete:
left: original hex; right: flash read after the program is done.
There is my code below.
If the CRC is good I write to flash.
data contain exactly (first hex ligne example) "100000000C9438000C944A000C944A000C944A005A"
I check from the second uart what is sent to the "boot_program_page" fonction, there is no CRC error all the hex file is sent.
if(data[j-1] == crc)
	status=SUCCESS;
	if(page_offset==0)
		page = ((data[1] << 8) + data[2])+0x1300;
	memcpy(&page_data[page_offset], &data[4], data[0]);
	if(data[0]!=0x10)
		uint8_t diff_octets_16 = (16-data[0]);
		uint8_t	diff_octets_64 = pagesize-page_offset;
		memset(&page_data[page_offset+data[0]],0xFF,(diff_octets_64+diff_octets_16));
		page_offset=(pagesize-16);
	page_offset+=16;
	if(page_offset==pagesize)
		page_offset=0;
		WRITE_UART_DEBUG((char*)page_data, pagesize,1);
		//FLASH WRITE
		boot_program_page (page, page_data);
Thank you for help,
Eliott.
I finally got my flash writing functional without the "boot_program_page" function:
But now I'm unable to jump to my written program.
I tryed:
-asm("JMP 4864");
-asm("JMP 1300");
-asm("JMP 0x1300");
Thank you for help.
