return 0, return 1 What they do?
11 posts / 0 new
So, i was studying I2C, which is referred as TWI by atmel, i came across these return 0 and return 1. I do not know what they actually do and my predictions might be wrong.
http://homepage.hispeed.ch/peterfleury/doxygen/avr-gcc-libraries/group__pfleury__ic2master.html
Example from source code
unsigned char i2c_start(unsigned char address)
    uint8_t   twst;
	// send START condition
	TWCR = (1<<TWINT) | (1<<TWSTA) | (1<<TWEN);
	// wait until transmission completed
	while(!(TWCR & (1<<TWINT)));
	// check value of TWI Status Register. Mask prescaler bits.
	twst = TW_STATUS & 0xF8;
	if ( (twst != TW_START) && (twst != TW_REP_START)) return 1;
	// send device address
	TWDR = address;
	TWCR = (1<<TWINT) | (1<<TWEN);
	// wail until transmission completed and ACK/NACK has been received
	if ( (twst != TW_MT_SLA_ACK) && (twst != TW_MR_SLA_ACK) ) return 1;
	return 0;
life is hard
Why not read the documentation you linked to?
unsigned char i2c_start ( unsigned char  addr )
Issues a start condition and sends address and transfer direction.
Parameters
addr address and transfer direction of I2C device
Return values
0 device accessible
1 failed to access device
Already explained in your link
İt says if calling i2c_star() is successfull or not
İt can be used for error handling when using i2c_start()
Majid
yet this still does not answer to my question and it's drawbacks on main function. Does the main function stop or reset on fail?  if returns 0 does it go from where it left off ?
Because atmel datasheet handles this with a very weird unexplained ERROR(); function.
life is hard
That is up to the writer of the main() function to decide. E.g. if i2c_start(..) returns 1 then that means (from the very documentation that you linked to) that it "failed to access device". In that case it really is meaningless to continue with e.g. calls to read or write functions.
Unfortunately, Peter Fleurys example main() function does not test on the return values and handle them. (No, we can't tell you why hee chose not to.)
Yes. when a function returns execution commences at the point right after the function call. This is really basic general C stuff, nothing specific to AVRs, I2C or Peter Fleurys code. You need to take one step back, get a good book (or other good learning material) on the C programming language in general, and read.
Name the data sheet and give reference to specific spot in that (i.e. page number and spot on that page).
That answered all the questions i had and i was wondering why would he use return values if he has no use for them in main. So i thought it was something special to Atmel studio. Then my job would be to write my own error functions if any of the functions given by fleurys returns a error which would be to stop the current transmission and start over again.
atmega32a datasheet TWI section page 230 revision 2016
Now i think what the datasheet meant was to write our own specific error function.
life is hard
