Problems building basic Atmel Studio 7 project (Windows 10)
3 posts / 0 new
Hi
I recently installed Atmel Studio 7 to my Windows 10 PC for doing my first steps with programming AVR controllers.
I created a new project selected GCC C Executable project, specified my controller typ and tried to build a default project with an empty while(1) loop.
Trying to build this project always results in the error message "recipe for target GccApplication2 failed". The error message points to line 108 of the autogenerated makefile which I didnt change.
It would be great if someone please can help me. I'm completly new to Atmel Studio.
The complete output looks like this:
------ Build started: Project: GccApplication2, Configuration: Debug AVR ------
Build started.
Project "GccApplication2.cproj" (default targets):
Target "PreBuildEvent" skipped, due to false condition; ('$(PreBuildEvent)'!='') was evaluated as (''!='').
Target "CoreBuild" in file "C:\AtmelStudio\7.0\Vs\Compiler.targets" from project "c:\users\test\Documents\Atmel Studio\7.0\GccApplication2\GccApplication2\GccApplication2.cproj" (target "Build" depends on it):
    Task "RunCompilerTask"
        Shell Utils Path C:\AtmelStudio\7.0\shellUtils
        C:\AtmelStudio\7.0\shellUtils\make.exe all --jobs 12 --output-sync
c:\users\test\Documents\Atmel Studio\7.0\GccApplication2\GccApplication2\Debug\Makefile(108,1): error: recipe for target 'GccApplication2.elf' failed
        make: *** [GccApplication2.elf] Error 1
    Done executing task "RunCompilerTask" -- FAILED.
Done building target "CoreBuild" in project "GccApplication2.cproj" -- FAILED.
Done building project "GccApplication2.cproj" -- FAILED.
Build FAILED.
========== Build: 0 succeeded or up-to-date, 1 failed, 0 skipped ==========
Which processor are you using?  Did you make changes to Studio in any way when you created GccAplication1?  Reason I ask this is because your build output reads 'GccApplication2'.
I just fired up my Win10 pc and loaded up Studio7 and created a new project using a mega 328 processor and simply hit build and received no errors.
HEre is what Studio created:
 * GccApplication1.c
 * Created: 1/12/2018 9:04:32 AM
 * Author : james
    while (1)
And the build output:
------ Build started: Project: GccApplication1, Configuration: Debug AVR ------
Build started.
Project "GccApplication1.cproj" (default targets):
Target "CoreBuild" in file "C:\Program Files (x86)\Atmel\Studio\7.0\Vs\Compiler.targets" from project "c:\users\james\Documents\Atmel Studio\7.0\GccApplication1\GccApplication1\GccApplication1.cproj" (target "Build" depends on it):
Using "RunCompilerTask" task from assembly "C:\Program Files (x86)\Atmel\Studio\7.0\Extensions\Application\AvrGCC.dll".
Shell Utils Path C:\Program Files (x86)\Atmel\Studio\7.0\shellUtils
C:\Program Files (x86)\Atmel\Studio\7.0\shellUtils\make.exe all --jobs 2 --output-sync
Building file: .././main.c
Invoking: AVR/GNU C Compiler : 5.4.0
"C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\bin\avr-gcc.exe"  -x c -funsigned-char -funsigned-bitfields -DDEBUG  -I"C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.2.150\include"  -O1 -ffunction-sections -fdata-sections -fpack-struct -fshort-enums -g2 -Wall -mmcu=atmega328p -B "C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.2.150\gcc\dev\atmega328p" -c -std=gnu99 -MD -MP -MF "main.d" -MT"main.d" -MT"main.o"   -o "main.o" ".././main.c"
Finished building: .././main.c
Building target: GccApplication1.elf
Invoking: AVR/GNU Linker : 5.4.0
"C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\bin\avr-gcc.exe" -o GccApplication1.elf  main.o   -Wl,-Map="GccApplication1.map" -Wl,--start-group -Wl,-lm  -Wl,--end-group -Wl,--gc-sections -mmcu=atmega328p -B "C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.2.150\gcc\dev\atmega328p"
Finished building target: GccApplication1.elf
"C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\bin\avr-objcopy.exe" -O ihex -R .eeprom -R .fuse -R .lock -R .signature -R .user_signatures  "GccApplication1.elf" "GccApplication1.hex"
"C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\bin\avr-objcopy.exe" -j .eeprom  --set-section-flags=.eeprom=alloc,load --change-section-lma .eeprom=0  --no-change-warnings -O ihex "GccApplication1.elf" "GccApplication1.eep" || exit 0
"C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\bin\avr-objdump.exe" -h -S "GccApplication1.elf" > "GccApplication1.lss"
"C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\bin\avr-objcopy.exe" -O srec -R .eeprom -R .fuse -R .lock -R .signature -R .user_signatures "GccApplication1.elf" "GccApplication1.srec"
"C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\bin\avr-size.exe" "GccApplication1.elf"
   text    data     bss     dec     hex filename
    134       0       0     134      86 GccApplication1.elf
Done executing task "RunCompilerTask".
Using "RunOutputFileVerifyTask" task from assembly "C:\Program Files (x86)\Atmel\Studio\7.0\Extensions\Application\AvrGCC.dll".
Task "RunOutputFileVerifyTask"
Program Memory Usage : 134 bytes   0.4 % Full
Data Memory Usage : 0 bytes   0.0 % Full
Done executing task "RunOutputFileVerifyTask".
Done building target "CoreBuild" in project "GccApplication1.cproj".
Target "PostBuildEvent" skipped, due to false condition; ('$(PostBuildEvent)' != '') was evaluated as ('' != '').
Target "Build" in file "C:\Program Files (x86)\Atmel\Studio\7.0\Vs\Avr.common.targets" from project "c:\users\james\Documents\Atmel Studio\7.0\GccApplication1\GccApplication1\GccApplication1.cproj" (entry point):
Done building target "Build" in project "GccApplication1.cproj".
Done building project "GccApplication1.cproj".
Build succeeded.
========== Build: 1 succeeded or up-to-date, 0 failed, 0 skipped ==========
So my main question is did you change anything in the Studio configuration?
12 cores? you lucky person :)
Do a rebuild and post the output...
:: Morten
