Using the Peter Fleury I2C library with Atmega32U4
18 posts / 0 new
Hi !
I'm quite new to AVR and I'm currently stuck with the I2c communication between my Atmega32U4 and my AD converter ADS1114.
I inspired myself with the basic example of Peter Fleury here as well with this other example.
The code builds just fine, but when it doesn't work. When I try debugging step by step, the  program get stuck at the
if ( ret ) {
statement.
twimaster.c and ic2master.h are added to my project.
If I also add ic2master.S, an error occurs because of multiple definitions of functions so it's not with the rest.
The relevant parts of the code are in blue.
#include <avr/interrupt.h>
#include <stdbool.h>		//bool type support
#include "i2cmaster.h"
//fast PWM output pin 5 & 6 port B -> to mosfet driver
#define HighSideMos DDB6
#define LowSideMos DDB5
//Switch between modes pin 2 & 6 port E
#define SwitchMode DDE6
// ADS1114 I2C Adresse 0x48
#define ADS1114 0x48
extern volatile bool TimerSet = false;
extern volatile bool IsCharging = true;//True -> Buck converter mode, using only High-side Mosfet. False -> Boost converter mode, using only Low-Side Mosfet
void PWM_Init()			//ok
	//fast PWM pins configured as output (timer 1)
	DDRB = (1<<HighSideMos)|(1<<LowSideMos);
	//InitTimer1
	TCNT1  = 0;
	TCCR1A = 0;
	TCCR1B = 0;
	// set to mode 14 fast PWM	see DatenBlatt S. 133
	// no prescaling
	// if inquiry to choose between buck or boost mode
	ICR1 = 159;   //Set Top Value, -> frequency 100 kHz 16 MHz/100kHz-1, 16 MHz internal clock
	if (IsCharging == true )	//buckmode, HSM with COM1B1
		TCCR1A = 0b00100010;
		TCCR1B = 0b00011001;
	else           //boostmode, LSM with COM1A1
		TCCR1A = 0b10000010;
	OCR1A = 50;   // init Wert 5 mikro sek
	OCR1B = 50;
void Get_current()
	unsigned char MSB;
	unsigned char LSB;
	i2c_rep_start(ADS1114+I2C_READ); // set device address and read mode
	MSB = i2c_readAck();			//read one byte from the I2C device, request more data from device
	LSB = i2c_readNak();			//read one byte from the I2C device, read is followed by a stop condition
	i2c_stop();						//Terminates the data transfer and releases the I2C bus.
	//switch interrupt pin configured as input
	//DDRE &= ~(1 << SwitchMode);
	unsigned char ret;
	PWM_Init();
	//interrupt handling
	EICRB|= (1 << ISC60);  //any logical change should enable interrupt
	sei(); //enabling interrupts
	EIMSK |= (1 << INT6);	//Enabling ext Int6 (port bit 6)
	i2c_init();	 // initialize I2C library
	 ret = i2c_start(ADS1114+I2C_WRITE);       // set device address and write mode
	if ( ret ) {
		 /* failed to issue start condition, possibly no device found */
		 i2c_stop();
		 }else {
			 //Configure ADS1114 continuous conversion mode
			 i2c_write(0x90);
			 i2c_write(0x01);
			 i2c_write(0x84);
			 i2c_write(0x83);
	while (1) //loop. Waiting for interrupt to change mode
		Get_current();
		//Buckmode
		if ((IsCharging == true) && (TimerSet == false)) {
			// Here Pin 9 stopped, Pin 10 enabled
			OCR1B = 100;
			TCCR1A &= ~(1 << COM1A1);		//PWM output is HighSideMos
			TCCR1A |= (1 << COM1B1);
			PORTB &= ~(1 << LowSideMos);		//LowSideMos connected to ground
			//warum immer gelsen selbst wenn kein interrupt ?
			TimerSet = true;
		//Boostmode
		else if ((IsCharging == false) && (TimerSet == false)) {
			OCR1A = 70;
			TCCR1A &= ~(1 << COM1B1);			//PWM output is LowSideMos		//warum immer gelsen selbst wenn kein interrupt ?
			TCCR1A |= (1 << COM1A1);
			PORTB &= ~(1 << HighSideMos);		//HighSideMos connected to ground
			TimerSet = true;
//interrupt Routine
ISR(INT6_vect)
	if (PINE & 0x40)//Buckmode, highside Mosfet is working (bit 6 gesetzt?)
		IsCharging = true;
		TimerSet = false;
	else 	//Boostmode
		IsCharging = false;
		TimerSet = false;
I think that the ADC device is not found, but I cannot figure out why. Could someone please point out what I possibly did wrong ?
An other possible option is that I'm using the library wrong, but how wrong?
The ADDR pin is connected to ground, which means the ADS1114 adress is 1001000 btw
Thank you for your consideration.
Murmeltier
Are you sure you have the I2C address correct and in the format expected by the library?
See: http://www.avrfreaks.net/comment...
And further detail at: http://www.avrfreaks.net/comment...
Right it seems I did this mistake.
For the address 1001000
 I typed 0x48 instead of 0x90 (which is the right one, I think)
But my problem is still there, and the debugging is stuck in exactly the same place either way. I also double-checked the connections of the elements and everything seems okay
Do you have experience with any other microcontroller(s) ?
What test equipment do you have to see what's actually happening on the wires?
Have you tried this on an Arduino?
Please provide us with a schematic or a clear picture of your I2C setup..
What value of pull up resistors are you using on the I2C_SCL and SDA lines?
Well I learnt a little bit with 8051 Microcontrollers a few years ago (assembler). (I don't remember which one exactly). Otherwise not much, I can do basic functions with the atmega32U4 or the atmega8 through arduino nano, but that's it.
As for programing, I also had a C and a c++ course at about the same time, and I did a few projects in other languages (actionscript, ST, python) so I got a basic understanding of programming, but I am not used to microcontroller programming.
I got a DMM and an osco for my tests.
I haven't tried this communication with arduino because I'm supposed to do this with the Atmega32u4 (didn't get to choose). However, I could try to make it work now with an arduino nano as an in-between step, just to check that it works at least that far. Seems easier, with the wire.h library, and there are a lot of examples. I'll still need to do it with Atmega in the end, though, so I really have to find this error.
Here is my schematic. The pull up are both 4,7kOhm.
Thanks, Murmeltier
Murmeltier wrote:
I got ... an osco for my tests.
You mean an oscilloscope?
The usual abbreviation is "scope"
So what have you learned from applying your 'scope ?
What is a MAX616 - there is no such part number at https://www.maximintegrated.com
As with any I2C project,   make sure that you use the correct Slave address.   And most importantly,   use return values.  e.g.
    if ( ret ) {
         i2c_stop();
         PORTB |= (1<<LED); // e.g. light error LED
         while (1) ;        // and tread water
    }else {
         i2c_write(0x90);   // .kbv I do not understand this
         i2c_write(0x01);   // set address register to CONFIG
         i2c_write(0x84);   //
         i2c_write(0x83);   //
The ADS1114 has a different Slave address according to the hardware pins.
And most IMPORTANTLY.   you must have external pullups e.g. 820R .. 10k
Edit.   ADDR seems to be floating.   Connect to GND for (8-bit)Slave = 0x90
What is MAX616?   SDA, SCL should have proper pullup e.g. 3.3V   (or 5V in a 5V system)
With the multimeter, I checked that everything is connected with what it should and not with what it shouldn't.
With the scope, I learned the same as with debugging: that the program doesn't work any farther: the PWM is initialized (so the PWM_init function is read), but not changed as it should be if the main function had been read at least once.
The MAX part is this one here: http://de.farnell.com/maxim-inte...
A voltage reference with 2.5 V (The ADS1114 supply range is from 2 V to 5 V)
My understanding of the connection diagram of the ADS111_ (attached) is that the pull up should be between the supply voltage (here 2,5 V) of the ADC and the SDA/SCL wires. Am I wrong ?
I added the
line (replacing LED by PORT0), but the program doesn't go that far. It gets stuck by the if-line.
As for the floating addr pin, I'm really sorry, I just forgot to make the change in the plan when I decided to ground it, but it really is grounded, and the address I use is now 0x90
Edit: added the attachment
But do you see a valid START condition, slave address, and an ACK from the slave?
So that's a MAX6166;  which is a voltage reference - why are you using it to power the ADS1114 ??
https://datasheets.maximintegrated.com/en/ds/MAX6161-MAX6168.pdf
So why not use 5V ?
You have the microcontroller running at 5V; so it will be expecting 5V levels on the I2C - so probably won't work at 2.5V !
What I get from the scope on the SDA and SCL lines is below. Pink for SCL, yellow for SDA.
If I understand this well, there is a start condition, but then nothing else and the SCL is back to high, like it were some sort of instant start/stop?
About the 2,5 V reference:
I need to measure the output current of the battery. It can be up to 10 A. I need a precision as near as possible (given my means) to 0,2% (yep, I know it’s very high) for the 500 mA – 10 A range. Which means in the case of the 500 mA an accuracy of 1 mA (so, no more than 0,5 mA/bit, to be sure, ideally a tenth of that)
The 10 parallel resistors functions as a shunt of 0,3 Ohm with a precision of +/-0,1%  (10 because of high power + higher combined precision)
The MAX series elements have a very high precision too. (2 mV/2,5 V here)
Now if I take 5 V one bit represent: 5 V / 2^(16-1-1) = 304 uV (-1 because: imprecision of ADC (I was advised to discount this one, and another -1 because the current range is from -10 A to 10 A, so I need a bit for the direction change)
which divided by 0,3 Ohm is: 1,013 mA /bit which is two high for the desired precision.
Two ways to make it better: either make the shunt value higher (which is already higher than I’d like to. 0,3 Ohm with 10 A are 30 W loss and a huge voltage drop of 3 V), or make the voltage reference smaller, which is how I end up with 2,5 V and 3 Ohm as some sort of compromise.
I’m going to try to switch the MAX piece with a 5 V voltage reference, to check if this work. If that’s the case, I’ll have to think of some solution, maybe some sort of bi directional level converter on the SDA and SCL lines ?
those aren't the only ways:
  • Use an ADC with separate reference input;
  • Use an amplifier on the input (there are parts specifically for this - Current-Sense Amplifiers)
Your microcontroller will work at 2.7V, won't it?
What speed are you trying to run your I2C at?
That pulse on SCL looks mighty narrow to me. According to the ADS1114 datasheet, in 'normal' I2C mode, it needs to be at least 1.3us wide.
You have a 5V system.  Connect pullups to 5V.   Connect ADS1114 VDD to 5V.    Connect ADDR to GND.
Paste or attach a buildable project.   Post an accurate schematic.   (or describe any changes to your earlier schematic)
Quite honestly,   I can't see how or why you have a nanosecond pulse on SCL or a 1us pulse on SDA,
After all,   a 100kHz bus has SCL pulses with 10us period.   5us low, 5us high.
Regardless of the ADC operation,   you should get good "I2C comms" between the ADS114 and the AVR.   e.g. good ACK for i2c_start(slave).   write data to the CONFIG register.   read the contents that you have just written.
What voltage is your battery?    AIN0, AIN1 must be in the permitted absolute range.   Even though you are only interested in the difference voltage.
I replaced the max voltage reference (2.5 V) with a connection to the 5 V Voltage reference already in the circuit (for the atmega). It seems to have solved my communication problem, see result below (yellow is the clock):
At least it is an improvement with which I can work further, so thank you very much people.
So you could mark that as the solution: http://www.avrfreaks.net/comment...
Do the comms work if you run the AVR and the ADC at 2.7V ... ?
(see #13)
All right, I did the marking :)
And I just checked, the communication works for 2,8 V and higher !
