Error while trying to create macro for GPIO configuration
10 posts / 0 new
So I wanted to create some easier to read functions for assigning pins and then setting and clearing them. I tried this:
#define GPIO_CONFIGURE_PIN(name, port, bit) \
__inline void make_##name##_input()        {DDR##port## &= ~(1 << bit)} \
__inline void make_##name##_output()       {DDR##port## |= (1 << bit);} \
__inline void ##name##_set()               {PORT##port## |= (1 << bit);} \
__inline void ##name##_clr()               {PORT##port## &= ~(1 << bit);} \
__inline uint8_t ##name##_get()            {return(PIN##port## & (1 << bit));}
but it doesn't work. I saw at some places that setting optimization at something OTHER than -O0 solved this issue for them, but it doesn't work for me in Atmel Studio 7. I've set the optimization to -Os, -O1 but I get the same following error:
pasting "DDRD" and = does not give a valid preprocessing token
I'm sure I'm doing something quite stupid here but I can't put my finger on it.
I tried doing straight up:
inline void make_##name##_input()        {DDRD = 0x00;}
and this works! However, using the 'port' variable by doing ##port## is failing.
I'd appreciate your help, thank you!
Show how you are invoking these macros.
Later in the same file, I'm calling
GPIO_CONFIGURE_PIN(ECHO_PIN, D, 3);
Ok so now you need to show what ECHO_PIN is. This would go easier if you simply post a complete, standalone test program.
I think you are using ##var## in places where you should just be using ##var
https://gcc.gnu.org/onlinedocs/cpp/Concatenation.html
Well ECHO_PIN is just the name, so that macro should result in 5 methods with names
void make_ECHO_PIN_input(){...}
void make_ECHO_PIN_output(){...}
etc. getting created when it's called, yes? Regardless, here's the standalone:
#include <util/delay.h>
#include <inttypes.h>
#include <avr/interrupt.h>
#include <stdlib.h>
#include <stdarg.h>
#include <stdio.h>
__inline void make_##name##_input()        {DDR##port## &= ~(1 << bit);} \
int main(void){
    make_ECHO_PIN_output();
    ECHO_PIN_set();
    while(1){
        // Do nothing
return(0);
I realized that after pasting DDRD, it's not searching avr/iom8a.h for definition of DDRD though, which is weird.
THIS HELPS!
__inline void make_##name##_input()        {DDR##port &= ~(1 << bit);} \
__inline void make_##name##_output()       {DDR##port |= (1 << bit);} \
__inline void ##name##_set()               {PORT##port |= (1 << bit);} \
__inline void ##name##_clr()               {PORT##port &= ~(1 << bit);} \
__inline uint8_t ##name##_get()            {return(PIN##port & (1 << bit));}
has done away with the compilation errors, though the macro isn't working as expected, but this helps a lot. Thanks!
Whenever you're getting trouble with preprocessor stuff, the thing to do is to look at the preprocessor output.
http://www.8052.com/forum/read/2...
For GCC, use -E or -save-temps
https://gcc.gnu.org/onlinedocs/gcc/Overall-Options.html#Overall-Options
https://gcc.gnu.org/onlinedocs/gcc/Developer-Options.html#Developer-Options
https://gcc.gnu.org/onlinedocs/gcc/Preprocessor-Options.html
#PreprocessorDebugging
Yeah, I was using the concat operator (**) incorrectly, as was correctly pointed out, everything is hunky dory now, thread can be marked solved, thanks a lot guys!
That's something that you have to do yourself: http://www.avrfreaks.net/comment...
EDIT
never mind - it's done.
