Atmel Studio 7.0.1416/7.0.1417
99 posts / 0 new
Pages
meolsen wrote:
Over-active antivirus?
Good point, unfortunately not. During my problem analysis I disabled/closed all unnecessary windows processes. The Task-Manager doesn't give me helpful hints.
Regards
Sorry to be a pain, but where has Percepio Trace gone?
We've had to remove it since our redistribution license expired.
:: Morten
Does it mean that it is removed from the Extensions as well? Can I revert the installation to a previous version to have it? Or will it disappear forever from the Extensions section? Is there a way to install it separately? Or will there be a similar feature installed?
We have removed it from the studio installation due to the license. However, if Percepio wants to make it available in the gallery is up to them. I don't know if they want to do that (I haven't had the chance to talk to them about this yet).
I'm sure that if you ask them you'll at least get an answer wink
:: Morten
Are you aware that the Atmel Studio Webpage still shows 1188 as the latest. Just downloaded the 1188 full installer and the first question was: "There is a newer version ..." ... sigh. Also the release notes are for 1188. The ones you posted here are newer.
@meolsen: You're doing a great job, thanks :-)
Yes, we know...
Note that when you download 1188, you don't have to check the "download newest" (if that was the question).
:: Morten
I am not privy to the contractual agreements between Atmel and Percepio. My understanding based on your statements is that Percepio Trace was removed from the Gallery by Atmel because of the agreement's expiry, but Percepio might not know about it yet?
the trace plugin was never on the gallery....
:: Morten
Oh, so it was part of the install? so the previous versions of Atmel would still have it?
Jupp :)
(there's also ways of moving it between versions, but I think I'm passing my usual grey-zone of operation if I divulge too much smiley )
:: Morten
kawosch wrote:
I'm running the 1417 under Windows 7. Installation worked, it compiles, but my GUI stucks about every 5 seconds for about 1-2 seconds. This is very annoying, a continuous workflow is nearly impossible (the complete Atmel Studio is affected). Did anyone else encountered this problem so far? The last Atmel Studio (1188 for me) worked fine.
Regards
After a complete reinstallation of Atmel Studio .1417 (by as-installer-7.0.1417-web.exe) everything works fine, last time I updated from .1188. I know that Atmel Studio is based on VS 2015, but my web search showed me, that some VS 2017 users have exactly the same problem. (link1 link2)
Regards
Where there's a will there's a way. I had the will, so I found the way.
Nonetheless, the release notes for the latest version should specify the disappearance of Percepio Trace.
I just upgraded to the new version of Studio 7 7.0.1417. I'm using Windows 10. Now I can not see any of my programming tools.
The Device Programming screen shows: "There are no Available tools"
I also get an error saying "The back end process exited with code -1073740791"
What is going on?. Should I try to go back to my previous version. I'm using Windows 10.
Arturo
Is the new version still unofficial? I cannot find it on http://www.atmel.com/tools/atmel..., there is 7.0.1188. I can't find release notes for 7.0.1417 as well.
That's right. However, when I tried to install 7.0.0.188 it says there is a later version and asks if you would like to install the newest version. I clicked yes and I got 7.0.1417.
Arturo
7.0.1417 is official, it's just that updating the web site is a task that (obviously) takes some time. Not everything is running smooth after the merger.
@acab, try to delete the content in Atmel\Studio\7.0\atbackend\codeCache\ and start Studio again. If not even the simulator is showing in the tools list there is nothing wrong with your tools, it's the backend that is having issues.
Thanks for your response. Unfortunately I got impatient and I decided to go back and install the old version I had which was working mostly. But It would crash with an error of "AVR8 Device Support". Therefore, I tried to re-install 7.0.1417 but I got the same error.
When I checked the Atmel site I noticed that the latest version recommended is 7.0.1188. So I donwloaded it and tried to install with the same result plus more errors listed. It also shows some links on how to troubleshoot. However when I click them I get sent to a web page that is not working.
I submitted a support case to Microchip but no answer yet.
I noticed Atmel studio still shows up as an installed. I tried to uninstall but that only restarts the installation and I get the same error again:
So to summarize my problem is that I don't have Atmel Studio anymore and any attempt to install it fail.
How can I get Atmel Studio installed again?
Arturo
FYI!
It seems my problem was a corrupted registry. Tried to Fix it with Microsoft Fix-It but didn't work. Finally I used Revo Uninstaller and that worked. Great program!.
I have installed version 7.0.1188. I still have to properly fix everything but I'm hopeful.
Thanks everybody for listening to my sorrow.
Arturo
Recently updated :
http://www.microchip.com/development-tools/atmel-studio-7
Yep... website says 1417.
What's the "MPLAB" component installed when this version is installed?
Should I be worried we will eventually be forced to use that inferior IDE?
meolsen wrote:
We are working on updating the website. Getting there soon wink
Seriously? More than a month later and its still not updated!!!  How hard is it to update a link?
My "soon" and yours are probably different. Why shouldn't theirs also be different. cheeky
What are you talking about... It's on the site...
:: Morten
Morten he is talking about the Atmel site link where people would normally go for Atmel stuff, it is still 1188
But, Atmel didn't make 7.0.1417... :-)
(I'll ask the web guys to link over to the Microchip site...)
:: Morten
Oh dear, things are starting to get "very interesting but stupid"...you may be to young to remember Laugh In.wink
I'm using win10 creators update (attached file), Atmel studio 7 build 1417, Atmega324P MCU and JTAGICE3/Atmel ICE. I can use JTAGICE3 or Atmel ICE to flash the code to board successfully. But can not debugging due to "Debugger command Prog Mode Leave failed" error, then the FUSES were reset (JTAGEN changed from checked to unchecked).
Do you have any idea to resolve this issue? Thank you.
I tried to update to 7.0.1417 on Win 7 but it doesn't work. AS installer says that I have to update Windows KB2999226 (essential) and KB2670838 and KB2978092 (optional), but all are installed!
I tried to deinstall the 3 updates and reinstall using Windows Update - no success. AS installer doesn't finish the installation because of the missing updates.
What's going wrong and how can I install 1417?
Hans
It’s always looking for IronPython v2.7.0.4
I had the latest IronPython installed 2.7.5, that didn’t work.
I reinstalled v2.7.4 and that didn’t work.
I can find a specific version 2.7.0.4
Joe
If I try to create an Arduino project I get
If I click New Example Project I immediately get this
Joe
i installed AS 7.0.1417 on a Windows 10 64bit OS.
I have a AVR ISP MK2 Programmer.
In AS the Tools list stay empty, no Programmer, no Simulator.
Target is a ATtiny2313A.
The USB Device seems ok, and the programmer work with AVRDUDE.
Any Ideas?
Any Ideas?
See if it works if you connect the MK2 and then run AS7.
Apparently, an uninstall, reboot, reinstall, reboot fixed the problem.
Now to learn how to use it.
Joe
I have an error when i want to install the last version of AVR studio on windows 10
I need help, please smiley
lolo
The error message talks about an earlier version of "Microsoft Redistributable 2010" being present and that it is a "blocker" for installing Atmel Studio.
Are you sure about that youre trying to install "the latest version"? You're talking about "AVR Studio" but it's been caölled "Atmel Studio" for many years now. Also, I can (faintly) read in your screen shot that it tries to install "Microsoft C++ 2010 x86 Redistributable Setup". I do not think (but am not 100% sure) that it is a part of the latest Atmel Studio install.
As far as sI know Atmel Studio 7 is based on newer components than that from Microsoft.
Can you tell us what version of Studio you're trying to install? I.e. give us the version number. Also tell us where/how you got it.
BTW, your screenshot is ridiculously small and very hard to read. Whenever possible, it is much better to copy error messages as text and paste them in a post here. Or possibly do a decent screenshot and copy messages as text and post both.
The version that i try to install is: 7.0.1417
my screenshot in text mode
OS Version = 6.2.9200, Platform 2
OS Description = Future OS - x64
CommandLine = d:\ac8c7fbe6640ed3b23c420963d\Setup.exe /q /norestart /log "C:\Users\cdt\AppData\Local\Temp\AtmelStudio_7.0.1417\\AS_20170702162238_0_VCRedistD10x86.log"
TimeZone = Paris, Madrid (heure d’été)
Initial LCID = 1036
Using Simultaneous Download and Install mechanism
Operation: Installing
Package Name = Microsoft Visual C++ 2010 x86 Redistributable Setup
Package Version = 10.0.30319
User Experience Data Collection Policy: UserControlled
Logging all the global blocks
Installation Blockers:
  1. Une version plus récente de Microsoft Visual C++ 2010 Redistributable a été détectée sur cet ordinateur.
Final Result: Installation failed with error code: (0x000013EC), "A StopBlock was hit or a System Requirement was not met." (Elapsed time: 0 00:00:00).
In fact: i have on my computer the version Microsoft Visual C++ 2015
Thank in advance
Laurent
lolo
Is it Windows 8?  (via winver)
IIRC, Microsoft has ceased maintenance of Windows 8.
If it's Windows Server 2012 then that is maintained.
Microsoft
Microsoft
MSDN
Operating System Version
https://msdn.microsoft.com/en-us/library/windows/desktop/ms724832(v=vs.85).aspx
via https://superuser.com/questions/680825/am-i-running-windows-8-or-8-1#680874
Microsoft
Microsoft
Windows Server 2012 update history
https://support.microsoft.com/en-us/help/4009471
OK. My French is a bit rusty, haven't spoken or written in it for 40+ years, so had to look up "récente" , and of course it's the same as the English "recent".
So, it looks like the Visual C++ 2015 has installed a newer version of the "redistributable" than the one coming with Atmel Studio.
I'm sorry, but I don't know what to do about this. One interesting StackExchange thread found while searching: https://stackoverflow.com/questi... . PErhaps there's something in that to help you?
Could anyone share the note "How to downgrade to use older Jungo drivers." referenced in the release notes for 1417?
The Server behind the embedded link http://atmel.force.com/support/articles/en_US/FAQ/Downgrading-tools-to-use-older-Jungo-driver seem to be down and Atmel sales support is not answering my mail...
Holger
Microchip support helped me. The support articles have been migrated to the microchip site:
https://microchip.secure.force.com/microchipknowledge/articles/en_US/FAQ/Downgrading-tools-to-use-older-Jungo-driver
Maybe they should put this info into the old database offline-message instead of the useless standard message i've got....
meolsen wrote:
Hopefully this will resolve the ongoing issues with Windows 10 that are piling up.
Is it possible for Atmel Studio to eventually be in Microsoft Store?
Reason : Windows 10 S
Am uncertain this is possible because Microsoft Visual Studio is not in Microsoft Store though Atmel Studio having Visual Studio Isolated Shell may make this a possibility.
Windows 10 S is likely to be popular in the US for primary, secondary, and post-secondary education and for libraries.
Locally, I doubt Arduino is in secondary schools; any primary and secondary educational use of Arduino is at one library with one professor from the engineering college.
With a reasonable drive, or a few/several mass transit rides, one can be at one library that has a makerspace.
The upgrade to Windows 10 Pro from S has a price of 49USD for a low price notebook PC (zero for more expensive PC with the zero price upgrade ending 2018-Mar-31)
Computerworld
How Windows 10 S is different from the Windows 10 you know
Windows 10 S isn't just for education; Microsoft hopes the new Windows edition will find its way into homes and enterprises, too. But beneath the familiar user interface are some significant differences.
by
Computerworld | Sep 25, 2017
https://www.computerworld.com/article/3227066/microsoft-windows/how-windows-10-s-is-different-from-the-windows-10-you-know.html
This is a full version of Windows with some limitations, one that’s designed to start up quickly, have long battery life, and keep working properly month after month after month, without resets or support calls.
Another is that schools are usually short on IT resources, so they’re looking for simpler management options that rely on the cloud.
A pristine PC
More significantly, this is a Windows that restricts which applications you can run (they have to come from the Windows Store) and ...
That [Azure Active Directory] removes Group Policy, a feature that gives IT admins control but also slows systems down and makes Windows fragile.
Instead of Group Policy,  it’s managed the way smartphones and tablets are, using MDM tools and cloud identities.
... and to install apps – either online or via a USB stick that teachers or admins plug into Windows 10 S devices.
Because Windows 10 S only runs software from the Windows Store, all the apps use a virtualized registry, so one app can’t affect the settings another app uses.
Windows Store restrictions
You can install desktop applications on Windows 10 S, but only if they’ve been sandboxed by Microsoft’s Desktop Bridge tool and come through the Windows Store.
Other software publishers using the Desktop Bridge tool to deliver software include ...
How to get Windows 10 S
... Windows 10 S ISO is available on the Microsoft Developer Network so schools can put it on their existing hardware and IT departments can test it.
(other than MSDN, it's on specific new OEM PCs)
How to get off of Windows 10 S
Schools can switch to Windows 10 Pro Edu at any time and at no cost.
via https://www.askwoody.com/2017/curious-about-windows-10-s-mary-branscombe-has-an-in-depth-report/
Microsoft
Microsoft
Windows
Desktop Bridge
https://developer.microsoft.com/en-us/windows/bridges/desktop
Edit : third URL
scratch
Klaus
Can the next major version of Atmel Studio run on Windows 10 S?
Reason: Windows 10 Enterprise in S Mode
Computerworld
Enterprises to get locked-down Windows 10 in six months
‘Windows 10 Enterprise in S Mode,’ a locked-down version of Windows 10 S, will be available from Microsoft in April or May 2018.
by Senior Reporter, Computerworld | Oct 13, 2017
https://www.computerworld.com/article/3232749/microsoft-windows/enterprises-to-get-locked-down-windows-10-in-six-months.html
"It's about having the best of Windows 10 S and the best of Windows 10 Enterprise in just one subscription package." - Augusto Valdez, a director of product marketing in the Windows group
... Microsoft 365 F1 (M365 F1) [10USD/mon] ...
Like Windows 10 S, only more
... only apps from the just-renamed Microsoft Store can be installed under the OS and will run on it.
... simpler management for IT.
Only on 10 S devices
During Ignite [Microsoft technology conference, Orlando, 2017-Oct], several OEMs, including HP and Lenovo, trotted out new notebooks, some starting as low as $275, that came with Windows 10 S.
Enter Microsoft 365 F1
M365 F1 consists of three parts: Office 365, Windows 10 and Enterprise Mobility + Security (EMS), a collection of device- and user-management services and tools.
upgrade : Windows 10 Pro to Enterpise, upgrade : Windows 10 S to Enterprise in S Mode
What's next?
[desktop PC]
In that scenario, only the latter [notebook PC with Windows 10 Enterprise in S Mode] would leave the multi-layered defenses of the company's network.
via https://askwoody.com/2017/where-windows-for-businesses-is-headed-details-about-win10-enterprise-in-s-mode/
Edit: typo
Why does the "Update pack, The project is referring to a pack that is not installed" happen?  Are these things that did not get downloaded installed with the main program install?
It is cool that the int24 has been added.  I sure would love to see double floating point too!
@Morten can (and will) probably correct me if I'm wrong, but packs installed when installing Atmel Studio will be updated/replaced with newer versions when you install a new Atmel Studio version. Packs you have manually installed will be left untouched. Your project was created before you updated Studio, and the Studio update upgraded the part pack.
All part packs are available at packs.download.atmel.com, so you can get any version you want.
Google Drive seems to blocks the files if it is syncing your files.
You may have the same thing happening with it or Dropbox.
0xA
Pages
