XMEGA LCD Controller won't display with my code.
12 posts / 0 new
I have an XMEGA-B1 Xplained board.  I am using an Atmel ICE in conjuction with Atmel Studio 7.  When I run the LCD_EXAMPLE1 it all works fine.
I have used ASF to put the LCD driver into another example program - the AT45DBX_UNIT_TESTS1  and copied the relevant initialisations and functions from LCD_EXAMPLE1 into it to try to get the LCD to display something.
I cannot get even one character to display.  Looking at the VLCD with an oscilloscope it doesn't get turned on.
I have been going through my code looking for differences and can't see anything wrong.
I have been looking at the LCD controller registers, Power Reduction register, Sleepmanager with the debugger and comparing the two projects.  I can't see anything wrong.
I am very new to XMEGAs etc so I have heaps more to learn before I have exhausted all avenues so I am not asking anyone to debug my code.  It's just that I have spent so much time on this and would rather have moved on to the next step.
Anyone familiar with using the LCD controller able to tell me any gotchas/traps for newbies?  Thanks
IME, just copying stuff out of an ASF project is not sufficient.
You need to start with the ASF project, and copy your other stuff into it ...
Have you stepped through it in the debugger?
eg,
So step through the working code, and see where it does get turned on.
Then step through the non-working code to see what's different/missing ...
+1  This method has always worked for me
awneil wrote:
So step through the working code, and see where it does get turned on.   Then step through the non-working code to see what's different/missing ...
Thanks for the suggestion.  That's what I have been doing but not methodically enough.
Doing that on the working code I see, in dissassembler, stuff that I have no idea why the compiler thought to put it in/how it got in there.  Something from ioport_compat.c.  I'm sure once I figure that out my problem will be solved.
Thanks heaps.
Don't count on it...
Greg Muth
Portland, OR, US
XMEGA legacy IOPORT software compatibility driver interface.
Copyright (c) 2014-2015 Atmel Corporation. All rights reserved.
http://asf.atmel.com/docs/3.28.1/xmega.services.timeout.example1.xmega_a1_xplained/html/ioport__compat_8c.html
Sorry,
The assembler stuff came from two lines of C back from where I put the breakpoint.  I'll keep trying.
Disclaimer:  I don't use ASF or C, but I'd think two places to look at carefully would be:
The I/O pin set up for the display.
Make sure each pin is being set up correctly, and that your code doesn't then in-set up the pin.
Look at your clock speed in the working and in the non-working code.
Make sure you aren't switching to a faster clock too soon, before some (perhaps relatively slow), start up times are being met.
 The XMEGA B family has a built-in LCD interface, so other than configuring that interface, there shouldn't be a need to setup individual pins on the LCD.
Greg Muth
Portland, OR, US
Ah, good point.
I've used the A's and the E5, but never the B's.
My only exposure to the B's is the same XMEGA-B1 Xplained board the OP has.  Here is its LCD:
Greg Muth
Portland, OR, US
A thousand apologies.
I have barely been able to work on this XMEGA stuff for a couple of days.
The LCD display working now.  I didn't have the clock settings correct.  Copying the settings from conf_clock.h in the working project into my project got the LCD working.
Now I need to see what stuff I broke doing that.
A lot of the suggestions above helped me to think more straight.  Thanks heaps.
