Weird behavior of "IF" statement
35 posts / 0 new
Hello freaks,
I am trying to manipulate the ON/OFF functionality of a GSM module.
This is my code.
#define GSM_ON        1
#define GSM_OFF       0
volatile unsigned char gsmPresent_state = 0;  // Global variable
void gsmOnOff_func(void)
    switch(gsmPresent_state)
        case 0 :
        gsmOnOff(GSM_ON, &gsmPresent_state);
        break;
        case 1 :
        gsmOnOff(GSM_OFF, &gsmPresent_state);
        break;
void gsmOnOff(unsigned char desire_state, volatile unsigned char *next_state)
	unsigned char response = check_state_command(....);
	if(response != desire_state)
		if((response == 0) && (desire_state == 1))
			// Switch ON the modem
			if((response = check_state_command(...)))
				*next_state = 1;
		else if ((response == 1) && (desire_state == 0))
			if((response = send_OFFstate_command(...)))
				*next_state = 0;
When the gsmOnOff_func() called by an external push button runs normally and the first IF statement "if(response == 0 && desire_state == 1)" compares the values and finally switched on the GSM.
Now, when I pressed again the external push button the second IF statement "else if (response == 1 && desire_state == 0)" has being ignored.
During debugging I observed that all values at this particular point are correct (response and desire_state).
Can you explain me please this behavior?
Thanks.
It may or may not be your problem, but do you have the C precedence table so ingrained that you do not need parentheses?
I.e. is
the same as
?  Dunno; have to look it up.  Yep, == is higher than &&
An important take-away from Lee's comment is that parenthesis cost you absolutely nothing when the code is finally compiled. Yes, it costs you a few more milliseconds to type but it removes any ambiguity or uncertainty about what the intended code is. For all I know, you COULD have intended
(response == (0 && desire_state) == 1)
Whether the compiler would accept it is another question (it probably won't, but it will accept some, to me, odd constructs). Adding parenthesis removes any ambiguity about what you REALLY intend to do.
What this assignment does inside if?!
I bet you mean == not =
This is a common mistake
Majid
Nice catch m.majid!  Two places in the code kobogia.
I have made enough of them, time to catch them!
Majid
Thanks for your quick replies.
Even if I use the extra parentheses (which is the correct approach) the IF statement has being ignored.
I had tried also a different way to to do the same thing :
if (response == 1)
	if(desire_state == 0)
		// Switch off the GSM
But I have the same results. The second "if(desire_state == 0)" has being ignored.
If the "response" is true (1) then I have positive reply of the module else (0) is negative.
Seriously kobogia, do you not see the two lines of code that m.majid has referenced above that need == instead of =    On a phone can't post code now
EDIT:  I'm out
How do you know it is being ignored?
  • maybe desire_state is not zero?
  • maybe response is not one?
Have you used the debugger to step through and see what's actually happening?
Note that, in 'C', zero is false; but any other value is considered true - so are you sure that response is actually one ... ?
EDIT
Clarify references
Yes, I read the code of m.majid but I still don't understand why to use a comparison operator at this point.
First, I don't want to compare any value there but I want to assign the return value of the "check_state_command()" function to the "response" variable and if it is <!=0> then run that is inside.
Second, the program is running well until this point. The problem starts here:
Please give me detailed explanation if possible.
As I mentioned in my first post I have checked already with debugging mode which are the values at this particular point.
All values are correct and the
statement must be "true".
I have checked it with debugging. "response" variable takes the value 1(one) from returned variable of the
response = check_state_command(...);
check_state_command() function.
Later I'll give you pictures during debugging.
Thanks for helping.
Yes, that is what your code as written will do.
But it is a common mistake for people to write code like that when they did want a compare rather than an assignment.
For clarity, it is better to write it as
if( response )
You don't save any code space by compacting your source text!
I think you need to start by giving a clear explanation of what, exactly, the problem is.
I have already raised a number of points in #10 - please address them
if( response )
Or, as you don't use response, as
if( check_state_command(...) )
So, I captured some images during debugging in order to explain you what the problem is.
I made also all suggested corrections in my code.
The GSM module is already switched ON because I have pressed the push button once and the first part of program is working well.
Now, when I press again the push button in order to switch OFF the GSM module.
On image (1d) showed the first IF statement which compares if the "response" and "desire_state" are equal or not.
As you can see below in watch variable's table those two variables are not equal and that is correct.
Image (2d).
At the next step the program jumps to the "else if((response==1) && (desire_state==0))" statement which is also correct according to our variable's values.
Image (3d).
Finally at the next step the program jumps to the end of the function without entered in the above "else if" statement and that is the problem.
I hope that I explained it good and you understood which is the issue.
Sometimes the debugger pointer is not in sync with the code.  What happens if you step a few times more?
It continue normally to the rest of the program.
I didn't observe any synchronization issue of the debug pointer.
The code shown in the first screenshot step1 does not match the code in step2 and step3.  This is the reason it skips the else if.  Missing { leading to mismatched if else code flow.
Please repost the actual code you are using now with the code editor button <>.
EDIT: Missing...
I'm sorry but I didn't understand what you mean that the code doesn't match. The code is the same in all steps and this is my actual code that I use, plus one more function which mentioned in my first post.
Can you give me more details please?
Thanks.
They are not the same, see my post edit above and this annotated step2 screenshot;
EDIT: Copy of original step1 screenshot is below;
EDIT: edited to annotated
Now, if you want us to continue to invest our time in helping you, please post the code you are actually using.
EDIT: me, my to us, our
Total votes: 2
Just an observation but why test twice anyway if you have already ascertained that response != desire_state
				*next_state = 1;
				*next_state = 0;
becomes:
		if(desire_state == 1)
				*next_state = 1;
				*next_state = 0;
That's without removing the need for the response variable inside the if statements.
Sometimes the optomiser might just appear to skip the code too so maybe just check that the code isn't being run without you realising.
j0n90 wrote:
why test twice
My thoughts exactly!
And what is the point of assigning the response inside the ifs:
				*next_state = 1;
and
				*next_state = 0;
since it is never used?
If the purpose of the code is to simply turn the GSM off, or on based on a press of a button may I am wondering:
If PC boards have not been done, why not simply connect the push button to one of the External interrupt pins and set the interrupt. Then when one presses the button, do a fast denounce, and then toggle the associated AVR on connected to th GSM? Super simple.
The code posted seems awfully complicated for such a simple task. Am I missing something?
jgmdesign wrote:
do a fast denounce
I just love that spelign misteak! ;-)
jgmdesign wrote:
simply (sic) turn the GSM off
One shouldn't just turn off the power to a Cellular device - like you shouldn't just pull a USB stick out of the socket.
So I would guess that the OP is being good, and shutting down "nicely" ... ?
EDIT
You don't just pull USB sticks out of the socket - do you ... ?
Andy
I think you get my simplistic point...... There simply is no need for such an elaborate mechanism for something so simple as required
JohanEkdahl wrote:
jgmdesign wrote:
do a fast denounce
Damn autocorrect on my phone! Grr
@Johan
jgmdesign wrote:
do a fast denounce
My first thought was, "That button did NOT just change states, IT DID NOT! Reports that it did are just false news"
David (aka frog_jr)
Let's keep to the thread topic and not my spelling issues :)
The code is the same but when the cursor is located inside of every statement the curly braces are getting black.
If you look carefully you will see the BLACK braces. I think is a matter of the editor.
My actual code is in my first post with suggested corrections.
Thanks anyways...
Thanks anyways...
Okay, but the way the code flow appeared in the debugger did indicate a control flow issue.  So is your code working now?
If so, what is the harm in posting your new working code, including the mentioned missing function for the benefit of others to learn from?
EDIT:  If you are going to post debugger screen shots in the future, please change the Color Theme to Blue or Light so that we don't waste time hunting imperceptible ghosts.
The code modified and is working as j0n90 suggested.
The push button is actually a button of rotary encoder and is already connected to a PCINT pin but it has a lot of functionalities since that my project includes a menu structure and not just the GSM module.
Thanks everybody for your time and I wish happy new year.
The final code is...
#define GSM_ON        1
#define GSM_OFF       0
        case 0 :
        break;
        case 1 :
        break;
	unsigned char response = sim900SendCmdWaitReply(ATCMD_AT,500000,(unsigned char *)RESPONSE_OK,NULL);
			GSM_PORT &= ~POWER_PIN;
			GSM_PORT |= POWER_PIN;
			_delay_ms(2000);
			_delay_ms(3000);
			if(response)
				*next_state = 1;
			response = sim900SendCmdWaitReply(ATCMD_POWER_OFF,500000,(unsigned char *)RESPONSE_POWER_DOWN,NULL);
			if(response)
				*next_state = 0;
kobogia wrote:
code modified and is working (sic)
Well, ...
Here
if(response)
	*next_state = 1;
and here
if(response)
	*next_state = 0;
you test the response, presumably, for "success" - but you have no handling or recovery or even notification of failure ...
That's true. I'm planning to continue the code when I'll find a free time.
Thanks for suggestion. smiley
