ATmega328P - Scrolling text on Hitachi HD44780 (16x2) LCD
8 posts / 0 new
Hi, I'm having difficulty getting text to scroll on the Hitachi HD44780 LCD (in 1-line mode).
I've placed the Hitachi's shift (left) command within an infinite loop
but no luck getting the text to move.  Any ideas?
Here's the code (haven't added functions yet):
#include <util/delay.h>
#define RS_PIN 0
#define E_PIN 1
#define DISPLAY_ON_NO_CURSOR 0x0C
#define DISPLAY_ON_CURSOR_BLINK 0x0F
#define CLEAR_DISP 0x01
#define CONTROL_PORT PORTB
#define CONTROL_PORT_DIR DDRB
#define DATA_PORT PORTD
#define DATA_PORT_DIR DDRD
    //********************* OUTPUT PINS **********************
    CONTROL_PORT_DIR |= (1<<RS_PIN);
    CONTROL_PORT_DIR |= (1<<E_PIN);
    DATA_PORT_DIR = 0xFF;
    _delay_ms(20); //Delay to give LCD time to boot up
    //********************** DISPLAY ON ***********************
    CONTROL_PORT &= ~(1<<RS_PIN); //Command mode - RS set low
    DATA_PORT = DISPLAY_ON_NO_CURSOR;
    _delay_ms(1); //Delay to let data settle on pins
    //Latch data. Falling edge-triggered clock
    CONTROL_PORT |= (1<<E_PIN);
    _delay_ms(1);
    CONTROL_PORT &= ~(1<<E_PIN);
    //***************** CLEAR AND RESET CURSOR *****************
    DATA_PORT = CLEAR_DISP;
    _delay_ms(2);
    _delay_ms(1);
    //********************* PUT INTO DATA MODE *****************
    CONTROL_PORT |= (1<<RS_PIN);
    //********************* SEND CHARACTERS *****************
    DATA_PORT = 'S';
    _delay_ms(1);
    _delay_ms(1);
    DATA_PORT = 'C';
    _delay_ms(1);
    _delay_ms(1);
    DATA_PORT = 'R';
    _delay_ms(1);
    _delay_ms(1);
    DATA_PORT = 'O';
    _delay_ms(1);
    _delay_ms(1);
    DATA_PORT = 'L';
    _delay_ms(1);
    CONTROL_PORT |= (1<<E_PIN); //E pin high
    _delay_ms(1);
    CONTROL_PORT &= ~(1<<E_PIN); //E pin low
    DATA_PORT = 'L';
    _delay_ms(1);
    _delay_ms(1);
        DATA_PORT = 0x1C;
        _delay_ms(1000);
        _delay_ms(1);
You're not switching to "command mode" before sending the scroll instruction.
The command mode thing is probably right. You don't need a full millisecond for the enable pin, a microsecond will do. Also, you appear to be delaying 2ms after setting the data port to clear, but that's wrong; you should be delaying 2ms after sending the clear command, which is to say, after pulsing the enable pin. I think there's a corresponding _delay_us().
Many thanks JohanEkdahl, I didn't spot that..  It works! :)
Changed code to:
		DATA_PORT = 0x1C;
		_delay_ms(500);
		_delay_ms(1);
		_delay_ms(1);
I'd like to get the text to reappear on the left side of the LCD as soon as it disappears from the right.
Could you suggest how I could get last 'L' character to appear on the left side of the screen, once the
'S' character has gone off the screen to the right?
Thanks the_real_seebs, I'll get that sorted.
Putting a delay of 1us for all of the enable pin commands
_delay_us(1);
causes the leftmost character 'S' to disappear from the screen.
Do you mean I should put a 2ms delay as follows:
    _delay_us(1);
    _delay_ms(2);
In these "modern" times I would not trust the scroll function to be implemented (properly) in a HD44780 clone.
But because those displays only hold a very limited amount of data you can easily write the scroll funcion in your uC firmware yourself.
Paul van der Hoeven.
http://www.hoevendesign.com
This is a bit tricky, complicated by the fact that you are using a 16x2 device in the 1-line mode.  For some background information about the LCD controller memory addressing and how that affects what you are trying to do you might like to follow the LCD Addressing link at http://web.alfredstate.edu/faculty/weimandn .  After you read that you may want to consider the suggestion in the post just above although I don't agree with the premise in his first sentence.
Don
