atmega32 UART transmission problem in Proteus
30 posts / 0 new
Hi all.
I am trying to simply send a set of characters from an atmega32 to a virtual terminal by UART protocol in Proteus.
This is my code: https://gist.github.com/cod-r/83af8bd8b633b7d7ce81e76e50e928e3
What my code is supposed to do: Every 3 seconds send the text "lab micro" to the terminal, but i only get a weird character on the terminal every 3 seconds (see atached photo and please ignore the LCD)
I am using a baud rate of 300bps, 8bit, 2bit stop, even parity.
I have checked every setup of the terminal and its the same as my code.
I tried using an external clock of 8mhz, as well as the internal clock, but no luck.
We tested the exact same code in my uC class with an easyAVR7 development board and everything was working fine.
I tried using another baud rate in the code, no parity, odd parity, 1 bit stop, I think i tried everything.
Any sugestions?
codR wrote:
Any sugestions?
   Contact Proteus support, you paid for the license!
To trace bug set virtual terminal to show hexcode and see whats is the hex code of weird characters
Majid
What makes you think that a forum related to Atmel Studio bugs is a suitable place to ask for support for another company's product?
Are you sure you have the baud rate properly set in the AVR? Your system clock is not USART friendly, and you may need to set the 2x bit to get communications within spec.
2 stop bits? Most of the time communications is 8 bit, no parity, one stop bit. Do you have the terminal set properly?
As noted above why not contact proteus as you have a licensed installation?
Since this is not Studio related I will move this to general programming
Wrong baud rate generally results in "garbage" characters being displayed; eg,
Baud Mismatch
See: https://learn.sparkfun.com/tutorials/serial-communication
see atached photo
It makes life a whole lot easier if you embed the picture in your post where we can all see it (as above) - rather than attach it.
Instructions here: http://www.avrfreaks.net/comment...
And make the effort to crop-out any irrelevant details
EDIT
fix quote
Extra Stop bits should not hurt - a stop bit is just the same as a line idle condition
awneil wrote:
jgmdesign wrote: 2 stop bits? Most of the time communications is 8 bit, no parity, one stop bit. Extra Stop bits should not hurt - a stop bit is just the same as a line idle condition
No argument there, I was/am only saying that its unusual.
I suspected proteus and wrote some code in CVAVR to test 300,600,1200,2400,9600 baud rates in proteus. Result:
300 bps dos not work fine,
600, 1200, 2400, 4800, 9600 works fine
Virtual terminal doesn't work fine when set 2 stop bits, works fine when set to 1 stop bit
Most likely simulation bug,
Majid
Well that's definitely something to take up with Proteus, then!
EDIT
But beware: http://www.catb.org/~esr/faqs/sm...
m.majid wrote:
300 bps dos not work fine, 600, 1200, 2400, 4800, 9600 works fine Virtual terminal doesn't work fine when set 2 stop bits, works fine when set to 1 stop bit Most likely simulation bug,
Either I don't have enough information, ir I'd meed to dig deeper in anything attached/linked above.
1.  >>OF COURSE<< two stop bits could be a problem -- if the receiver is expecting 2 stop bits but the transmitter is only sending one.    From there, it depends on how framing errors are handled.
1a.  However, I guess I'd agree that it may not cause the gibberish display.
1b.  Use the same settings on both ends.  Explicitly show those settings.
2.   Do we know the AVR's clock rate?  Have we seen the AVR UART setup code?  There are certain clock speeds where 300 will require a UBRRH value, and 600, etc. not.  IIRC there are also clock speeds where 300 (even with correct UBRR) has a higher error rate than desired.
Assembly code in the github link in post #1.
Well, I did specifically say extra stop bits should not cause a problem - but, agree that insufficient stop bits could cause problems.
That is proteus
Can't stop use it, can't trust it!
Majid
Absolutely extra stop bits is no problem at trasmiter side
Majid
Your code is wrong:
ldi r16, 0x6C     ;ascii for "l"
out UDR, r16
call wait         ;wait for data to be sent
You normally check UDRE before writing to UDR.  e.g.
putchar:              ;print the character in R16
wait:
    in r16, UCSRA     ;read the state of UCSRA
    sbrs r16, UDRE    ;check if UDRE is empty
    rjmp wait         ;UDRE is not empty, we wait more
    out UDR, r16      ;then write to UDR
    ret
Note that it is always worth factoring code into subroutines.   e.g. putchar() and putstring()
It makes your program logic much easier to follow and maintain.
Your "unusual" approach of shooting first and asking questions later might work.   It makes my head hurt.
I suspect that it is corrupting the USART buffer.
If you want to check for TX completion,  you use the TXC flag but it is a bit fiddly because you must clear TXC manually.
I would expect a licensed copy of Proteus to simulate the USART correctly.    Try it and see.
m.majid wrote:
That is proteus
Hmm -how are you so sure?
Again, see: http://www.catb.org/~esr/faqs/sm...
Can't stop use it
Of course you can!
In this day & age of on-chip debug, the value of simulations like this is greatly reduced.
can't trust it!
See above.
It is a well-established product from a reputable source - it seems rather unlikely that something so basic could be seriously broken.
Again, have you actually contacted Proteus support - https://www.labcenter.com/ - about this ?
Or used the Proteus forum: https://support.labcenter.com/forums/index.php
edit
typo
Ofcourse labcenter is reputable company, I am familiar with proteus isis since I was student at university, and I use it to examine some aspects of my projects. It is useful
I cant trust it since I spend hours and days to test and establish a bug in FE of UART in ATmega model, you know the below thread :
http://www.avrfreaks.net/comment/2212801#comment-2212801
The value of simulation for AVR is $487+$322
For 2 new issues "ATmega 300 bps baud rate" and "VirtualTerminal"
Don't worry, I am pursuing both to establish absolute result, I will share results here
Majid
That value of an Atmel ICE is about $100!
Since you own a Proteus license, why are you here getting help with it?
m.majid wrote:
That is proteus Can't stop use it, can't trust it!
Can you explain why you cannot stop using it?
Well you paid it didn't you?
Well, add $30.00 for 5 Arduino UNO knockoffs from Ebay and now you have actual hardware to work with.  And any terminal program can communicate with the USB connection as it emulates as a COM port.
And before you say that this wont work because you are using a Mega32......the USART is the same in the Mega32 as it is in the Mega328.  What IS diffent is the internal clock on the UNO but its a non issue in the grand scheme of things.
JIm
Didn't see that, so the debugger costs between $3 and $5 instead of $100??
The main reason is it is easy to use, I can quickly test and evaluate design ideas with minimum effort before starting real pcb design. also simulating several input sources and inspecting instruments.
Debugging is not everything, Benenefits of simulation such as easy to make and archive projects can not be denied
I mean along with benefits simulation can not be 100% trusted, it should be used watchfully
Majid
Then there was no need for this thread then, right? wink
As the MANY threads we have here on Proteus users finding out that the simulator is not as good as they thought.
I used to use Electronics Workbench Pro back in the day and found it used up way too much time compared to a breadboard and a handful of parts from the stores in the lab.
Nowadays I simply CAD the boards, and while they are being made write the code and then load it into the PC board and make adjustments as needed.
To each his own.
especially nowadays with on-chip debug - so you can single-step, examine variables & registers, etc, in the actual hardware ...
Although no simulation is perfect, I very much doubt that the "problems" the OP is seeing are faults in the simulator - far more likely to be bugs in the code.
I repeated the test using ATmega88 both on real chip and simulated chip on proteus isis
Internal rc 8 MHz
300/600/1200 bps
Sending fixed data 0x55
And inspected 1bit pulse width on oscilloscope
300 bps pulse is wrong only on isis, true on real chip
600/1200 bps pulse is true both on isis and real chip
Now I am quite sure it is proteus fault!
What can be other explanation?
Majid
That is very interesting.   I would expect Proteus to Simulate just fine.
URRR = 8000000 / 16 / 300 - 1 = 1666 which is well within the 12bit UBRR size.   It even works with U2X (UBRR = 3332)
An 8MHz AVR will fail on 110 baud and 75 baud.   But I doubt if there is much call for those speeds nowadays.
I have never considered buying a Proteus licence.    It seems an excellent Tool for Universities to use.
Proteus is indeed very good, but the simulation of some more obscure details of the peripherals may have bugs. Certainly not on par with the AS simulator.
Sometimes, if you have a legit Proteus license, they will send you an improved model file fixing the bugs you discovered. Other times, they will kindly ignore you: "We will look into it, fix it in a future version..."
Maybe some bugs are just too hard to fix, who knows...
So have you reported it to Labcenter (the makers of Proteus) yet?
There's no use just moaning about it here - it has nothing to do with Atmel.
Dont worry I have already reported
sharing test results to help solve this thread is useful not moaning
Majid
What I find interesting that the OP (CodR) is NOWHERE to be found after the first post.  This thread seems to be m.majid vs just about everyone.
Long story short, I think the OP is gone, There seems to be a  bug in Proteus(which has been reported allegedly), and there is NO reason to continue this arguing any further.
Topic locked
