Hardware Error in ATMega328p ?
22 posts / 0 new
I have come across a most curious behaviour in the ATMega328p. Under certain conditions, doing an st  X,R16 appears to brick my program (but not the chip itself). Storing certain values at XH:XL as shown by the "<- *****" comment below just stops the code running. I apologize for assembler, but this is all I use. I have tried with two different 328's, from different sources. Here is my test code, with a lot of the preamble omitted:
; Background:
; This is a highly condensed version of a filing program, only to show a
; curious behaviour of the ATMega328p
; I have not included any of the initialization,
; Setting up the stack,  disabling the Watchdog, clearing RAM, and
; initializing the LED output
; I use a=R16, b=R17 and 'file_pointer' happens to be R13 (must have been
; the wrong choice ;-)
main:
	clr	file_pointer
mm3:
	sbi	LED_port,LED	; Flash LED - at least we've got here
	rcall	wait20ms
	cbi	LED_port,LED
	rcall	wait200ms
	loadZ	test_string
mm1:
	lpm	a,Z+
	cpi	a,0     ; exit on null terminator
	breq	mm2
	mov	XL,file_pointer
	clr	XH
	ldi	b,'f'	; 'f' is no good, 's' is OK
	st	X,b		; <-- !!!!!!!!!!!!!!!!!!!!!!!!!!
	inc	file_pointer
	rjmp	mm1
mm2:
	sbi	LED_port,LED	; Flash LED - and we've got here
	rcall	wait20ms
	cbi	LED_port,LED
self:	rjmp	self
test_string:	.db	"Now is the time for all good men to come to the aid of the party",0,0
.include	"wait.inc"   ; routines to provide delays
.dseg
.org	SRAM_START
file_buffer:	.byte	128	; file output buffer
end_file_buffer:
; End of source code
I have tried a few different letters in the line < ldi  b,'f' > and some also cause a problem. If I had to take a stab at the cause I would say it was a problem in the chip's microcode but I don't even know if this is how Atmel chips work.
What, exactly, do you mean by that?
How are you observing it?
In my highly simplified snippet, you never see the second  flash from the LED.
The original code was much more complicated and included the ability to write values out on a serial interface, using this I found that the code simply stopped running after it had processed a few characters of the test string.
And from that you conclude that the code has, "simply stopped running" ?
Have you tried running this in a simulator, so that you can step through and see exactly what's happening?
The ATMega328p has on-chip debug - so you can do the same thing in the actual target.
http://www.catb.org/~esr/faqs/sm...
Perfect situation and code to run in the Simulator in Atmel Studio, since no advanced peripherals are used. In the Simulator you can track execution flow and inspect register contents and status flags to find out if/why it possibly gets stuck in the mm1 loop - or what else happens. For that, shorten (or cancel out) your delays since they will take a very long time to execute in the simulator.
I admit to never having tried a simulator, but will now go and fire up my Studio 7, learn the simulator, and have a go. May take me a little time to learn.
I normally use a text editor in linux, AVRA to do the assembly and avrdude to upload programs to the target with an AVR Dragon, but I also have a Windows 10 machine for Studio 7 which, so far, I've only used to write the fuse bits.
Welcome to the 21st Century
wink
ROTFLMAO!!!
So you are suggesting that the ATmega328P, the chip used in countless Arduino boards, has a hardware error, that is just now being discovered, because your code doesn't do what you expect it to do.  Is that right?
Perhaps it is because your code is attempting to overwrite the first 65 addresses in the data space.  So it first clobbers the R0, then R1, .... , and lastly EEDR, but it clearly never makes it to EEDR.
EDIT:
Greg Muth
Portland, OR, US
Greg, you're quite right, and thank you so much. Removes face from palm. I'd got so used to starting my iteration from an already-loaded base value for XH:XL. I sometimes wish learning was not so humiliating.
Been there.  Done that.  Got the T-shirt.
Greg Muth
Portland, OR, US
Why? Many developers used low level exclusively.
I can sympathize with that!
But.. Better debugging capabilities caters for earlier revelation of the bug which leads to less humiliation.
Many here argue that the best tool for debugging is e.g. paper, pen and brain. I agree. But I also think that debugging is, to a large extent, the "art of finding out", and good tools makes it so much easier to find out.
Even if this problem has been solved, I urge you to test drive the simulator. Unless you have provisions for on-chip debugging the Simulator is well worth knowing.
jbug11 as in 68HC11 debugger??
Yes, John. Just keeping my hand in.
John just made a new BFF for 2018......cheeky
JIm
Actually John has been a "BFF" since last century, I think, or at least early this century and had the pleasure of his visit at the Ampertronics' worldwide headquarters. cheeky
JBUG11 is a on chip debugger for the HC11 (found Version 5 on this computer) but I haven't used it for many years, well since I have been using AVRs at least. It was better version of the Motorola mbug11?? and it would come in very handy when away from the workshop and the Motorola development system, it allowed programming and debugging without hardware.
I used it in Hong Kong (2000 AD) when the client there could not make up his mind on what he wanted exactly so it was a matter re-assembling the code and reprogramming on site, single stepping or putting a breakpoint to examine things inside the chip.
I used NOHAU EMUL-51 and EMUL-68.... Both with Trace boards.  I owned the EMUL-51, was loaned an EMUL-68 by the Motorola FAE who was trying to get me to convert.
Great stuff to use. Too bad they are practically worthless on Ebay these days sad
So, did you guys also report a hardware bug when a test 'HC11 app didn't produce the expected results?
We were saved from this embarrassment by the lack of forums such as this (I realize there were bulletin boards - not the same at all). In a way, my OP error was a hangover from the HC11, still with the mental image that the user's RAM started at zero and forgetting that Bogen and Wollan had already absconded with a few handy low RAM addresses for their working registers.
1)  OK, I'll bite:  On AVR8 architecture, what is special about low RAM addresses, such that kidnapping must be reported?  [I'm trying to think of a RAM-address-space-related instruction that doesn't use 16 bits (or more) of address]
2)  Use an Xmega model, where the feature was taken away.  Back when I was your age, >>with<< the feature on an AVR8, one could have a "register variable" and take its address to pass to a function or whatever.  No more on the new-fangled.
In other words, in my opinion, I think we have >>lost<< something by not having GP registers memory-mapped.  (Now, the waste of low >>I/O<< space on the unified map -- what a shame)
I think he IS your/our age or older and DOES KNOW a lot about microcontrollers, maybe not about AVRs yet. wink
Just a saying.  But that is really my point -- reitereating
No matter how far the pointing goes to use of address space...
I've had splendid success with AVR8.  If I were to start now, perhaps a bit passe.  But still pretty solid.
