Reading wrong LM35 value with Atmega8
27 posts / 0 new
Hi, I have temperature sensor lm35 and Atmega8A-PU.
I have connected
lm GND to avr GND
lm DQ to avr AC0
lm VDD to avr VCC via 4.6k Ohms resistor (if I do not use the resistor the lm35 gets insanely hot)
now i use this code to read the value and i display it on one number led display by showing the numbers gradually. E.g. if the temperature is 18.5 the display will show 1 then 8 then 5..
#ifndef F_CPU
#define F_CPU 1000000UL
#endif // F_CPU
#include <util/delay.h>
#define DELAY_IN_MS 2000 /* 2 sec */
uint16_t ReadADC(uint8_t ch)
	//Select ADC Channel ch must be 0-7
	ch=ch&0b00000111;
	ADMUX|=ch;
	//Start Single conversion
	ADCSRA|=(1<<ADSC);
	//Wait for conversion to complete
	while(!(ADCSRA & (1<<ADIF)));
	//Clear ADIF by writing one to it
	ADCSRA|=(1<<ADIF);
	return(ADC);
int main()
	int numbers[] = { // LED display numbers
			0b01000000,
			0b01110011,
			0b00100100,
			0b00100001,
			0b00010011,
			0b00001001,
			0b00001000,
			0b01100011,
			0b00000000,
			0b00000001,
			0b11111111 // off
    DDRD = 0b11111111;
	ADMUX=(1<<REFS1)|(1<<REFS0); // Internal 2.56 Voltage Reference
	ADCSRA=(1<<ADEN)|(1<<ADPS2);  // 16 division factor (62.5 kHz ADC frequency)
	int res;
		uint16_t adc_value;
		adc_value=ReadADC(0)/4; // 2.5 mV resolution
		res = adc_value*10; // to simplify reading onto one digit led e.g 18.5
		PORTD = numbers[res / 10 / 10 % 10]; // tens e.g. 1
		_delay_ms(DELAY_IN_MS);
		PORTD = numbers[res / 10 % 10]; // units e.g. 8
		PORTD = numbers[res % 10]; // decimal e.g. 5
		PORTD = numbers[10]; // off
    return 0;
The problem is, I am indeed getting about 18 degrees in a room that has 22.3 degrees, is there something wrong with my code? Or is the temperature sensor malfunctioning?
I have connected
lm GND to avr GND
lm DQ to avr AC0
Please don't mess about with trying to describe circuit connections in text - draw a schematic!
Then there is something very fundamentally wrong!!
surprise
Probably, you have the connections wrong - VDD and GND swapped, perhaps?
Once it has got "insanely hot", it has probably been damaged.
awneil wrote:
draw a schematic!
aka "circuit diagram".
Some tips here: https://electronicsclub.info/circuitdiagrams.htm
http://www.bbc.co.uk/bitesize/ks3/science/energy_electricity_forces/electric_current_voltage/revision/3/
EDIT
If you prefer video: https://www.youtube.com/watch?v=...
(but note that putting cells in parallel is not generally a good idea)
+1
I did that once...
Well the sensor is probably damaged at this point so I would throw out the current one and replace it with a new one and DOUBLE CHECK your connections.
As far as the code is concerned, I believe the LM35 outputs 10mv/C IIRC, so how have you set your reference voltage for the ADC for example?  How do you have AVcc decoupled?
As far as using single conversions go, I would take multiple readings and average them together.
JIm
jgmdesign wrote:
I did that once...
Actually, I did it only the other day with a DS1820
blush
That is, indeed, what the datasheet says: http://www.ti.com/lit/ds/symlink/lm35.pdf
jgmdesign wrote:
+1
I did that once...
If I swap VDD with GND the value read is 0. When I was using the same sensor with raspberry pi, I also used the resistor, without which it was getting how. It was reading correct values back then (its already about 6 months since I was playing around with pi)
Ok I will throw it away and need to buy a new one first.
JIm
I am commenting this in the code above, reference voltage is 2.56V which gives me 2.5 mV resolution. The LM35 itself has 10 mV so it is 4 times less, thats where I get the / 4.. (more details on that here http://extremeelectronics.co.in/avr-tutorials/interfacing-temperature-sensor-lm35/)
This is best I can do (I do not include LED connections as they would make things messy):
edit:forgot the resistor: updated
That's perfectly fine.
Note that it is a convention (not entirely rigid) that schematics should generally read left-to-right - so inputs are on the left, and signals "flow" to the right.
The resistor remains a puzzle - you certainly should not need it, and your LM35 certainly should not get hot.
Something is still fundamentally wrong.
Are you sure it's an LM35?
You've labelled its output as "DQ" - but that's not what the linked tutorial calls it, nor what the datasheet calls it.
You haven't actually got a DS1820 or suchlike instead - have you ... ?
omg, you're right. I am still a beginner and when I asked for LM35 in a shop I actually got DS18B20 (https://www.gme.cz/data/attachments/dsh.530-067.1.pdf) without even realizing. I am sorry, this is stupid.
And whose Vcc and GND are reverse of the LM35
LM35:
DS1820:
I see a certain resistor mentioned earlier that is used differently here as well.....
EDIT: OP beat me to the post button
Increase wrote:
omg, you're right.
It does happen occasionally!
laugh
The thing is I was looking into the correct spec, so I connected the wires correctly. If I put the resistor as shown on jgmdesigns schema, the sensor gets hot, only if the resistor is put as drawn on my schema, the sensor remains cool. I don't know why.
You have the power pins reversed.  LOOK at both pinouts of the LM35 and the DS1820...they are reversed.  Also what voltage are youpowering the circuit with?  TheLM35 can tolerate high voltages while the DS1820 not so much
nope, trust me, VDD is connected to 5V, GND to ground and DQ to the MCU as shown on my schematics. I know they are reversed from LM35, but I was using datasheet of DS1820, just not realizing its not LM35...
Increase wrote:
nope, trust me,
Like you knew you were using an LM35? wink
Now which one are you planning on using as both devices have VERY different outputs.  The LM35 has an Analog output, the DS1820 has a digital output.
JIm
right now, I'd like to try more with current DS1820, even though I don't know if its still okay, but I can't get my hand on anything else until monday. Then I would consider LM35 as it seems easier to handle.
There is something very odd happening here.
The active current for a DS1820 is 1mA. With that resistor in series with the power rail a 4.6V drop will happen across the resistor with means that on a 5V power supply the DS1820 will only see 0.4V so it can never work. And as it can never work it won't get hot.
(It's actually a bit more complicated as it will never draw 1mA with a 0.4V rail, but it certainly won't work.)
jgmdesign wrote:
Increase wrote:
nope, trust me,
JIm
I am gonna kill myself. :D
Ok, I had it in reverse, you know why? Because I didn't realize the schema in the doc is BOTTOM VIEW. There is so many new things for me and then such small details just evade my brain..grr..
So when I connect the wires correctly I get value of 0. I guess the sensor is already screwed. I think that is all for now, until I buy a new one.
 I get value of 0.
The LM35 puts out an analog voltage, and one reads it with an ADC, does some math conversion, and gets the temperature.
The DS18B20 is a DIGITAL temperature sensor.
You have to read the data sheet.
You have to send it digital commands, and read back digital data.
All doable, but rather complex for a beginner if you are not using a canned library for the interface.
Brian Fairchild wrote:
With that resistor in series with the power rail ... it can never work. And as it can never work it won't get hot.
But OP said it got hot without the resistor!
Yes, I think so.
Indeed.
Datasheet page 1: "Current drain < 60uA"
60uA * 4k6 = 280mV
5V-280mV = 4V72 and LM35 should work down to 4V.
Best guess: Sensor is fried, possibly a short somewhere.
I don't really understand why anyone would order a single 50ct sensor while experimenting.
I usually buy batches of 10 or so.
Swapping out a sensor (uC) on a breadboard is a very fast and easy way to diagnose circuit problems / mysteries.
Paul van der Hoeven.
http://www.hoevendesign.com
Well, "retail" they're more like $2 (online, Digikey) - possibly even more, as it sounds like the OP actually got it from a local, physical store.
But even so it is, as you say, good to have spares ...
The more accurate grades are even more expensive. Digikey wants $7.47 (quantity 1) to $3.187 (quantity 1000) for an LM35CAZ.
- John
exactly i got it from local store, and back when I was buying it I didn't realize I can destroy the sensor in an instant. good i didn't buy more anyway because LM35 seems better now than the DS... :)
(almost?) any electronic component will be destroyed "in an instant" by gross abuse like connecting its power supply backwards!
EDIT
For discussion on this point, go to: http://www.avrfreaks.net/forum/s...
