Split from: Empty program and RAM in simulator
19 posts / 0 new
Hello, I am new on this Board and I hope it's the right way to ask you.
I have a Problem with simulating programms in Atmel Studio 7,
a few days before it ran correctly, but after some Updates i have Problems with viewing the SRAM Memory (see screenshot below).
The data Iram is correctly adressed, but there are only "??".
I already have installed Studio once again, but it's not working.
Which chip are you using and which version of AS7? Never used IRAM, just normal RAM window.
I can't easily look it up but does internal RAM start at 0060 or 0100 in Tiny2313?
Questionmarks in the Memory Window means that you're reading outside any segment that is declared in the device descriptor (atdf file).
:: Morten
Just looked up datasheet so RAM in 2313 *should* start at 0060. Does that mean the ATDF is wrong?
Sounds like it ... :) I'll have to check (questionmarks can also come if the read request fails, but that usually also means that the ATDF is wrong...)
:: Morten
OK, I'll bite -- what piece of evidence led you gurus to conclude '2313 of some flavour?
But indeed, a quick test program showed values starting at 0x150...
Both Stefan and I replied to your post Lee but then someone split the thread and our two posts have been left behind in the original.
As we said there it was in the screen shot he posted. It shows he's using ATtiny2313 in the Simulator.
http://www.avrfreaks.net/comment...
Shame that the forum doesn't automatically add links to show where a split went to & came from...
Ok It is still there in the 1st page blush didn't see that before.
I'm sorry, but I only have some Time at evening to work with.
1st. the Version of Atmel Studio:
Atmel Studio 7 (Version: 7.0.1417 - )
© 2015 Atmel Corp.
All rights reserved.
OS Version: Microsoft Windows NT 6.1.7601 Service Pack 1
Platform: Win32NT
The Chip I'm using is a Tiny2313 and there is 128 Bytes SRAM on (beginning) Adress 0x60
Once I start the Debugging I have found following :
looking for the 'ZZZZZ' every step (F11) in Simulator takes the Memory away to another place.
The two screenshots are only one Step apart. Why walkes the area?
Sorry for my bad english.
Please post your code using the <> button above if you want someone to try things out.
It's only a test-Project, but the same Problem.
Code:
; djpetka.asm
; Replace with your application code
start:
	lds r16, test
	inc r16
	sts test, r16
	ldi r17, 'Z'
	sts ram1, r17
	sts ram2, r17
	sts ram3, r17
	sts ram4, r17
	sts ram5, r17
rjmp start
.dseg
	test: .byte 1
	ram1: .byte 1
	ram2: .byte 1
	ram3: .byte 1
	ram4: .byte 1
	ram5: .byte 1
I meant you need to use the <> BUTTON not characters when posting code, it's next to the Omega sign. I'll clean it up for you in a minute.
so it works ok here
The ATDF looks correct at least
<memory-segment name="IRAM" start="0x0060" size="0x0080" type="ram" external="false"/>
:: Morten
The issue there almost looks like the DSEG location counter in the assembler was wrong (random) ?!?
(thought it's true that does not explain question marks where you might expect RAM locations to be displayed).
Can the Atmel assembler produce a listing? It would be interesting to see what locations "test", "ram1", etc. have actually resolved to be.
It is not comprehensibly for me, wich Location is used for each cycle or step.
I have deleted all parts of Atmel Studio (also the Regedit-Parts)
Then installed a older Version. Now it runs nice again!
I will test some Update in the next time, to see if same error occures again.
Thanks for your help and ideas!
Hi Guys and Gals!  Hope you have a great new year!
Does anybody know if the ?? problem was solved; either EEPROM or IRAM. Have this issue with Studio 7 still. I have done all the updates I can find with no luck.
Seems to work fine as is with Studio 4.
Thanks!
Todh
