OLED Suggestions
12 posts / 0 new
Been looking through Ebay for an OLED display to get my feet wet on, but most are only 128 x 64 in size.
Has anyone used something a little larger?  I also noticed that the majority use I2C to communicate, and the occasional SPI.  I would think I2C too slow for real time bar graph displays.
Any pointers on this would be appreciated.
My 5 ct:
On I2C -> 400kHz / 128 / 64 = 48Hz which should be enough for some animations.
Datasheet of of SSD1306 (popular oled driver chip) suggests:
• Pin selectable MCU Interfaces:
o 8-bit 6800/8080-series parallel interface
o 3 /4 wire Serial Peripheral Interface
o I2C Interface
A quick search on Ali only shoed the small oled screens, but after a few clicks I found a store with different sizes displays.
These also seem to have similar resolutions, but the price goes up quickly.
https://www.aliexpress.com/store...
Ali also has "super amoled HD" for sale.
This seller has lot's of telephone replacement screens:
Paul van der Hoeven.
http://www.hoevendesign.com
Thanks Paul.  I will look at these as a possible solution.
Have you already given any thought to the software you want to use?
These displays are dot-matrix, so you'll have to render your own fonts.
Lot's of commercial drivers are available, some open source ones, different licences etc...
Rinkydink has a utility to transform a bitmap of your text font into a C readable array.
I've also seen quite some fonts on displaycore.
github spits loads of projects out. Try it with the type number of the oled controller you want to use.
https://github.com/search?utf8=✓&q=oled
http://www.rinkydinkelectronics....
http://displaycore.org/?page=oled
Quite some time ago I stumbled into platformio, but I still haven't done much with it.
Below the output of:
paul@dualcore ~ $ yes | pio lib search oled >asdf.txt
Found 152 libraries:
ESP8266-OLED Display Library
#ID: 1487
esp8266-Arduino library for I2C-OLED displays
Keywords: display
Compatible frameworks: Arduino
Compatible platforms: Espressif 8266
Authors: Klar Systems
SparkFun Micro OLED Breakout
#ID: 366
Library for the SparkFun Micro OLED Breakout
Keywords: display oled
Compatible platforms: Atmel AVR, Atmel SAM, Espressif 8266, Intel ARC32, Microchip PIC32, Nordic nRF51, Teensy, TI MSP430
Authors: SparkFun Electronics
I2Cdevlib-SSD1308
#ID: 108
SSD1308 is a single-chip CMOS OLED/PLED driver with controller for organic / polymer light emitting diode dot-matrix graphic display system
Keywords: i2c, driver, oled, pled, i2cdevlib, display
Authors: Jeff Rowberg
SSD1331
#ID: 156
OLED-Display (SSD1331, SPI)
Keywords: spi, oled, display, graphics
Authors: Watterott electronic
Adafruit_GFX
#ID: 188
A derived version of the BSD licensed Adafrut GFX library for the SSD1306 controller for an OLED 128x32 or 128x64 display using SPI or I2C.
Keywords: spi, oled, i2c, display, ssd1306
Compatible frameworks: mbed
Compatible platforms: Freescale Kinetis, Nordic nRF51, NXP LPC, ST STM32, Teensy
Authors: Neal Horman
SparkFun_MicroView
#ID: 260
The MicroView is a chip-sized Arduino with a built-in OLED, available from SparkFun Electronics
Keywords: oled, display
Adafruit-SSD1331
#ID: 262
This is a library for the 0.96" 16-bit Color OLED with SSD1331 driver chip
Keywords: led, color, 1331, oled, graphics, display
Compatible platforms: Atmel AVR, Espressif 8266
Authors: Adafruit Industries
SH1106
#ID: 312
SH1106 Oled driver which offers scrolling frames, custom fonts, etc
Authors: Rene-Martin Tudyka
FaBo 214 OLED EROLED096
#ID: 732
A library for FaBo OLED I2C Brick
Keywords: display
Authors: FaBo, Hideki Yamauchi
PG25664CG
#ID: 1138
PG25664CG OLED Driver for DisplayCore
Keywords: oled, displaycore, lcd, graphics, glcd, tft, display
Compatible platforms: Microchip PIC32
Authors: Majenko Technologies
Show next libraries? [y/N]: ESP8266_SSD1306
#ID: 562
A I2C display driver for SSD1306 oled displays connected to an ESP8266 or ESP32
Keywords: oled, i2c, display, ssd1306
Compatible platforms: Espressif 32, Espressif 8266
Authors: Daniel Eichhorn, Fabrice Weinberg
Adafruit Feather OLED
#ID: 1919
Helper class to work with 128x32 OLED displays on Adafruit Feathers
Keywords: display
Authors: Adafruit
Mini Grafx
#ID: 1670
A generic graphics library containing several drivers for TFT, OLED and e-paper displays
Keywords: tft, oled, e-paper, embedded, graphics
U8glib
#ID: 8
Universal Graphics Library for 8 Bit Embedded Systems (SSD1325, ST7565, ST7920, UC1608, UC1610, UC1701, PCD8544, PCF8812, KS0108, LC7981, SBN1661, SSD1306, T6963, LD7032)
Keywords: lcd, oled, display, graphics
Authors: Oliver Kraus
U8glib
#ID: 9
Compatible platforms: TI Tiva
ACROBOTIC SSD1306
#ID: 457
Library for SSD1306-powered OLED 128x64 displays!
Keywords: display
Authors: ACROBOTIC
ESP8266 QRcode
#ID: 534
ESP8266 Generate QRCode for SSD1306 oled displays 128*64 pixel
Keywords: display
Authors: Anun Panya
Adafruit SSD1325
#ID: 584
SSD1325 monochrome OLED library
Keywords: display
Authors: Adafruit
OakOLED
#ID: 690
An Adafruit GFX driver for the Oak OLED (an SSD1306 with no reset line)
Keywords: display
Authors: Brian Taylor
OLED_pictivaWide
#ID: 964
Very fast driver for Osram Pictiva OLED OS288048PQ33MxxC11
Keywords: display
Authors: sumotoy
Show next libraries? [y/N]: LedMatrixDim
#ID: 1020
LedMatrixDim library
Keywords: oled, displaycore, lcd, graphics, glcd, tft, font, display
MonoIcon
#ID: 1021
MonoIcon library for DisplayCore
Keywords: buttons, toolkits, oled, displaycore, widgets, lcd, graphics, glcd, tft, display
Widgets
#ID: 1022
Simple Widget toolkit library for DisplayCore
LCARSInterface
#ID: 1023
LCARS-like interface widgets
BMP
#ID: 1025
DisplayCore BMP Flash renderer
Keywords: image, bmp, oled, jpeg, displaycore, lcd, graphics, glcd, tft, display
BinaryVector
#ID: 1026
Binary Vector drawing image class
JPEG
#ID: 1027
JPEG library
Raw565
#ID: 1028
DisplayCore RGB565 Flash renderer
BMPFile
#ID: 1029
DisplayCore BMP File renderer
CP853
#ID: 1030
CP853 font for DisplayCore
Show next libraries? [y/N]: Kimberley
#ID: 1031
Kimberley font for DisplayCore
CP884
#ID: 1032
CP884 font for DisplayCore
CP861
#ID: 1033
CP861 font for DisplayCore
CP113
#ID: 1034
CP113 font for DisplayCore
Linux6x10
#ID: 1035
Linux6x10 font for DisplayCore
Font44
#ID: 1036
Font44 library
CP111
#ID: 1037
CP111 font for DisplayCore
ArialBold
#ID: 1038
ArialBold font for DisplayCore
LCDish
#ID: 1039
HD44780 LCD font for DisplayCore
Liberation
#ID: 1040
Liberation font for DisplayCore
Show next libraries? [y/N]: Squircle
#ID: 1041
Squircle font for DisplayCore
Gem
#ID: 1042
Gem library
SheepSans
#ID: 1043
SheepSans font for DisplayCore
CP862
#ID: 1044
CP862 font for DisplayCore
DOS
#ID: 1045
DOS VGA font for DisplayCore
ProFont6x11
#ID: 1046
ProFont6x11 font for DisplayCore
CP850
#ID: 1047
CP850 font for DisplayCore
Sinclair
#ID: 1048
Sinclair font for DisplayCore
Aquarius
#ID: 1049
Aquarius font for DisplayCore
Doorly
#ID: 1050
Doorly font for DisplayCore
Show next libraries? [y/N]: Ingot
#ID: 1051
Ingot library
Unicode
#ID: 1052
Unicode Font library
Comic
#ID: 1053
Comic book font for DisplayCore
SUN8x16
#ID: 1054
SUN8x16 font for DisplayCore
ComfortAA
#ID: 1055
Comfort Anti-Aliased font for DisplayCore
LCARS
#ID: 1056
LCARS font for DisplayCore
Open24Display
#ID: 1057
Open24Display font for DisplayCore
Hazard
#ID: 1058
Hazard symbols font for DisplayCore
CP866
#ID: 1059
CP866 font for DisplayCore
PEARL8x8
#ID: 1060
PEARL8x8 font for DisplayCore
Show next libraries? [y/N]: SUN12x22
#ID: 1061
SUN12x22 font for DisplayCore
CP881
#ID: 1062
CP881 font for DisplayCore
OldStandard
#ID: 1063
OldStandard font for DisplayCore
Display7SegShadow
#ID: 1064
Display7SegShadow library
EngliBesh
#ID: 1065
EngliBesh font for DisplayCore
BunnyMambo
#ID: 1066
BunnyMambo library
GeorgiaBoldItalic
#ID: 1067
Georgia Bold Italic font for DisplayCore
Roboto
#ID: 1068
Roboto font for DisplayCore
CP883
#ID: 1069
CP883 font for DisplayCore
Topaz
#ID: 1070
Topaz font for DisplayCore
Show next libraries? [y/N]: Acorn8x8
#ID: 1071
Acorn8x8 font for DisplayCore
CP863
#ID: 1072
CP863 font for DisplayCore
OCRAExtended
#ID: 1073
OCR A Extended font for DisplayCore
Linux10x18
#ID: 1074
Linux10x18 font for DisplayCore
VGA8x8
#ID: 1075
VGA8x8 font for DisplayCore
Linux7x14
#ID: 1076
Linux7x14 font for DisplayCore
DejaVuSansMono
#ID: 1077
Monospaced DejaVuSans font for DisplayCore
CP885
#ID: 1078
CP885 font for DisplayCore
CP864
#ID: 1079
CP864 font for DisplayCore
CP437
#ID: 1080
CP437 font for DisplayCore
Show next libraries? [y/N]: AVOP
#ID: 1081
AVOP Japanese Font
CP851
#ID: 1082
CP851 font for DisplayCore
RawGold
#ID: 1083
RawGold library
CP880
#ID: 1084
CP880 font for DisplayCore
Terminus6x12
#ID: 1085
Terminus6x12 font for DisplayCore
CP112
#ID: 1086
CP112 font for DisplayCore
DejaVuSans
#ID: 1087
BPMonoItalic
#ID: 1088
BPMonoItalic Font for DisplayCore
CP852
#ID: 1096
CP852 font for DisplayCore
CP865
#ID: 1097
CP865 font for DisplayCore
Show next libraries? [y/N]: CP882
#ID: 1098
CP882 font for DisplayCore
XTerm
#ID: 1107
XTerm font for DisplayCore
Atari
#ID: 1108
Atari font for DisplayCore
Carbine
#ID: 1109
Carbine font for DisplayCore
Display7Seg
#ID: 1110
Display7Seg font
Ubuntu
#ID: 1111
Ubuntu font for DisplayCore
CP737
#ID: 1112
CP737 font for DisplayCore
Bisasam
#ID: 1113
Bisasam library
AtariButtons
#ID: 1114
Atari 8-bit font in Buttons
MINI4x6
#ID: 1115
MINI4x6 font for DisplayCore
#ID: 1116
Acorn font for DisplayCore
Icon8
#ID: 1117
Icon8 mini icons
LedMatrixBright
#ID: 1118
LedMatrixBright library
VGA8x16
#ID: 1119
VGA8x16 font for DisplayCore
CP860
#ID: 1120
CP860 font for DisplayCore
Ecqlipse48
#ID: 1121
Ecqlipse48 library
Keywords: icons, oled, displaycore, lcd, graphics, glcd, tft, display
Ecqlipse32
#ID: 1122
Ecqlipse32 library
Arial
#ID: 1123
Arial font for DisplayCore
Tutorial9Mono
#ID: 1124
Tutorial9Mono library
Gentleface32
#ID: 1125
Gentleface32 library
Show next libraries? [y/N]: Brankic
#ID: 1126
Brankic Mono Icon library for Display Core
Iconic
#ID: 1127
Iconic library
PICOL
#ID: 1128
PICOL library
Gentleface48
#ID: 1129
Gentleface48 library
Filters
#ID: 1130
DisplayCore Image Filters
Keywords: filter, image, oled, displaycore, lcd, effects, graphics, glcd, tft, display
Diablo16
#ID: 1131
Diablo16 library
KS0108
#ID: 1132
KS0108 GLCD Driver for DisplayCore
SDL
#ID: 1133
SDL driver for DisplayCore
SSD1306
#ID: 1134
SSD1306 library (Basic IO Shield)
ILI9340
#ID: 1135
ILI9340 driver for DisplayCore
Show next libraries? [y/N]: VGA
#ID: 1136
VGA Driver for DisplayCore
ILI9342
#ID: 1137
ILI9342 library for DisplayCore
ILI9341
#ID: 1139
ILI9341 library for DisplayCore
ILI9163
#ID: 1140
ILI9163 driver for DisplayCore
LM6800
#ID: 1141
LM6800 driver for DisplayCore
ST7735
#ID: 1142
ST7735 driver for DisplayCore
ILI9325
#ID: 1143
ILI9325 library for DisplayCore
VLCD
#ID: 1144
VirtualLCD Driver for DisplayCore
S6D0154
#ID: 1145
S6D0154 library for DisplayCore
LinuxEvent
#ID: 1146
Linux Event driver
Show next libraries? [y/N]: Picadillo
#ID: 1147
Picadillo-35T driver for DisplayCore
XPT2046
#ID: 1148
XPT2046 touchscreen driver
AnalogTouch
#ID: 1149
Analog Resistive Touchscreen driver for DisplayCore
Framebuffer332
#ID: 1150
DisplayCore RGB332 Framebuffer
HX8347D
#ID: 1151
HX8347D library
BD663474
#ID: 1152
BD663474 driver for DisplayCore
NativeFB
#ID: 1153
Native Framebuffer (Linux) Driver
Framebuffer565
#ID: 1154
DisplayCore RGB565 Framebuffer
ILI9481
#ID: 1155
ILI9481 driver for DisplayCore
Goldelox
#ID: 1156
4D Goldelox driver for DisplayCore
Show next libraries? [y/N]: SSD1963
#ID: 1157
SSD1963 7 inch TFT
SSD1289
#ID: 1158
SSD1289 3.2 inchTFT
gciWidget
#ID: 1159
gciWidget DisplayCore toolkit library
Adafruit SSD1306 128x64
#ID: 1513
SSD1306 oled driver library for 'monochrome' 128x64 and 128x32 OLEDs!
Keywords: display
Authors: Adafruit
TeensyView
#ID: 1550
A library for driving the TeensyView OLED board
Keywords: display
Accessory Shield
#ID: 1797
Allows an Arduino board to use the DFRobot Accessory Shield
Keywords: sensors
Authors: BiagioMkr Adafruit, Biagio Montaruli
WeatherStation
#ID: 563
A wifi connected information display
Keywords: oled, display, embedded
U8g2
#ID: 942
Monochrome LCD, OLED and eInk Library. Display controller: SSD1305, SSD1306, SSD1309, SSD1322, SSD1325, SSD1327, SSD1329, SSD1606, SSD1607, SH1106, T6963, RA8835, LC7981, PCD8544, PCF8812, UC1601, UC1604, UC1608, UC1610, UC1611, UC1701, ST7565, ST7567,...
Keywords: display
Authors: oliver
Adafruit SSD1306
#ID: 135
Keywords: display
Authors: Adafruit
SparkFun Flexible Grayscale OLED Breakout
#ID: 2004
Library for the <a href="https://www.sparkfun.com/products/14543">SparkFun Flexible Grayscale Display</a>.
Keywords: display
Show next libraries? [y/N]: ssd1306
#ID: 1904
SSD1306 i2c OLED Display driver, PCD8544 spi display driver
Keywords: display
Authors: Alexey Dynda
Ucglib
#ID: 943
True color TFT and OLED library, Up to 18 Bit color depth. Supported display controller: ST7735, ILI9163, ILI9325, ILI9341, ILI9486,LD50T6160, PCF8833, SEPS225, SSD1331, SSD1351, HX8352C.
Keywords: display
Authors: oliver
Plan on using Studio and an AVR.  I will look at Rinkydink,  Thanks.
Need to get a better sized OLED...these 128/64 are just too small
So what kind of size do you need?
Are you looking for character displays, eg http://www.midasdisplays.com/products/character-17.page ?
Or graphic, eg http://www.midasdisplays.com/products/graphic-18.page ?
Boring, plain old rectangular - or other shapes?
eg
http://www.4dsystems.com.au/product/uLCD_220RD/
(these are just things which have hit my inbox recently - not actually used any of them)
Just had a little peek at Mouser:
https://eu.mouser.com/Optoelectr...
And they seem to sell lots of oled displays.
Then it occured to me that a self respecting oled display manufacturer would probably have some software package to go with their display's.
Picked a random display from:
https://www.vxdisplays.com/pmoled
... and had a peek at a "datasheet/design pack" for an pmoled display.
"Display_Mode.c" has some routines for writing commands, blocks, images to the display, but i see no look up tables for ascii rendering
Great stuff Paul!!
I will look at ordering a couple from mouser and find a vendor for VXL, then look for similar on Aliexpress and ebay.
Thanks!
Knowing that OLED displays have limited lifetimes and are subject to image burn-in, I collected information from Newhaven Display's standard OLED modules. Blue and white displays seem to have the shortest lifetimes, character displays have longer lifetimes, smaller and lower pixel count displays are brighter and data sheets have inconsistencies.
Stan
Adafruit have some very pretty 'O' LEDs:
Image result for neopixel ring
cheeky
sbennett wrote:
Knowing that OLED displays have limited lifetimes and are subject to image burn-in, ...
Matrix Orbital has graphic OLED with a MCU and storage for fonts and bitmaps :
https://www.matrixorbital.ca/manuals/gok-series/gok12832a-25-sm-manual
(page 51)
(lifetime) (100K hours)
(page 15)
5.3 OLED Burn-In
(screen saver or turn display off)
It has a region scroll feature that might be used to implement a screen saver.
(page 24)
3.13 Scroll Screen
(extent)
(signed words for pixels X & Y)
If you're amazed by a simple mouser search, then try octopart:
https://octopart.com/search?q=oled
Messed around a bit over there and I saw some Xplained boards with oled displays.
Fun thing of octopart is that it gives direct links & prices from multiple vendors & distributors.
Another part of octopart is that they seem to be integrating some BOM functionality.
Put in a list of your favourite PCB software output and octopart spits out more suggestions than you can handle. Looks impressive...
But to take a step back. Why Oled?
Small colorfull TFT lcd's are widely available in all kinds of sizes and resolutions and are extremely cheap.
https://www.aliexpress.com/whole...
