Atmega328P _delay_ms default function gives 2x delay of set value
11 posts / 0 new
I am writing program in Atmel Studio for Atmega328P and downloading that on arduino board with avrdude.exe
#define F_CPU 16000000UL
#include <util/delay.h>
int main( void )
/* Initializations */
DDRB |= (1 << DDB5);   // LED on-off output pin
while (1)
PINB |= ( 1<<PINB5);
_delay_ms(1000);
PINB &= ~( 1<<PINB5);
_delay_ms(1000);
This is the DSO snap for that pin. Its toggling after every 2 sec.
For the modified code like:
int main( void )
while (1)
_delay_ms(1000);
_delay_ms(400);
It generates square wave with 1.4s . This is very weird.
Initially I thought its some clock issue. So I generated PWM, and it gets generated with correct frequency.
Please help me with this.
I am guessing this is a Studio project and you are using an Arduino for hardware?
If so, in teh Fuses Section of Studio for programming check to see if the DIV8 fuse  is set to be programmed.  There will be a 'Check' in the little box next to DIV8 if this is the case uncheck that box and hit Write/Program.
JIm
EDIT:
while (1)
_delay_ms(1000);
_delay_ms(400);
No, thats correct.  The HIGH side of the wave form is set for 1000ms, the LOW side is set for 400ms....Look at your code carefully
PINB is changing the pullup, not the port output right?
What if you use PORTB instead of PINB
Thank you!
This worked.
Updated code:
int main( void )
while (1)
PORTB |= ( 1<<PORTB5);
_delay_ms(1000);
PORTB &= ~( 1<<PORTB5);
_delay_ms(400);
But in the datasheet I found this:
That's why i was setting PINB.
Yeah, I have a little trouble understanding that as well, but I always thought I was the only one(Until your post ;) )
I always write to PORT as well.
Glad to read its working for you finally.
The PINB &= ~( 1<<PINB5); will not affect the PB5 pin (it would toggle the other pins on PORTB that are set as output; however, they are all inputs).
David (aka frog_jr)
Priyanka.K wrote:
But in the datasheet I found this: That's why i was setting PINB.
Do you understand why your code in post #1 worked as it did, or are you still puzzled about that?
I added a comment to let you know what is happening to you.
int main( void )
	while (1)
		PINB |= ( 1<<PINB5);	// (toggle PORTB5)
		_delay_ms(1000);
		PINB &= ~( 1<<PINB5);	// (not effect)
		_delay_ms(1000);
	// (As a result, the port output is inverted once every 2 seconds.)
No.
Interesting -- what part of "writing to PIN toggles corresponding bit(s) in PORT" is not clear?
Now, the ramifications lead to a number of combinations.  But PORT always controlled output state when an output, and pullup when an input.
Back when men were men and AVR8s didn't have all the newfangled features, it was a painful process to toggle an output pin.  Several cycles and instructions to do the job, and RMW considerations as well -- one could not toggle an output in an ISR for debugging purposes without thinking about possible RMW.
Around the time of [Mega48-family introduction?] the AVR chip designers added the feature, and use a write to PIN to implement -- thus avoiding having another I/O register.
There have been examples here of algorithms making great use of the toggle feature.  IME for "general" work it is more of a "Meh."; toggle most done on a debugging indicator.
theusch wrote:
No.
Ahh yes, it is toggling the output.  I forgot about that.  Setting PORTB while set as in input sets the pullup.
DDRx -->  input/ouput direction
PORTx --> when output, sets high or low output, when input sets pullup enabled or not enabled
PINx --> when set, it toggles output, when read it shows the pin state
Right?
Note that using update operators on a PIN register presents logical difficulties.
Compiler writers generally resolve the issue by ignoring it.
The result is that update operations can behave differently depending on the the optimization level.
The first PINB update probably toggled PORTB.5 with an SBI instruction.
The second probably did nothing with a CBI instruction.
With low optimization, both probably also cleared 7 PORTB bits,
International Theophysical Year seems to have been forgotten..
Anyone remember the song Jukebox Band?
