Support of ATmega324PB in avr-gcc
9 posts / 0 new
 Any news or ideas on the topic? Just bought 324PB Xplained Pro and all of a sudden found out that I can't even compile for it.
 Toolchain I have is 3.5.3, no mention of 324PB in headers and device specs. Release notes for the latest gcc toolchain (3.5.4) at
http://ww1.microchip.com/downloa...
 list only 324A, P and PA
 Is it the same with the Studio? I can't use it, just curious.
 PS
 Not sure if this belongs here or in Compilers. Please, feel free to move.
Please explain that.
You mean you have previously been able to "compile for it", but now can't?
What, exactly, are you doing?
What, exactly, is happening?
Any error messages?
 Sorry for not being perfectly clear. This is my first 324PB so I haven't been able to compile for it before.
 Here is what happened:
avr-gcc -Wall -pedantic -O3 -pipe -mmcu=atmega324pb -DBLI_APP_VERSION=\"0.2\" -I. bli.c -c -o bli.o
avr-gcc: error: cannot access device-specs for 'atmega324pb'
Well,  AS7 knows all about the ATmega324PB.
However there are a few changes in the header files compared to the ATmega324PA.
e.g. bit names in multiple peripherals like USART0, USART1 are now called RXC instead of RXC0, RXC1
and single peripheral SFR names like TWCR are now called TWCR0, TWCR1 because there are two TWI channels in the 324PB.
You will need to do a certain amount of conditional editing.   e.g. #if ..324PB.. #define TWCR TWCR0
There have been similar name conflicts in the past.  e.g. with RXC RXC0
The new system is more logical.  i.e. single bit name because RXC0, RXC1 are both in the same position in UCSR0A and UCSR1A
http://packs.download.atmel.com/#collapse-Atmel-ATmega-DFP-pdsc
via
http://distribute.atmel.no/tools/opensource/Atmel-AVR-GNU-Toolchain/3.6.1/avr8-gnu-toolchain-readme.pdf
(page 8)
4. Supported Devices
P.S.
0-series megaAVR?
Some new megaAVR in the works.
 gchapman,
 Thanks, atpack worked. Do you know if avrdude part definition of 324pb can be derived from 324p by simply changing signature to 0x1e 0x95 0x17?
You're welcome.
Yabusame wrote:
Do you know if avrdude part definition of 324pb can be ...
Don't know (won't have mega324PB until Jan '18)
Yabusame wrote:
... 324pb can be derived from 324p by simply changing signature to 0x1e 0x95 0x17?
An assumption is like the change for mega328PB.
http://svn.savannah.gnu.org/viewvc/avrdude/trunk/avrdude/avrdude.conf.in?r1=1391&r2=1397
 That's what I did. I can flash the chip and change fuses.
 However, Atmel's migration guide 324->324PB says `ATmega324PB is not a drop-in replacement for ATmega324 variants, but a new device.' So 324PB may require more profound changes. We'll see.
