avr-gdb DDD "Function "xy" not defined"
7 posts / 0 new
as I changed from Windows to Linux some years ago I missed the possibility to debug my ATMEGA with AVR-Studio :-(
Now I tried AVARICE with DDD and a AVR-DRAGON. Actually I am able to debug expect one problem. I can' t see the values for any peripheral registers like PORTA which are defined in <avr/io.h>. This information seems to be lost during preprocessing and the gdb has no access to this. Another ugly consequence is that I cant set a breakpoint via the graphical interface of DDD on a line like this: PORTA &= ~_BV(PORTA0). The DDD issues something like:
(gdb) break PORTA
Function "PORTA" not defined.
Breakpoint 4 (PORTA) pending.
Setting the breakpoint via the gdb command break LINEx works.
Does anybody know how link this information?
Thanks a lot
Butze
avr-gcc -c -mmcu=atmega32 -I. -gstabs -DF_CPU=16000000UL -O1 -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=./toggleLED.lst  -std=gnu99 -Wundef -MMD -MP -MF .dep/toggleLED.o.d toggleLED.c -o toggleLED.o
Ah ha! It was exactly for this reason I developed this...
http://www.avrfreaks.net/forum/b...
In fact see the picture here...
http://www.avrfreaks.net/comment...
The whole point being that "PORTA" etc. are not C cymbols but simply preprocessor macros (that don't make it through to the debugger).
Having said that, because the debugger here is avr-gdb you could try -g with one if the higher levels if DWARF which might carry #define's through to the debugger.
They don't, in fact, even make it as far as the compiler - see: http://www.avrfreaks.net/comment...
See: http://www.avrfreaks.net/comment...
(gdb) break PORTA
You need to break on a line number, not on a 'function symbol' as PORTA is not a function...
:: Morten
Maybe (s)he want to break on an access to (read/write) PORTA ?
Does GDB support that ... ?
hmh... Maybe? Compile with -g3 to get the used macro definitions into the symbol table, and 'watch &PORTA' ? This all depends on the gdb server supporting data breakpoints and watches...
:: Morten
I tried several -g options but the symbols for the peripheries wont be listed in the elf file.
In the meantime I came to the (perhaps wrong?) conviction that for professional debuggers the reference to the memory mapped peripheries is always done by an separate memory description file which is not supported by DDD(?).
Thank  you clawson for the idea with the structure pointer! I did not trie yet but it looks really promising.
Butze
