Using DS1307 tiny RTC module with 3 volts
7 posts / 0 new
I am looking to power my Atmega32L from the same same coin cell that is used as battery back up for the Tiny RTC module. Ds1307 datasheet says that required vcc is 5 volts but since I'll be runing my Atmega32 on 3 volts, I won't be able to wake up the RTC module with 3 volts. Is there anyway to power the module with 3 volts.
Tiny RTC I2C module
No buts - the minimum is 5V (well; 4.5, actually)
https://datasheets.maximintegrat...
But, surely, it can't be hard to find a 3V RTC these days?
Ok thanks!!
Doge123 wrote:
Hi, it actually works with 3v.
No - that is wrong.
The datasheet clearly states that the DS1307 requires 5V for proper operation.
Most of the posts in that other thread are about interfacing it to a 3V device (Raspberry Pi) - not about running it from 3V.
For a 1-off hobby project you might get away with running it at 3V - but you should not rely upon out-of-spec operation for a serious design.
As this post says, superior replacements that do operate at 3V are available.
EDIT
Doge123 Has, apparently, edited post #3 and completely deleted the entire content to which I was replying.
Hi, I realized it after I posted my comment, you had not posted anything. So, I edited it so to not confuse anyone who visit this. Seems, you posted at the same time. I stand corrected.
No,  I have not tried this.
If you remove the Battery,   it might work because VCC > VBAT.
However the best solution is to invest £0.99 in a DS3231, DS1302, PCF8563, ... module from Ebay.
Personally,  I am very sceptical that anything for £0.99 will contain 100% quality components.
My experience is that the cheap modules "work" but are not 100% accurate.   suggesting that they use crystals that failed QC.
Total votes: 2
If you are indeed trying to make an app that runs off the fumes from a urine sample, why are you choosing a Mega32 model that will consume much more power than more modern alternatives, and will have fewer power-saving features as well?
