Problem With external interrupt of Attiny84
9 posts / 0 new
my purpose is to use external interrupt pin. I hooked up button to PB2 in Attiny84, I want to just turn an LED ON when a button is pressed
I can't figure out what's the problem .. any help please ?
there is my code for interruption
void interupt(){
        MCUCR=(0<<ISC01)|(1<<ISC00);
        GIMSK=(1<<INT0);
ISR(INT0_vect){
        PORTA = PORTA&~(1u<<7);
int main(void){
        DDRA=0b10111100;
        PORTA=0B10110100;
        interupt();
        sei();
        while(1);{}
So what does happen when you press the button?
Oh, and for completeness...
1) How have you hooked up your button?
2) How have you hooked up your LED?
3) How have you proved that your controller is being programmed with your code correctly?
4) How have you proved that your controller is running your code?
Please post a schematic or at least a picture of your setup.
When I press the button Nothing happened, the LED does not turn ON
You can find the schematic in the attachment file
Thank you
Thank you Brian for your reply,
to respond your first and second questions I post a schematic of my project.
For your third and fourth questions : There is no error happened when I passed my code to my controller,
I tested it with a simple code that reads the state of the button (High or Low) and turn the Led ON or OFF following the state of the button and it worked fine.
The problem happened when I switch to working with interrupt, I don't know why it doesn't work.
Your code sets pa7 low in the isr - this turns the led off according to your schematic.
The code is a "one shot". As soon as the condition happens once that is it and nothing else will change from there on. You might want to consider having the interrupt toggle state. Or perhaps when the event occurs set a flag and when the code in a main while loop sees the flag set it starts a delay after which it switches the LED state back.
