LM7001,ATTiny2313A-20PU and 74LS138N
4 posts / 0 new
My symply project for using ATTiny2313A-20PU and 74LS138N  with LED display with common cathode for control LM7001M (dummy edition , without memory save and channel switching, using only 'f+' and  'f-' on pins 2 and 3  ).
Prototype of the code is  http://vrtp.ru/index.php?act=Attach&type=post&id=440354 (from Internet ,prototype  is not my project), modifyed for led with  common cathode, may be rebuilded for 5... 6 digits, 3... 5 buttons.
V2.05_mem.zip (367.92 KB) - version for  memory read button, step control , IF constant  was patched for  IF filter , BQ  7.2 MHz and AFC of tuner . Using with 10 uF ,27 Ohm and  0.8...1,5kOhm in the amplifier-integrator.
V208.zip with circuit and hex for 5 buttons, 1 memory preset , advanced circuit , IF 10.7 MHz , Fosc>Fsig,internal RC osc 4MHz,LEDs
For modify step replace data in "Send8Bit(0b10000000);"  in the subroutine and change types of data for Fcounter, change subroutines for LED out , memory
saveing and frequency increment/decrement :
if(ifmode==1  )
SPI_CE_PORT |= (1<<CE_PIN);
Send8Bit((DIVISOR  +IF_VAL) & 0xFF);//D7...D0
Send8Bit(((DIVISOR +IF_VAL ) >> 8) & 0xFF); //T2=0,T1=0; D13...D8;  or replace  & 0xFF  mask  using &0b00111111(T2=0,T1=0; ) or &0x3f mask
Send8Bit(0b10000000);  //byte=(S<<7|R2<<6|R1<<5|R0<<4|TB<<3|B2<<2|B1<<1|B0<<0)
PORTA = 0;
PORTD&=~(1<<CE_PIN);
//divisor=(fsig-fif)/fref
//divisor=(145500-10700)/25=5394
//divisor=(100800+10700)/100=1115
//data=D0;D1;D2;D3;D4;D5;D6;D7;D8;D9;D10;D11;D12;D13;T0;T1;B0;B1;B2;TB;R0;R1;R2;S;
//or control=(S<<7|R2<<6|R1<<5|R0<<4|TB<<3|B2<<2|B1<<1|B0<<0)
data for patching Send8Bit(control);
0b10000000 for step 100 kHz ,FMIn
0b11000000 for step  50 kHz ,FMin
0b10100000 for step  25kHz,FMin
0b11100000 for step 5 kHz,FMin ( it may not work for some freq.)
0b01100000 5kHz ,AMin
0b00010000 10kHz,AM in
0b01010000 9kHz ,AMIn
0b01110000 5kHz ,AMin
 0b00110000 1kHz ,AMin
           Send8Bit(  ... );                               Send8Bit(  ... );                                  Send8Bit(   ... );
D0;D1;D2;D3;D4;D5;D6;D7     ;D8;D9;D10;D11;D12;D13;  T0;T1;     B0;B1;B2;TB;R0;R1;R2;S;
1  ;1  ; 1 ;  1;  0 ; 1 ; 1 ; 1      ; 1 ; 1  ; 0   ;  0  ;  0  ;  0  ;  0 ; 0 ;             control                                         FMin divisor 1007
x  ; x ; x ;  x ; 1 ; 0 ; 0 ;  0      ; 1 ; 0  ; 0   ;  1  ;  0  ;  0 ;  0 ; 0  ;             control                                        AMin divisor =145 (fit data in subroutine )
 R0 R1 R2 fref [kHz] BO1 BO2 BO3
0    0   0   100         1        1   0
0    0   1   50           1        1   0
0    1   0   25           1        1   0
0    1   1   5             0        0   1
1    0   0  10            1        0   1
1    0   1  9              1        0   1
1    1   0  1              0        1   1
1    1   1  5              0        0   1
Input             Output
B0 B1 B2 TB nBO1 nBO2 nBO3
0   0   0   0   *     *     *
0   0   1   0   0     0     1
0   1   0   0   0     1     0
0   1   1   0   0     1     1
1   0   0   0   1     0     0
1   0   1   0   1     0     1
1   1   0   0   1     1     0
1   1   1   0   1     1     1
0   0   0   1  TB    *     *
5 1 0 1 TB 1 0
5 0 1 1 TB 0 1
5 1 1 1 TB 1 1
1 0 0 1 TB 0 0
 S: Divider selection data
1: FMIN, 0: AMIN
If it is necessary, patch TB<<3|B2<<2|B1<<1|B0<<0 in the control byte using datasheet and   use control|=(TB<<3|B2<<2|B1<<1|B0<<0) for BOx input
MC3362DW.pdf (288.33 KB)  MC3362 datasheet (tuner    27 MHz, tuner 145,6 MHz for amateur radio )
V211.zip   for step 25 kHz, ATTiny2313A/ATTiny4313,6 digits  (may be with some bugs, check and modify source .c codes )
V211_01.zip (897.71 KB)  for fosc<fsignal
 V211_tx.zip (897.63 KB) for Fif=0 (TX)
V215_ATTiny4313_plus.zip (911.86 KB) Version LM7001_pll.atsln for Atmel studio 7  , ATTiny4313,4MHz RC internal osc , no CKDIV8, (converted from .aps,  no place in MCU, may be with bugs)
My experience PLL board for tuner with TEA5711
It may work with LM7000N with patching of codes
Please post new projects in ...
https://community.atmel.com/proj...
This "AVR Freaks Projects" forum is for a discussion by others about projects found in the projects section.
Topic locked
