How to create a libarary in Atmel Studio 6
12 posts / 0 new
I want to create my own libraries in Atmel Studio 6 (The header file and source file for a library). I've already written my code in a simple editor but don't know how to make them .h and .c files in order to use them in my projects.
This will help http://www.avrfreaks.net/index.p...
There is also an updated PDF, use the link at the top of that page
Alex
"For every effect there is a root cause. Find and address the root cause rather than try to fix the effect, as there is no end to the latter."
Author Unknown
But I didn't find what I want, in that PDF. Sorry but maybe you didn't get it. I want to know how to create a .h file in Atmel studio 6.
There is nothing special about a header file (.h) apart from the extension, it is a simple text.
You can create it in any text editor or in AVRstudio and save it with .h extension.
Alex
Author Unknown
Thanks Alex.
But, In Studio 7, how does one specify where such .h files are to be located?
David Abineri
Under the C/C++ compiler section there's an entry called "Directories", list any directories to be searched by the preprocessor there and they'll be passed as -I's on the command line.
Thanks for this hint but I just went carefully through all the menus in Studio 7 and there is no "C/C++ Compiler Section"
How does one get to the C/C++ Compiler Section in order specify the directories for the preprocessor to search?
Also, is just the  .h file needed in order to compile properly or are other files needed too?
Many thanks
David Abineri
You can just add the .c and .h files to your project, or tell the compiler where to search for them during the build.
Oh come on? You must have set SOMETHING in the projrct properties before now?? In the Solution Explorer you right click the project and select Properties. Under there you'll find option for Compiler and Linker (among other things).
Kiobk, your advice is normally 100% but in this case it's not as simple as just adding .h to the project, that won't lead to the prepro finding it for #include if it's not in an existing search path.
If I right-click on the project in the solution explorer and choose properties, I get
Common Properties
     Startup Project
     Project Dependencies
     Debug Source Files
Configuration Properties
     Configuration.
None of these lead to anything about the compile options.
What am I missing here?
Thanks.
David Abineri
dabineri wrote:
If I right-click on the project in the solution explorer and choose properties, I get   Common Properties      Startup Project
You're right-clicking the Solution (which is the top node in the tree view in the Solution Explorer).
Either right-click the node under the solution (which is the project node) and select Properties,
Or select Properties in the Project menu.
Both will lead to the project properties.
I would advise you to go through the Users Guide for Atmel Studio. Available in the Help menu in Studio, or online here.
