atmega328pb signature byte error
16 posts / 0 new
I am using atmega328pb mcu, i have been trying to burn bootloader using usbasp and avrdudess.
but everytime time i detect for signature it returns different values all the time.
i've tried uno boards they seem to work properly, also tried to flash hex code directly but the values are not being written into the flash memory.
j1 is the isp header.
Never, ever, use -F (Force) with avrdude.  Unless you show us a picture of your breadboard or a schematic there is really not much we can suggest other than check your wiring again.
wiring is proper, i've double checked them. i was able to burn hex blink to arduinos no problem there.
Is this chip installed on an Arduino?  The clock fuse is set for an external crystal oscillator, if you do not have an external crystal oscillator connected to the chip you will need to supply a clock to recover the chip to a usable state.  Always remember what I said above about -F.
Late here, I will let one of the other AVRFreaks continue to help you with this issue.
EDIT: ssf.png in OPs 1st post was added after this post, may need to disregard this, or not, see post #8.
R5 and R6 are shown as 0 Ohms. This means that whatever is connected to WI_FI RXD and WI_FI TXD will interfer with the SPI programming signals. And why have you got R7 there at all?
The fuse value for clk selects internal rc oscillator so the crystal is of no use. This is a custom board not an arduino.
Those 0 ohm resistors are smd jumpers its just a short , but r7 is there by mistake .can jumper resistors interferewith spi?
Your Fuse values, as shown in q.png, Low 0xFF  High 0xDE  Extended 0x05 do not select the internal rc oscillator.  http://www.avrfreaks.net/sites/d...
Did you program the fuses to something other than what is shown?
...can jumper resistors interferewith spi?
Not the resistors but what is connected to WIFI_TXD?
And can we clear up EXACTLY what chip you are using? Your schematic says "ATMEGA328-PB" which is not a valid part number. What EXACTLY is written on the top of your chip?
i have not written fuse values that are displayed, the default fuses from factory are present.
its a wifi module , i think it may be
interfering
Oh, and C7 at 1uF is too large a value.
Read this...
Thanx for your time guys, the issue was the connection made to wifi module,
removed jumper resistors now i am getting correct signature of 328pb.
