SAMD21G18A SPI Help
8 posts / 0 new
Hello all, I'm trying to get an SAMD21G18A to write to an MCP4131 digipot. I tired the asf code example for SPI but it is not working. Where am I going wrong?
  * File:       Main.c
  * Author:     Armstrong Subero
  * Controller: SAMD21G18A w/INT OSC @ 48 MHz 3.3v
  * Program:    01_Pushbutton
  * Compiler:   ARM/GNU (v 5.3.1, Atmel Studio v7.0)
  * Program Version: 1.0
  *        * Added:
  *        * Issues:
  * Program Description: Turns on an LED when a pushbutton is pressed
  * Hardware Description: An LED is connected via a 1k resistor to PIN PA23 and a Pushbutton connected to PIN_PB23 10K pullup
  *   Created on November, 1st , 2016, 1:13 PM
*Includes and defines
// Atmel Software Framework
#include <asf.h>
#include <stdio.h>
#include <stdlib.h>
#define LED_0_PIN PIN_PA23
#define SW_0_PIN    PIN_PB23
#define SLAVE_SELECT_PIN PIN_PA16
struct spi_module spi_master_instance;
struct spi_slave_inst slave;
void configure_spi_master(void);
void digipot_write(uint8_t data);
 * Function: void config_pins(void)
 * Returns: Nothing
 * Description: Configures IO Pins
static void config_pins(void)
 // General Pin config
 struct port_config config_port_pin;
 port_get_config_defaults(&config_port_pin);
 // Pushbutton Config
 config_port_pin.direction  = PORT_PIN_DIR_INPUT;
 config_port_pin.input_pull = PORT_PIN_PULL_UP;
 port_pin_set_config(SW_0_PIN, &config_port_pin);
 // LED Config
 config_port_pin.direction = PORT_PIN_DIR_OUTPUT;
 port_pin_set_config(LED_0_PIN, &config_port_pin);
struct spi_config config_spi_master;
struct spi_slave_inst_config slave_dev_config;
/* Configure and initialize software device instance of peripheral slave */
spi_slave_inst_get_config_defaults(&slave_dev_config);
slave_dev_config.ss_pin = SLAVE_SELECT_PIN;
spi_attach_slave(&slave, &slave_dev_config);
/* Configure, initialize and enable SERCOM SPI module*/
config_spi_master.mux_setting = SPI_SIGNAL_MUX_SETTING_A;
config_spi_master.mode_specific.master.baudrate = 1000000;
config_spi_master.pinmux_pad0 = PINMUX_PA04D_SERCOM0_PAD0;
config_spi_master.pinmux_pad1 = PINMUX_PA05D_SERCOM0_PAD1;
config_spi_master.pinmux_pad2 = PINMUX_UNUSED;
config_spi_master.pinmux_pad3 = PINMUX_UNUSED;
spi_init(&spi_master_instance, SERCOM0, &config_spi_master);
spi_enable(&spi_master_instance);
uint8_t data2 = 0x00;
// set CS low
spi_select_slave(&spi_master_instance, &slave, false);
spi_write_buffer(&spi_master_instance, data2,1);
spi_write_buffer(&spi_master_instance, data,1);
// set CS high
spi_select_slave(&spi_master_instance, &slave, true);
 * Function: int main(void)
 * Returns: Nothing
 * Description: Initializations for main
system_init();
config_pins();
configure_spi_master();
while (true) {
digipot_write(100);
delay_ms(500);
return 0;
Asubero
// set CS low
The last arg to spi_select_slave is not about the logic level on the CS signal, you need 'true'  to select the slave.
/Lars
One could argue that it is - because the CS signal is active-low ...
I don't get that sorry, the program above would be ok if passing false resulted in a low level on CS.
/Lars
I mean that CS is active low; ie, the low level is the "true" (or "asserted") state for CS
Yeah the MCP4131 is active low..idk whats going on..I tried SPI with the ST7735 as well...my scope shows everything looking well..so I guess it has to be some obsure setting..I even tried lowering the baud rate...does anyone have verifyable working SPI code for the SAMD21?
Asubero
So you did change to use
to select the slave already? But I guess if everything looks ok on the scope the problem can't be the SAMD21 code.
/Lars
sigh..tried three different spi devices now...still not working...
Asubero
