hm-10 send and receive data and checking received value
6 posts / 0 new
Hey all i am wondering what is wrong with my code below. I have 2 issues.
First issue I am checking if c equals "hi" and if it does then display said hi. I currently see the output of c when it hits the Serial.println(c); but never see the said hi even though Serial.println(c); does say "said hi".
Second issue is that when i startup the arduino i am sending the AT command AT using bluetooth.println("AT"); // just a check but all it seems to do is display AT on the phone instead of OK as it should.
#include <SoftwareSerial.h>
SoftwareSerial bluetooth(8,9); // RX, TX
void setup() {
  // Open serial communications and wait for port to open:
  Serial.begin(9600);
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  Serial.println("PC Side Connected");
  bluetooth.begin(9600);
  while (!bluetooth) {
  bluetooth.println("Bluetooth Side Connected");
void loop() { // run over and over
  String c;
  if (bluetooth.available()) {
    //What is sent back from the BT module
    c = bluetooth.readStringUntil('\n');
    delay(10);
    Serial.println(c);
        if (c.equals('hi')) {
          Serial.println("said hi");
  if (Serial.available()) {
    //Send back data to Bluetooth module
    bluetooth.write(Serial.read());
Serial comm seems to be a lost art, you have to pay attention to details.
Such as
probably sends AT<cr><lf>, while the modem was expecting only AT<cr>  as the println adds /r/n to the quoted string!
Try
bluetooth.print("AT/r"); // just a check
as .print does not add any control characters to the output.
In a similar vain the received string may also contain additional characters, both leading and trailing, making the .equals. not match,
You will need to parse the received input to remove any extra white space and control characters before searching for a match!
Such as
Try
Hey jim thanks for the info.
I did a little test and this is what i came up with:
Notice the debug says "hi" yet it never does hit the IF "hi" which it should also say "it works!" under the debug! hi one.
What type is comString? Usually you'd compare strings with strcmp() not ==
+1
Try
You mean
bluetooth.print("AT\r"); // just a check
ie, a back-slash
elsewhere, (s)he's using stuff like
  String c;
and
  if ( c.equals('hi') ) {
