DIY JTAG for ATmega2560
14 posts / 0 new
I considering for a while to buy proper JTAG in order to use it for some 8-bits AVRs (in this case ATmega2560), however the price and trouble to order it do not approve it usefulness (occasional usage for debug purposes). The second issue is that I use Linux only and using Atmel Studio is out of question.
The first question is related to possibility to DIY  some simple and proper JTAG for the purpose.
The second is about proper free software on Linux. Reading somewhere that JTAG protocol for Atmel MCUs is closed is not very promising.
Thank in advance.
I have always found using the proper tool to do a job is much easier and gets the job done quicker.
You can use a jack knife (linux) to drive a nail (AVR), but a hammer (Windows) is the tool for the job.
YMMV
Of course, some people enjoy making jack knifes into hammers, and that is ok too! smiley
BTW, this is hobby for me, not a job.
Don’t use AVRs then. Maybe try the SAM series that are supported with openocd and are cheaper and faster. Entry level would be the SAMD21 that also has Arduino support and a variety of other tools under the three major operating systems.
I'm using 8-bit AVRs long time (7 years) and have many of them in prototypes and several still not used. And they are quite proper for the prototype purposes...
True, ARMs are much better than any AVR... I have considered for a while some NPX with default bootloader or some without internal programming memory, however, for now, I have no intention to move up as I have no time to read extensively ARM documentation - I would prefer to continue with AVR for a bit more.
Anyway, the topic requirement seems to be not possible or at least not cheap.
Thank you to both.
Totally agree with Kartman. I see three options for debugging "on the cheap"
1 follow that advice and use Cortex, not AVR. You can setup a complete debug system for a few $
2 consider AVR Xplained boards, all have an AVR on a board, some have a debugger (for that AVR) built in and the cheapest is about $10
3 go with one of the "original" AVR with JTAG (mega16, 32,64,128 etc). They can be debugged with a clone of the original JTAGICE that you can get on ebay for $5..$10
But you do have time to mess about with trying to make your own JTAG adaptor ?!
Even so, for any hobby you will have to make some outlay for "tools & materials"
http://www.avrfreaks.net/comment...
PS regarding option 3. If this is about "DIY" then you can build it not buy it. I seem to remember the design is based around a mega16 itself.
I see no point for such cynical comment.
Few hours in homemade PCB against few months in reading ARM documentations?
if proper DIY JTAG is possible to create, for me, choice is strait forward and more than obvious...
Thank you clawson, for JTAGICE clone suggestion, I will certainly look for it.
It's possible with an instance in
LuRa
HappyJTAG2
http://www.lura.sk/?&LP=111EN&MP=4&ML=3&PO=%27%27
for mega2651 (etc), Windows, and AVR Studio 4.
Hmmm...
If old AVR Studio can run on Linux through wine, suggested clones could be solution.
Even I'm not particularly happy to install wine, it is certainly worth to try.
Thank you to all.
You can use Eclipse+avr-gdb+avarice, no need for Studio+wine
Thank you.
