LCD 16X2 charcter
23 posts / 0 new
Hello people, im using an LCD 16x2 with atmega, and on the screen there is one charcter that wont be there, i dont know how to take off.
Anyone help?
I try using this code but doesnt resolve.
for (int k=0; k<=15; k++){ // data1 is my string to pring 16 charcter
     data1[k]=' ';
  sprintf(data1, "%d    Cm   %d",distancia, distancia2); //Print on data1 two vars and 'cm'
dis_data(data1[k]); _delay_us(800);
Remnants of the cursor? Have you tried to turn it off?
It could be a stored custom character, perhaps in cgram location 0, so prints if you send a null character!
Please post a link to where you got your LCD, or a link to its datasheet.
yeah, that's a null byte. Those LCDs use characters 0x00 through 0x07 as custom user-programmable characters and have defaults for them.
Hello, its an 16x2 with number 1602
datasheet https://www.openhacks.com/upload...
Im using with 4bit mode with this configuration:
dis_cmd(0x02); //LCD 4 bits
dis_cmd(0x2C); //define o LCD como um de 16x2 4bits
dis_cmd(0x06); // Increment cursor (shift cursor to right)
dis_cmd(0x80); // move cursor para o 1º point da 1ª line
thanks
Does it disappear if you turn down the contrast and/or the brightness pot?
Hello Jim,
No, do not disappear, and if a took off my FOR (   for (int k=0; k<=15; k++){    data1[k]=' ';}  )  all the position that havent anything to print stays with that symbol. and i saw in datasheet to use 0x01 on configuration to clean screen but if i add that the screen stay blinking 4ever.
Why are you sending character by character for 15 characters irrespective of strlen(data1).
A more "normal" string printing routine would print up to but not including the terminating NUL.
Im printing with ' ' to clear all LCD, if dont it stay this way:
I dont know why even with all position clear with FOR why still on2 charcter in the screen?
void dis_string(char * str) {
    while(*str) {
        dis_data(*str++);
Then
dis_string(data1);
Joao, when you do the following in your code, do you realize that the characters that follows the %d converted value of distancia2, '0' in this last case, is a null character.  You are printing the string that you want plus all of the characters that follow it including the null character and they are being displayed perfectly!  You need to only print the string itself and not the null characters as clawson indicated earlier and has shown in his code in the post above.
EDIT: post above
dis_data(data1[k]);
Im printing with ' ' to clear all LCD, ...
If I want to use sprintf() to format a line that will be put to an LCD during periodic update, I will let sprintf() take care of building the entire line, then output the entire line.  Example:
#define LCD_WIDTH 16
unsigned char line_buffer[LCD_WIDTH+a few];  //"a few" might be 5 or 6 .
sprintf (line_buffer, "%5u  Cm  %5u", distance1, distance2); // build at least the full line
line_buffer[LCD_WIDTH] = '\0'; // ensure no more than one line
... then position to the beginning of an LCD line, and output line_buffer as a strung up to terminating null
When I update an LCD, I print the data, plus fill the rest of the line with "space" characters to erase any previous data on the line.
I find this works better then doing a clear screen, as that will cause the screen to blink with each update, but does not if I clear any unused positions using a space "0x20" character.
I thought that was what the OP was doing, but it looks like he may be using null or at least not stopping at the null and continuing to fill the line with spaces.
Hello guys
I resolve the problem with this:
sprintf(data1, "%d           %d  ",distancia, distancia2);
data1[7] ='C';
data1[8] ='m';
data1[15] =' ';
Its not the best way to do but works fine, i ll keep studying how to do the other way.
Thanks to all
Did you even bother to read #10? You don't need some shonky solution, you need to do it properly.
I really try to use this, but the program dont do /0. Whene the string finish it start again until the lcd line its full. Like:    23    cm   1523 repeat 23.
#ifndef LCD_PRT
	#define LCD_DRT DDRA
	#define LCD_PRT PORTA
#endif
#ifndef	F_CPU
	#define F_CPU 14745600UL
#endif
#include <util/delay.h>
#define LCD_RS 0
#define LCD_RW 1
#define LCD_EN 2
class LCD
	public:
	LCD()
		init();
	void init()
		LCD_DRT=0xFF;
		LCD_PRT&=~(1<<LCD_EN);		//make EN=0
		_delay_ms(20);				//startup delay
		cmdSend(0x33);			//33 for 4 bit mode
		_delay_ms(2);
		cmdSend(0x32);			//32 for 4 bit mode
		_delay_ms(2);
		cmdSend(0x28);			//28 for 4 bit mode
		_delay_ms(2);
		cmdSend(0x0C);			//display on cursor off
		_delay_ms(2);
		clearDisplay();
		_delay_ms(2);
		print("Initialized...");
	void clearDisplay()
		cmdSend(0x01);
		_delay_ms(2);
	void dataSend(uint8_t data)
		LCD_PRT=(((data&0xF0)|(1<<LCD_EN)|(1<<LCD_RS))&~(1<<LCD_RW));	//msb data and control to 101
		_delay_us(100);
		LCD_PRT&=~(1<<LCD_EN);						//EN=0
		LCD_PRT=(LCD_PRT&0x0F)|(data<<4);			//shift lsb data
		LCD_PRT|=(1<<LCD_EN);						//make EN=1
		_delay_us(100);
		LCD_PRT&=~(1<<LCD_EN);						//EN=0 - job done
	void cmdSend(uint8_t cmd)
		LCD_PRT=((cmd&0xF0)|(1<<LCD_EN))&~(1<<LCD_RW)&~(1<<LCD_RS);	//msb cmd and control to 100
		_delay_us(100);
		_delay_us(100);
		LCD_PRT=(LCD_PRT&0x0F)|(cmd<<4);		//shift lsb cmd
		LCD_PRT|=(1<<LCD_EN);		//EN=1
		_delay_us(100);
	void print(char str[])
		clearDisplay();
		_delay_ms(1);
		for(int i=0;str[i]!='\0';i++)
			dataSend(str[i]);
Hope this helps...
pass a string like "                " to print()...
[EDIT] Also change clock according to yours...
Show's ON....
The way I display a string on a display is to have two routines.
The first just writes a single character to the display equivalent to your dis_data() function.
The second is a function to display a string similar to that shown by clawson in Post #10:
    while(*str) {
        dis_data(*str++);
then to call the display string function:
char data1[20];   // A buffer to hold the longest string to be generated (+1)
// ... other code ...
// Create the string as needed,
//   note spaces can be added at the end of the string to overwrite any previous text
sprintf(data1, "%d    Cm   %d  ",distancia, distancia2); // Fill data1 with two vars and 'cm'
// Now display the string
dis_string(data1);
David (aka frog_jr)
SOLVED
Intead of unsigned char data1[16];  put just   char data1[16];
 dis_string(data1);
Thanks ALL
Well, you should modify your displaying routine loop (should be put into a function, anyway, as you were hinted)  like that:
 #define LCDsIZE 16
for (int k=0; k < LCDsIZE ; k++){
 if (data1[k] == 0) break; // copes with null terminated strings
This might answer the \0 weird coding and warrants you wonot display more than 16 chars (your LCD display might become bigger or split else).
(using pointers as in 10 is more beautiful, but more difficult to read -ex : fortran users-, is not consistent with your way of writing,   and does not limit the number of chars displayed...)
Edited : looked at (I should have looked at it before...) : http://www.avrfreaks.net/forum/tutc-lcd-tutorial-1001?name=PNphpBB2&file=viewtopic&t=102296
Your delays are way too long (should be 50 -80 us...). Hope there are no other unpleasant things (correcting at random until something seems to work is not the best method)
Joao Pinto wrote:
SOLVED
 dis_string(data1);
Thanks ALL
That doesn't seem like it should matter. You'll still have a NUL at the end of the string. But if you added enough spaces that you're getting all 16 spots, then the nul will display off the end of the display. But also you'll potentially write past the end of your buffer. In the example you showed, you had a 1-digit and 3-digit number, so this would be a total of 15 characters, so the NUL should still be showing up, I'd expect. But also you shouldn't be using sprintf into a buffer that might not be large enough for some inputs.
snprintf(data1, sizeof(data1) , "....) can respect the size of the buffer and do the job with a negligeable increase of complexity....
Yes. snprintf is almost always a better choice.
