SAMD21 multiple PWM using ASF
7 posts / 0 new
Hello to all,
I'm trying to configure multiple PWM output using ASF. I need 8 PWM output.
I started using the basic TCC Callback example, modifying it to manage the 8 output, but I only get PWM one at a time, or two from pin with different TCC.
Is there a way to configure multiple PWM using ASF?
Many Thanks
Clemente
Yes it is possible but to get 8 outputs you will have to use all 3 TCC instances (it's the number of compare channels that is significant and they have 4, 2 and 2).
#include <asf.h>
static void configure_tcc(void);
struct tcc_module tcc_instance;
struct tcc_module tcc_instance1;
struct tcc_module tcc_instance2;
    struct tcc_config config_tcc;
    tcc_get_config_defaults(&config_tcc, TCC0);
    config_tcc.counter.period = 0x1FF;
    config_tcc.compare.wave_generation = TCC_WAVE_GENERATION_SINGLE_SLOPE_PWM;
    config_tcc.compare.match[0] = 0x23;
    config_tcc.compare.match[1] = 0x33;
    config_tcc.compare.match[2] = 0x43;
    config_tcc.compare.match[3] = 0x53;
    config_tcc.pins.enable_wave_out_pin[0] = true;
    config_tcc.pins.wave_out_pin[0]        = PIN_PA04E_TCC0_WO0;
    config_tcc.pins.wave_out_pin_mux[0]    = MUX_PA04E_TCC0_WO0;
    config_tcc.pins.enable_wave_out_pin[1] = true;
    config_tcc.pins.wave_out_pin[1]        = PIN_PA05E_TCC0_WO1;
    config_tcc.pins.wave_out_pin_mux[1]    = MUX_PA05E_TCC0_WO1;
    config_tcc.pins.enable_wave_out_pin[2] = true;
    config_tcc.pins.wave_out_pin[2]        = PIN_PA10F_TCC0_WO2;
    config_tcc.pins.wave_out_pin_mux[2]    = MUX_PA10F_TCC0_WO2;
    config_tcc.pins.enable_wave_out_pin[3] = true;
    config_tcc.pins.wave_out_pin[3]        = PIN_PA11F_TCC0_WO3;
    config_tcc.pins.wave_out_pin_mux[3]    = MUX_PA11F_TCC0_WO3;
    tcc_init(&tcc_instance, TCC0, &config_tcc);
    tcc_get_config_defaults(&config_tcc, TCC1);
    config_tcc.compare.match[0] = 0x63;
    config_tcc.compare.match[1] = 0x73;
    config_tcc.pins.wave_out_pin[0]        = PIN_PA06E_TCC1_WO0;
    config_tcc.pins.wave_out_pin_mux[0]    = MUX_PA06E_TCC1_WO0;
    config_tcc.pins.wave_out_pin[1]        = PIN_PA07E_TCC1_WO1;
    config_tcc.pins.wave_out_pin_mux[1]    = MUX_PA07E_TCC1_WO1;
    tcc_init(&tcc_instance1, TCC1, &config_tcc);
    tcc_get_config_defaults(&config_tcc, TCC2);
    config_tcc.compare.match[0] = 0x83;
    config_tcc.compare.match[1] = 0x93;
    config_tcc.pins.wave_out_pin[0]        = PIN_PA12E_TCC2_WO0;
    config_tcc.pins.wave_out_pin_mux[0]    = MUX_PA12E_TCC2_WO0;
    config_tcc.pins.wave_out_pin[1]        = PIN_PA13E_TCC2_WO1;
    config_tcc.pins.wave_out_pin_mux[1]    = MUX_PA13E_TCC2_WO1;
    tcc_init(&tcc_instance2, TCC2, &config_tcc);
    tcc_enable(&tcc_instance);
    tcc_enable(&tcc_instance1);
    tcc_enable(&tcc_instance2);
    system_init();
    configure_tcc();
    while(1);
/Lars
Hello Lajon,
many thanks for your responce.
/Lars
Ah! This was not clear to me. I have this pin assignement:
    PWM_OUT1 PA9  TCC1/WO[3]   CC1	0
    PWM_OUT2 PA8  TCC1/WO[2]   CC0	1
    PWM_OUT3 PA15 TCC0/WO[5]   CC1	2
    PWM_OUT4 PA20 TCC0/WO[6]** CC2	3
    PWM_OUT5 PA6  TCC1/WO[0]   CC0	4
    PWM_OUT6 PA7  TCC1/WO[1]   CC1	5
    PWM_OUT7 PB12 TCC0/WO[6]** CC2	6
    PWM_OUT8 PB13 TCC0/WO[7]   CC3	7
and if I undestand what you say, about the compare channel (4,2,2), I can't use four TCC1 channels concurrently.
I need to free 2 pins that route to TCC2, isn't it?
Thanks again for your time.
Clemente
Right, you need to use TCC2 also.
/Lars
Thanks Lars.
Lajon/Lars,
Have you used the code posted above ( Wed. Feb 15, 2017 - 11:40 PM ) to produce PWM Wave-forms on multiple channels on same TCCx simultaneously?
I am using similar code; but when I enable Channel 1, Channel 0 stops. I can have two simultaneous wave-forms from TCC0 and TCC1.
C. Dicaprio, Did you get 8 simultaneous outputs working?
Betta
Betta
Yes it works, I would not post the code if it did not work.
SAMD21 8 pwm from TCC0,TCC1 and TCC2
/Lars
