Can't flash MCU.
8 posts / 0 new
Hello I am trying to flash an atmega64. I accidentally tried to flash it when the debugging was still going on. I stopped debugging and now this the output when flashing.
avrdude.exe: warning: cannot set sck period. please check for usbasp firmware update.
avrdude.exe: AVR device initialized and ready to accept instructions
avrdude.exe: Device signature = 0x1e9602
avrdude.exe: NOTE: FLASH memory has been specified, an erase cycle will be performed
avrdude.exe: erasing chip
avrdude.exe: reading input file "Debug\.hex"
avrdude.exe: can't open input file Debug\.hex: No such file or directory
avrdude.exe: write to file 'Debug\.hex' failed
avrdude.exe: safemode: Fuses OK
avrdude.exe done.  Thank you.
Help!
Amateur programmer.
Believe when I tell you that my struggle on here is real.
Show the command line used, as this error is pretty clear!
It could not find the hex file with no name!
avrdude -c usbasp -p atmega64 -U flash:w:$(ProjectDir)Debug\$(TargetName).hex:i
Amateur programmer.
Jim, for some reason it has started working now. I have no clue how.
Amateur programmer.
The attempt to program flash while debugging, and the AVRDUDE failure probably are not related.
You need to actually read through the AVRDUDE output in detail and take note of everything. Read, s-l-o-w-l-y, stop, think. Take special note of this
A file with file path "Debug\.hex"? Something is obviously wrong there, right? E.g. there's no file name.
So, go back and inspect your command:
Isn't it obvious that two macros (or whatever Atmel Studio calls them) has expanded to empty strings? These: $(ProjectDir) and $(TargetName). If both of those expand to empty strings, you will get the file spec that can be seen in the error from AVRDUDE.
You need to tell us in what context of Atmel Studio you are using this.
E.g. do you have a project open in Atmel Studio when you run the AVRDUDE command?
EDIT: Resolved while I was thinking and typing the above.
I have added USBasp as a custom programming tool - by following certain steps that I came across a blog. Here's the link to my reference:https://blog.manash.me/setting-up-atmel-studio-for-usbasp-and-avr-programming-802bb4dcf1e9
I did not use that command in AVRdude. I m flashing the mcu using AS7. It worked well until the last time it stopped writing. I asked my colleague to try flashing on his computer and it did work. Following that, I flashed once again and bingo it's back. I do not know what may have caused that temporary halt in program flash.
Amateur programmer.
While the problem has been resolved...
I know that.
I was trying to point out that you could start drawing conclusions on what went wrong by looking at the details of the messages from AVRDUDE. And that if you wanted help with that we'd need to understand more.
The use of the "macros" $(ProjectDir) and $(TargetName) made it entirely clear already at your post #3 that you where using Atmel Studio, running AVRDUDE through a custom External Tool (that you or someone else has set up in your Studio).
Thanks Johan. :)
Amateur programmer.
