ASF is generating not good project
6 posts / 0 new
Hi all, as you can see in this video: https://www.facebook.com/roberto... ASF is not working well and generate a code with errors that i don't understand and you can easily replicate on your computer, can someone explain how to remove this issue?
Thank you in advance to who answer
Posting a link to a Facebook page wont get you very far.  I did look and the video is so poor I cannot make out any of the text.  I did see an Arduino board at one point, but thats about it.
Can you explain what your project is, and what you were trying to do with ASF>  THat would be a big help
JIm
There is no magic thing that makes us see what you're seeing. If you want help diagnosing the problem you need to give us the facts. These, for a start:
1. Tell us, in detail, how you generated the project.
2. ZIP up the complete project directory tree and attach it to a post here.
3. Report version of ASF used.
4. Report version of Studio used.
5. Report version of avr-gcc used.
6. Show complete output of your failed build. After the build, switch to the Output tab, mark everything, copy it and paste into a post here.
Ok, I state about this error that I found it on two different computers, the second attempt I did on a very clean installation after 20 minutes from the installation.
In the attachement the files of project,
asf version is: 3.35.1.898 , in the attachement the picture
atmel studio is version 7, picture too
i don't know how to see the version of avr-gcc but and as I tell i make a new installation from sckratch
this is the request output:
------ Build started: Project: GccApplication3, Configuration: Debug ARM ------
Build started.
Project "GccApplication3.cproj" (default targets):
Target "PreBuildEvent" skipped, due to false condition; ('$(PreBuildEvent)'!='') was evaluated as (''!='').
Target "CoreBuild" in file "C:\Program Files (x86)\Atmel\Studio\7.0\Vs\Compiler.targets" from project "C:\Users\rob77\Documents\Atmel Studio\7.0\GccApplication3\GccApplication3\GccApplication3.cproj" (target "Build" depends on it):
    Task "RunCompilerTask"
        Shell Utils Path C:\Program Files (x86)\Atmel\Studio\7.0\shellUtils
        C:\Program Files (x86)\Atmel\Studio\7.0\shellUtils\make.exe all --jobs 8 --output-sync
        Building file: ../src/ASF/sam/utils/cmsis/sam3x/source/templates/system_sam3x.c
        Invoking: ARM/GNU C Compiler : 6.3.1
        In file included from C:\Program Files (x86)\Atmel\Studio\7.0\Packs\arm\cmsis\5.0.1\CMSIS\Include/cmsis_compiler.h:48:0,
                         from C:\Program Files (x86)\Atmel\Studio\7.0\Packs\arm\cmsis\5.0.1\CMSIS\Include/core_cm3.h:113,
                         from C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\SAM3X_DFP\1.0.51\include/sam3x8e.h:253,
                         from C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\SAM3X_DFP\1.0.51\include/sam3xa.h:44,
                         from ../src/ASF/sam/utils/header_files/io.h:75,
                         from ../src/ASF/sam/utils/compiler.h:67,
                         from ../src/ASF/sam/utils/cmsis/sam3x/source/templates/system_sam3x.h:60,
                         from ../src/ASF/sam/utils/cmsis/sam3x/source/templates/system_sam3x.c:48:
C:\Program Files (x86)\Atmel\Studio\7.0\Packs\arm\cmsis\5.0.1\CMSIS\Include\cmsis_gcc.h(1350,6): warning: "__ARM_FEATURE_DSP" is not defined [-Wundef]
        "C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\arm\arm-gnu-toolchain\bin\arm-none-eabi-gcc.exe"  -x c -mthumb -D__SAM3X8E__ -DDEBUG -DBOARD=ARDUINO_DUE_X -Dscanf=iscanf -DARM_MATH_CM3=true -Dprintf=iprintf -D__SAM3X8E__  -I"C:\Program Files (x86)\Atmel\Studio\7.0\Packs\arm\cmsis\5.0.1\CMSIS\Include" -I"C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\SAM3X_DFP\1.0.51\include" -I"../src/ASF/common/boards" -I"../src/ASF/sam/utils" -I"../src/ASF/sam/utils/header_files" -I"../src/ASF/sam/utils/preprocessor" -I"../src/ASF/thirdparty/CMSIS/Include" -I"../src/ASF/thirdparty/CMSIS/Lib/GCC" -I"../src/ASF/common/utils" -I"../src/ASF/sam/utils/cmsis/sam3x/source/templates" -I"../src/ASF/sam/utils/cmsis/sam3x/include" -I"../src/ASF/sam/boards" -I"../src/ASF/sam/boards/arduino_due_x" -I"../src/ASF/common/services/gpio" -I"../src/ASF/sam/drivers/pio" -I"../src/ASF/common/services/ioport" -I"../src/ASF/common/services/clock" -I"../src/ASF/sam/drivers/pmc" -I"../src" -I"../src/config"  -O1 -fdata-sections -ffunction-sections -mlong-calls -g3 -Wall -mcpu=cortex-m3 -c -pipe -fno-strict-aliasing -Wall -Wstrict-prototypes -Wmissing-prototypes -Werror-implicit-function-declaration -Wpointer-arith -std=gnu99 -ffunction-sections -fdata-sections -Wchar-subscripts -Wcomment -Wformat=2 -Wimplicit-int -Wmain -Wparentheses -Wsequence-point -Wreturn-type -Wswitch -Wtrigraphs -Wunused -Wuninitialized -Wunknown-pragmas -Wfloat-equal -Wundef -Wshadow -Wbad-function-cast -Wwrite-strings -Wsign-compare -Waggregate-return  -Wmissing-declarations -Wformat -Wmissing-format-attribute -Wno-deprecated-declarations -Wpacked -Wredundant-decls -Wnested-externs -Wlong-long -Wunreachable-code -Wcast-align --param max-inline-insns-single=500 -MD -MP -MF "src/ASF/sam/utils/cmsis/sam3x/source/templates/system_sam3x.d" -MT"src/ASF/sam/utils/cmsis/sam3x/source/templates/system_sam3x.d" -MT"src/ASF/sam/utils/cmsis/sam3x/source/templates/system_sam3x.o"   -o "src/ASF/sam/utils/cmsis/sam3x/source/templates/system_sam3x.o" "../src/ASF/sam/utils/cmsis/sam3x/source/templates/system_sam3x.c"
C:\Users\rob77\Documents\Atmel Studio\7.0\GccApplication3\GccApplication3\Debug\Makefile(262,1): error: recipe for target 'src/ASF/sam/utils/cmsis/sam3x/source/templates/system_sam3x.o' failed
         #if (__ARM_FEATURE_DSP == 1)                             /* ToDo ARMCLANG: This should be ARCH >= ARMv7-M + SIMD */
        In file included from ../src/ASF/sam/utils/cmsis/sam3x/source/templates/system_sam3x.c:48:0:
C:\Users\rob77\Documents\Atmel Studio\7.0\GccApplication3\GccApplication3\src\ASF\sam\utils\cmsis\sam3x\source\templates\system_sam3x.h(62,17): warning: redundant redeclaration of 'SystemCoreClock' [-Wredundant-decls]
         extern uint32_t SystemCoreClock; /* System Clock Frequency (Core Clock) */
        In file included from C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\SAM3X_DFP\1.0.51\include/sam3x8e.h:255:0,
C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\SAM3X_DFP\1.0.51\include\system_sam3xa.h(43,17): info: previous declaration of 'SystemCoreClock' was here
C:\Users\rob77\Documents\Atmel Studio\7.0\GccApplication3\GccApplication3\src\ASF\sam\utils\cmsis\sam3x\source\templates\system_sam3x.h(68,6): warning: redundant redeclaration of 'SystemInit' [-Wredundant-decls]
         void SystemInit(void);
C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\SAM3X_DFP\1.0.51\include\system_sam3xa.h(49,6): info: previous declaration of 'SystemInit' was here
C:\Users\rob77\Documents\Atmel Studio\7.0\GccApplication3\GccApplication3\src\ASF\sam\utils\cmsis\sam3x\source\templates\system_sam3x.h(74,6): warning: redundant redeclaration of 'SystemCoreClockUpdate' [-Wredundant-decls]
         void SystemCoreClockUpdate(void);
C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\SAM3X_DFP\1.0.51\include\system_sam3xa.h(55,6): info: previous declaration of 'SystemCoreClockUpdate' was here
C:\Users\rob77\Documents\Atmel Studio\7.0\GccApplication3\GccApplication3\src\ASF\sam\utils\cmsis\sam3x\source\templates\system_sam3x.h(79,6): warning: redundant redeclaration of 'system_init_flash' [-Wredundant-decls]
         void system_init_flash(uint32_t ul_clk);
C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\SAM3X_DFP\1.0.51\include\system_sam3xa.h(60,6): info: previous declaration of 'system_init_flash' was here
         void system_init_flash(uint32_t dw_clk);
        ../src/ASF/sam/utils/cmsis/sam3x/source/templates/system_sam3x.c: In function 'SystemInit':
C:\Users\rob77\Documents\Atmel Studio\7.0\GccApplication3\GccApplication3\src\ASF\sam\utils\cmsis\sam3x\source\templates\system_sam3x.c(70,32): error: implicit declaration of function 'CKGR_MOR_KEY' [-Werror=implicit-function-declaration]
         #define SYS_CKGR_MOR_KEY_VALUE CKGR_MOR_KEY(0x37) /* Key to unlock MOR register */
C:\Users\rob77\Documents\Atmel Studio\7.0\GccApplication3\GccApplication3\src\ASF\sam\utils\cmsis\sam3x\source\templates\system_sam3x.c(89,19): info: in expansion of macro 'SYS_CKGR_MOR_KEY_VALUE'
           PMC->CKGR_MOR = SYS_CKGR_MOR_KEY_VALUE | SYS_BOARD_OSCOUNT |
C:\Users\rob77\Documents\Atmel Studio\7.0\GccApplication3\GccApplication3\src\ASF\sam\utils\cmsis\sam3x\source\templates\system_sam3x.c(89,3): warning: nested extern declaration of 'CKGR_MOR_KEY' [-Wnested-externs]
        ../src/ASF/sam/utils/cmsis/sam3x/source/templates/system_sam3x.c: In function 'system_init_flash':
C:\Users\rob77\Documents\Atmel Studio\7.0\GccApplication3\GccApplication3\src\ASF\sam\utils\cmsis\sam3x\source\templates\system_sam3x.c(214,22): error: 'CHIP_FREQ_FWS_4' undeclared (first use in this function)
          } else if (ul_clk < CHIP_FREQ_FWS_4) {
C:\Users\rob77\Documents\Atmel Studio\7.0\GccApplication3\GccApplication3\src\ASF\sam\utils\cmsis\sam3x\source\templates\system_sam3x.c(214,22): info: each undeclared identifier is reported only once for each function it appears in
        cc1.exe: some warnings being treated as errors
        make: *** [src/ASF/sam/utils/cmsis/sam3x/source/templates/system_sam3x.o] Error 1
    Done executing task "RunCompilerTask" -- FAILED.
Done building target "CoreBuild" in project "GccApplication3.cproj" -- FAILED.
Done building project "GccApplication3.cproj" -- FAILED.
Build FAILED.
========== Build: 0 succeeded or up-to-date, 1 failed, 0 skipped ==========
i forgot to answer how i generate the project,
I start to file/new project then I select  GCC C Executable Project then clik ok
At the new window i select Device Family SAM3X and in the lillte window i select AtSAM3X8E (Arduino Due is equipped with this microcontroller)
then click OK and is generated a new project, if I try to compile this empty project is all well, then form menu ASF/ASF WIZARD appear this
I click ok and select arduino due and click Next
then i confirm clicking finish on this:
and read this warning and click apply:
so I removed the first main file generated in order to remain only the one generated by the ASF and recompile, and i try to merge the include and the routines of the removed main file in the new file but mthin change.
I hope this is sufficient to understando what is happening
 i read from the output that the compiler is an ARM/GNU C Compiler : 6.3.1
