#defines show up as unidentified during debug.
9 posts / 0 new
Simalr problem all of my #defines show up as unidentified during debug. How can I fix that? Use constants?
A define can never be seen during debugging. A #define is NOT similar to a variable. Defines are handled by the C preprocessor that runs before the compiler proper sees the source code. And it is a matter of simple text substitution in trhe source.
Suppose you had this source snippet:
#define FOO 42
  PORTD = FOO;
After preprocessing, tis is what will be left for the compiler to see:
PORTD = 42;
And since it is the compiler that produces the debugging information it can not produce any information about the define. It never even knew it existed.
mikey1 wrote:
Use constants?
That might help, but if the compiler decides to optimize it away then you're into the same fix again. Similar effects as above but because of a totally different phenomenon. You have
const uint8_t bar = 7;
PORTD = bar;
The optimizer of the compiler sees that the variable is actually only used as a temporary storage for a value, and decides it can replace this with the simpler
PORTD = 7;
Again, thee variable won't be visible in a debugger. If you're lucky you'll get the reason reported. In some cases Atmel Studio will actually say "optimized away" or some such.
Best bet: Make it a volatile initialized variable.
volatile uint8_t baz = 99;
But now you're consuming RAM that you didn't in the variants above. No free lunch..
mikey1 wrote:
Simalr problem .
Not really:
Hence this isn't really related to the 5-year-old thread http://www.avrfreaks.net/forum/atmel-studio-6-watch-unknown-identifier
Another option would be to use an enum - as this is seen by the compiler and can be included in debug info (though not all compilers do).
You sure about that? As you'll know, in C++ it's more usual to use "static const int", "static const uint8_t" etc for numeric constants than #define in the pre-pro. I'm pretty sure visual studio will show you the values of such static const variables even if they are ultimately optimised away (as you would hope).
As you can see it's happy to show me "width" in the debugger even though it's "static const int".
I just checked that for both Debug and Release. Of course this is MSVC, the Microsoft compiler and their debugger but I think behaviour will be the same in AS7.
It's possible for the preprocessor to generate the information for a #define to show up in the debugger.
I've never heard of it happening.
enums are always seen by the compiler proper.
They are much more likely to be known to the debugger.
What debugging information the
compiler emits was determined by its authors.
What information the debugger
understands was determined by  its authors.
International Theophysical Year seems to have been forgotten..
Anyone remember the song Jukebox Band?
skeeve wrote:
It's possible for the preprocessor to generate the information for a #define to show up in the debugger. I've never heard of it happening.
I'm pretty sure Morten said that they do that and presumably the intention is to use/display the info at some point.
I'm pretty sure I have seen it happen - maybe not in Atmel Studio / GCC, though.
But I might be confused by enums ...
ISTR that Keil's C51 debugger, when it saw a magic number for which it had no symbol information, would just use the first #define it found which matched that magic number!
This, of course, produced nonsense a lot of the time!!
The GNU debugger does that too!
Hence:
C:\SysGCC\avr\bin>type avr.c
int main(void) {
        while(1);
C:\SysGCC\avr\bin>avr-gcc -mmcu=attiny13 -Os avr.c -o avr.elf
C:\SysGCC\avr\bin>avr-objdump -S avr.elf
avr.elf:     file format elf32-avr
Disassembly of section .text:
00000000 <__vectors>:
   0:   09 c0           rjmp    .+18            ; 0x14 <__ctors_end>
   2:   0e c0           rjmp    .+28            ; 0x20 <__bad_interrupt>
   4:   0d c0           rjmp    .+26            ; 0x20 <__bad_interrupt>
   6:   0c c0           rjmp    .+24            ; 0x20 <__bad_interrupt>
   8:   0b c0           rjmp    .+22            ; 0x20 <__bad_interrupt>
   a:   0a c0           rjmp    .+20            ; 0x20 <__bad_interrupt>
   c:   09 c0           rjmp    .+18            ; 0x20 <__bad_interrupt>
   e:   08 c0           rjmp    .+16            ; 0x20 <__bad_interrupt>
  10:   07 c0           rjmp    .+14            ; 0x20 <__bad_interrupt>
  12:   06 c0           rjmp    .+12            ; 0x20 <__bad_interrupt>
00000014 <__ctors_end>:
  14:   11 24           eor     r1, r1
  16:   1f be           out     0x3f, r1        ; 63
  18:   cf e9           ldi     r28, 0x9F       ; 159
  1a:   cd bf           out     0x3d, r28       ; 61
  1c:   02 d0           rcall   .+4             ; 0x22 <main>
  1e:   02 c0           rjmp    .+4             ; 0x24 <_exit>
00000020 <__bad_interrupt>:
  20:   ef cf           rjmp    .-34            ; 0x0 <__vectors>
00000022 <main>:
  22:   ff cf           rjmp    .-2             ; 0x22 <main>
00000024 <_exit>:
  24:   f8 94           cli
00000026 <__stop_program>:
  26:   ff cf           rjmp    .-2             ; 0x26 <__stop_program>
"ctors"? In a C program ?
As it happens the generic linker scripts caters for C and C++ with:
    /* For future tablejump instruction arrays for 3 byte pc devices.
       We don't relax jump/call instructions within these sections.  */
    *(.jumptables)
     *(.jumptables*)
    /* For code that needs to reside in the lower 128k progmem.  */
    *(.lowtext)
     *(.lowtext*)
     __ctors_start = . ;
     *(.ctors)
     __ctors_end = . ;
     __dtors_start = . ;
     *(.dtors)
     __dtors_end = . ;
    KEEP(SORT(*)(.ctors))
    KEEP(SORT(*)(.dtors))
    /* From this point on, we don't bother about wether the insns are
       below or above the 16 bits boundary.  */
    *(.init0)  /* Start here after reset.  */
    KEEP (*(.init0))
    *(.init1)
    KEEP (*(.init1))
    *(.init2)  /* Clear __zero_reg__, set up stack pointer.  */
    KEEP (*(.init2))
    *(.init3)
    KEEP (*(.init3))
    *(.init4)  /* Initialize data and BSS.  */
    KEEP (*(.init4))
    *(.init5)
    KEEP (*(.init5))
    *(.init6)  /* C++ constructors.  */
    KEEP (*(.init6))
    *(.init7)
    KEEP (*(.init7))
    *(.init8)
    KEEP (*(.init8))
    *(.init9)  /* Call main().  */
    KEEP (*(.init9))
    *(.text)
    . = ALIGN(2);
     *(.text.*)
The code at:
is actually part of:
    KEEP (*(.init2))
but before that are defined:
     __ctors_start = . ;
     __ctors_end = . ;
     __dtors_start = . ;
     __dtors_end = . ;
and as none of them has any associated code they also happen to label the first thing that comes along that does provide code and the disassembler just takes the first of them and emits that in the Asm listing.
One slight mystery here is that the .map file actually shows:
 *(.vectors)
 *(.progmem.gcc*)
                0x00000014                . = ALIGN (0x2)
                0x00000014                __trampolines_start = .
 *(.trampolines)
 .trampolines   0x00000014        0x0 linker stubs
 *(.trampolines*)
                0x00000014                __trampolines_end = .
 *(.progmem*)
 *(.jumptables)
 *(.jumptables*)
 *(.lowtext)
 *(.lowtext*)
                0x00000014                __ctors_start = .
 *(.ctors)
                0x00000014                __ctors_end = .
                0x00000014                __dtors_start = .
 *(.dtors)
                0x00000014                __dtors_end = .
 SORT(*)(.ctors)
 SORT(*)(.dtors)
 *(.init0)
 .init0         0x00000014        0x0 c:/sysgcc/avr/bin/../lib/gcc/avr/5.3.0/../../../../avr/lib/avr25/tiny-stack/crtattiny13.o
                0x00000014                __init
 *(.init0)
 *(.init1)
 *(.init1)
 *(.init2)
 .init2         0x00000014        0x8 c:/sysgcc/avr/bin/../lib/gcc/avr/5.3.0/../../../../avr/lib/avr25/tiny-stack/crtattiny13.o
All of those things are at address 0x0014 so I guess the big question is why the disasm labelled it as "__ctors_end" and not "__trampolines_start" which is actually the first thing defined for 0x0014. I'm guessing that it knows:
                0x00000014                __init
but it then holds these in alpha-order so:
                0x00000014                __init
and therefore __ctors_end is the first one. Obviously the disassembly would have made more sense if "__init" had been used.
In the .map file one also sees:
                0x00000020                __vector_1
                0x00000020                __bad_interrupt
                0x00000020                __vector_6
                0x00000020                __vector_3
                0x00000020                __vector_7
                0x00000020                __vector_5
                0x00000020                __vector_4
                0x00000020                __vector_9
                0x00000020                __vector_2
                0x00000020                __vector_8
So all those symbols have the value 0x0020 but when the disassembler disassembled the code it used:
which is again the first one if all the symbols with value 0x0020 are in alpha order.
Thanks all for the education - I now have some more arrows in my quiver
