Problem with HCSR04 ultrasonic sensor
20 posts / 0 new
Hi! This is my first post here. Im doing a project and im using a atmega324p and therefore a hcsr04. The problem is: this doesn't work(every port is well connected, and the atmega and hcsr04 have a 5v supply). I don't why. Can you help me? Thanks in advance.
#include <avr/interrupt.h>
#include <util/delay.h>
#define F_CPU 16000000L
volatile int pulse = 0;
volatile int dist = 0;
ISR(INT0_vect)
	if (0<<PIND2)
	{ // se int0 tiver LOW, começa o timer.
		TCCR1B|=(0<<CS10)|(1<<CS11)|(0<<CS12); //presclaer 8, 16000000/8=2MHz =5us //// o mais proximo de 10 us
	if (1<<PIND2)
		pulse=TCNT1;
		TCCR1B|=(0<<CS10)|(0<<CS11)|(0<<CS12); //STOP timer
		TCNT1=0;
void init()
	DDRB |= (1<<PB0); // led -> PB0 OUTPUT
	DDRD |= (0<<PD2)|(1<<PD0); // echo -> PD2 intput // trig -> PD0 OUTPUT
	EIMSK|=(1<<INT0);
	EICRA|=(1<<ISC01)|(0<<ISC00);
	TCCR1A |= 0;
	sei();
	init();
		PORTD|=(0<<PD0);
		PORTD|=(1<<PD0);
		_delay_us(10);
		PORTD|=(0<<PD0);
		dist = pulse/58;
		if (dist<=10) {
			PORTB|=(1<<PB0);
nguterresn
I believe that your if statements are wrong in the INT0 interrupt.
Try:  if ( (PIND & (1<<PIND2)) == FALSE) {  do this if pin D2 is 0 }  else { do this if Pin D2 is 1 }
With the HCSR04 proximity sensor, you send the 10uS trigger pulse.  Then wait until the Echo line goes active (high, if I remember correctly).  Then time how long that it stays high.  When it goes low, apply the distance formula according to the length of the Echo pulse.
Indeed they are!
NGUTERRESN wrote:
	if (0<<PIND2)
and
	if (1<<PIND2)
PIND2 is a constant - it just tells you the position of the bit within the PIND register.
How have you proved that your chip is running at 16MHz?
NGUTERRESN wrote:
		PORTD|=(0<<PD0);
		PORTD|=(1<<PD0);
		_delay_us(10);
		PORTD|=(0<<PD0);
That code doesn't do what you think it does. ORing a value with 0 will leave ti set to 1 if it was already was set. It does not clear it to 0.
Thanks everyone for the quick answer.
First:
Brian Fairchild wrote:
 this is proved, I have a crystal and the fuses are set.
NGUTERRESN wrote:
		PORTD|=(0<<PD0);
		PORTD|=(1<<PD0);
		_delay_us(10);
		PORTD|=(0<<PD0);
This is the code that is meant to send the trig pulse of 40khz. I have seen it in the oscilloscope and it seems fine.
nguterresn
And I made some changes on what you said its wrong:
ISR(INT0_vect)
	if ((PIND & (1<<PIND2)) == 0)
	if ((PIND & (1<<PIND2)) == 1)
		pulse=TCNT1;
		TCNT1=0;
void init()
	EIMSK|=(1<<INT0);
	TCCR1A |= 0;
	sei();
	init();
		PORTD &= ~(1<<PD0);
		PORTD |= (1<<PD0);
		_delay_us(10);
		PORTD &= ~(1<<PD0);
		dist = pulse/58;
		if (dist<=10) {
			PORTB|=(0<<PB0);
nguterresn
But still.. This doesn't work.
nguterresn
Looking at last code line of message #8, If you get a signal out, then something else is wrong, because
PORTD|=(0<<PD0);
DOES NOT clear pin D0! If you OR 0 with anything, there is exactly no change. But, worse, (0<<PD0) does nothing itseslf. It takes a byte that  starts out as 0b00000000 and sort of makes the least bit 0. So, what do you have? 0b00000000! No change. Then you OR PORTD with 0b00000000 and, guess what? No change!
The only statement in all that, that does anything, is:
PORTD|=(1<<PD0);
If you are getting a signal out, it may just run through your program, reset, and start over. I recommend that you rethink your code snippet, above.
PORTD|=(0<<PD0);
PORTD|=(1<<PD0);
You are correct, but in message #8 I do not define
PORTD|=(0<<PD0);
Already changed that to:
PORTD &= ~(1<<PD0);
nguterresn
Pardon, wrong port, but the argument is the same. Your last lines have:
if (dist<=10) {
       PORTB|=(0<<PB0);
That does exactly nothing.
Have you changed this one as well?
if (dist<=10) {
	PORTB|=(0<<PB0);
Greg Muth
Portland, OR, US
#define F_CPU 16000000UL
ISR(INT0_vect)
	pulse = TCNT1;
	TCCR1B |= (0<<CS10)|(0<<CS11)|(0<<CS12);	//STOP timer
	dist = pulse/58;
	if (dist<=10)
		PORTB |= (1<<PB0);
		TCNT1 = 0;
		dist=0;					//Liga o led se for <= 10cm
		PORTB &=~(1<<PB0);
		TCNT1 = 0;
		dist=0;						//Desliga o LED se não for
void init()
	EIMSK |= (1<<INT0);									//Define que se vai utilizar a interrupção INT0
	EICRA |= (0<<ISC01)|(1<<ISC00);						//Falling edge gera uma interrupção
	TCCR1A |= 0;										//Modo normal
	sei();
	init();
		PORTD |= (1<<PD0);
		TCCR1B |= (0<<CS10)|(1<<CS11)|(0<<CS12);
		_delay_us(10);
		PORTD &= ~(1<<PD0);
Now the Led on the PB0 answers to the sensor values. BUT, it blinks too much. I don't know if is noise or the code is just wrong.
nguterresn
So change your program a bit.
In the Main Loop:
Turn LED on for 1/10 Sec
Turn LED off
Send a Ping
Do the distance calculation
Turn the LED on, if the distance is < X cm
Delay 1 sec to see the LED
Turn off the led
delay 1 sec, all leds are off
Loop
Now there is a brief flash once every 2 seconds, when you send a ping
And the LED turns on for a second, if the distance is < 10 cm
And there is a delay with everything off before the cycle repeats.
As you said, I made some changes in the interrupt. But, this doesn't work. Led only blinks.
Could it be that the TCNT1 doesn't have enough time to be correct?
the code:
ISR(INT0_vect)
	pulse = TCNT1/2;
	dist = pulse/58;
	PORTB &= ~(0<<PB0);
	if (dist<=10)
		PORTB |= (1<<PB0);
		_delay_ms(10);
		TCNT1 = 0;
		dist=0;
		PORTB &=~(1<<PB0);
		_delay_ms(100);
		TCNT1 = 0;
		dist=0;
void init()
	sei();
	init();
		PORTD |= (1<<PD0);
		_delay_us(10);
		PORTD &= ~(1<<PD0);
nguterresn
You still need to write a simple test program to blink the LED at one flash per second, to prove (verify) that the clock is running at the expected speed.
If the clock is wrong, then all of the timing calculations will be wrong.
Pseudocode:
Configure I/O pin for output
Do:
  Turn on led
  wait 500 msec
  Turn off led
  wait 500 msec
Loop
This verifies that the correct clock source is being used, (the osc using the external crystal), AND that any divide by 8 or other such setting is not altering the clock frequency.
Do this and report back.
Put this statement first . . .
In consideration of others, please RTFM!
volatile float dist = 0;
void update_led();
ISR(INT0_vect)
	pulse = TCNT1;
	TCNT1 = 0;
void init()
	EICRA |= (1<<ISC01)|(0<<ISC00);
	sei();
int main()
	init();
	TCCR1B |= (1<<CS10)|(0<<CS11)|(0<<CS12);
		PORTD |= (1<<PD0);
		_delay_us(10);
		PORTD &= (0<<PD0);
		update_led();
void update_led(){
	dist = (pulse/58)/2;
	if (dist<=10)
			PORTB |=(1<<PB0);
	{		PORTB &= (0<<PB0);
I've made these changes...
Now the led is ON when dist <= X. And it's X, because it's not really 10 cm as it says in the code(maybe 20cm). The problem now is: even if I change the X value (10cm in the code), it doesn't matter. The led still turns on when dist <= 20 cm.
nguterresn
It appears you zero the count when you receive the echo and there is no synchronization between sending the pulse and receiving the pulse...
Back in Post #15 DocJC gave a good outline of how to accomplish what you are doing.
The only thing I would add is where DocJC said "Send a Ping" I would change to "Start a Ping, Zero the Ping Timer, delay and Stop the Ping"
David (aka frog_jr)
