Timer1 Question
9 posts / 0 new
I can't seem to get my timer1 to enable on compare match to drive two motors. One at PD5 and one on PD6. It is driving me crazy. Please help.
ISR(TIMER1_COMPA_vect)
PORTD ^= (1<<PIND5);
ISR(TIMER1_COMPB_vect)
PORTD ^= (1<<PIND6);
// All initializations
void initialize_all()
sei();
DDRD = 0b11110100; //set the output pins to control the motors
DDRB = 0b00100001; //more motor control
PORTB = !(1<<PINB5); //onboard led off
PORTD |= (1<<PIND2); // SPIN FORWARD
PORTB |= (1<<PINB0); //SPIN FORWARD
TCCR1A = (1<<COM1A1) | (1 << COM1B1) | (1 << WGM13) | (0 << WGM12) | (0 << WGM11);
TCCR1B = (1 << WGM13) | (1 << WGM12) | (0 << CS11);
TCNT1 = 20000;
ICR1 = 20000;
OCR1A = 10000;
OCR1B = 10000;
TIMSK1 |= (1<<OCIE1A);
TIMSK1 |= (1<<OCIE1B);
The way you have it set up, it will toggle a port pin once every timer cycle, and that will give you a fixed 50% duty cycle square wave at 1/2 of the timer's overflow frequency.
Assuming that you REALLY want PWM, use the hardware capability to set a port pin on overflow and clear it on compare. You do not  even need interrupts to do that. Hardware takes care of all of it for you. That MIGHT not be  on the pins you have chosen.
By the way, the EASY way to toggle a port pin by software is to do PIND |= (1<<PIND5); or similar. Setting a bit in the PIN register of a port will toggle it with newer AVRs (say, approximately Mega328 or newer).
Moving. Nothing to do with Studio.
Thanks Jim, So im pretty new to this. How is using the hardware different from using the timer the way I have set up?
Just a caution:
I suggest that you get in the habit of NOT enabling interrupts (sei) until all of your initializations are complete.
Eventually, you may run into a situation that the interrupts occur before you are totally ready for them...
In this particular (simple) case, it is not necessary...
David (aka frog_jr)
How to properly post source code: http://www.avrfreaks.net/comment...
#define F_CPU 16000000UL
#include <util/delay.h>
#include <avr/pgmspace.h>
#include <inttypes.h>
#include <string.h>
#include "uart.h"
#include "lcd_lib.h"
#include <asf.h>
#include <avr/interrupt.h>
#include <ctype.h>
#include <stdio.h>
#include <time.h>
#include <stdio.h>
#include <avr/sleep.h>
#include <math.h>
#include <avr/wdt.h>
#include <avr/eeprom.h>
volatile uint16_t dutyCycleA;
volatile uint16_t dutyCycleB;
volatile uint16_t freqCycle;
// ADC variables
volatile unsigned int Ain;
volatile int AinLow;
volatile int voltageLeft;
volatile int voltageCenter;
volatile int voltageRight;
volatile float Voltage;
char VoltageBuffer[10];
uint8_t data;
volatile int sensorL = 0;
volatile int sensorC = 0;
volatile int sensorR = 0;
volatile int lapCounter = 0;
#define ON 1
#define OFF 0
char lcdBuffer[17]; // LCD display buffer
// File stream for UART. Used for Transmission to demonstrate the fprintf function.
//FILE uart_str = FDEV_SETUP_STREAM(uart_putchar, uart_getchar, _FDEV_SETUP_RW);
void convertADC()
	// Convert A to D
	ADCSRA |= (1<<ADSC);
	// Wait until this conversion is completed
	while((ADCSRA & (1<<ADSC)));
void readSensors()
	ADMUX = 0b10000010;
	convertADC();
	Ain = (1<<ADCL); // First read lower byte
	Ain |= (ADCH<<8); // Then read upper byte
	voltageLeft = Ain;
	if (voltageLeft >= 769) sensorL = ON;
	if (voltageLeft < 769) sensorL = OFF;
	ADMUX = 0b10000011;
	convertADC();
	voltageCenter = Ain;
	if (voltageCenter >= 769) sensorC = ON;
	if (voltageCenter < 769) sensorC = OFF;
	ADMUX = 0b10000110;
	convertADC();
	voltageRight = Ain;
	if (voltageRight >= 769) sensorR = ON;
	if (voltageRight < 769) sensorR = OFF;
void printSensorValues()
	dtostrf(voltageLeft, 3, 0, lcdBuffer);
	printf(lcdBuffer);
	printf(" \n");
	dtostrf(voltageCenter, 3, 0, lcdBuffer);
	printf(lcdBuffer);
	printf(" \n");
	dtostrf(voltageRight, 3, 0, lcdBuffer);
	printf(lcdBuffer);
	printf(" \n");
		dtostrf(sensorL, 1, 0, lcdBuffer);
		printf(lcdBuffer);
		dtostrf(sensorC, 1, 0, lcdBuffer);
		printf(lcdBuffer);
		dtostrf(sensorR, 1, 0, lcdBuffer);
		printf(lcdBuffer);
	printf(" \n");
ISR(TIMER0_COMPA_vect)
	//PORTD ^= (1<<PIND5);
ISR(TIMER0_COMPB_vect)
	//PORTD ^= (1<<PIND6);
	sei();
	// Initialize UART
	//uart_init();                         // Initialize UART
	//stdout = stdin = stderr = &uart_str; // Set File outputs to point to UART stream
	//printf("Hello! \n");
	// ADC Setup
	ADCSRA |= (1<<ADPS2) | (1<<ADPS1) | (1<<ADPS0); // Set ADC prescaler to 128
	ADCSRA |= (1<<ADEN); // Enable ADC circuit
	TCCR0A =  (1 << COM0A1) | (1<<COM0B1);// | (1 << WGM11);
	TCCR0B = (1 << WGM01)  |(1 << WGM00)|(1<<CS01);
	TCNT0 = 0;
	OCR0A = 254;
	OCR0B = 254;
	TIMSK0 |= (1<<OCIE0A);
	TIMSK0 |= (1<<OCIE0B);
	TIFR0 |= (1<<OCF0B) | (1<<OCF0A);
	initialize_all(); //initialize all
		readSensors();
		//printSensorValues();
		if (sensorL == 0 && sensorC == 1 && sensorR == 0)
			OCR0A = 254;
			OCR0B = 254;
		if (sensorL == 0 && sensorC == 0 && voltageRight >= 765)
			OCR0A = 254;
			OCR0B = 1;
		if (sensorL == 1 && sensorC == 0 && sensorR == 0)
			OCR0A = 1;
			OCR0B = 254;
		if (sensorL == 1 && sensorC == 1 && sensorR == 1)
			PORTB &= ~(1<<PINB5);
Ok. So I am trying to use Timer 0 to PWM my motors for a redbot but I can't get it to work. The data sheet says PD5 and PD6 are OCOB and OCOA respectively.
Got it!
#include <string.h>
#include "uart.h"
#include <asf.h>
#include <ctype.h>
#include <stdio.h>
#include <time.h>
#include <stdio.h>
#include <math.h>
// ADC variables
uint8_t data;
#define ON 1
#define OFF 0
void convertADC()
	// Convert A to D
void readSensors()
	ADMUX = 0b10000010;
	convertADC();
	voltageLeft = Ain;
	ADMUX = 0b10000011;
	convertADC();
	ADMUX = 0b10000110;
	convertADC();
	voltageRight = Ain;
	printf(lcdBuffer);
	printf(" \n");
	printf(lcdBuffer);
	printf(" \n");
	printf(lcdBuffer);
	printf(" \n");
		printf(lcdBuffer);
		printf(lcdBuffer);
		printf(lcdBuffer);
	printf(" \n");
	dtostrf(TCNT0, 3, 0, lcdBuffer);
	printf(lcdBuffer);
	printf(" \n");
	sei();
	// Initialize UART
	// ADC Setup
	PORTD |=(1<<DDD5) |(1<<DDD6);
	TCCR0A =  (1 << COM0A1) | (1<<COM0B1)|(1 << WGM00);
	TCCR0B = (1 << WGM01)  | (1<<CS01);
	TCNT0 = 0;
	OCR0A = 128;
	OCR0B = 128;
	//TIFR0 |= (1<<OCF0B) | (1<<OCF0A);
		readSensors();
		//_delay_ms(1000);
			OCR0A = 100;
			OCR0B = 100;
		if (sensorL == 0 && sensorC == 1 && sensorR == 1)
			OCR0A = 50;
			OCR0B = 100;
		if (sensorL == 0 && sensorC == 0 && sensorR == 1)
			OCR0A = 20;
			OCR0B = 100;
		if (sensorL == 1 && sensorC == 1 && sensorR == 0)
			OCR0A = 100;
			OCR0B = 50;
			OCR0A = 100;
			OCR0B = 1;
You can suit yourself on the below...
While I don't see where the AVR model is mentioned, I'm guessing some kind of Arduino given the 16MHz clock speed.  Those modern AVR models have a pin-toggle feature by writing to the PIN register, as opposed to the RMW that is in your ISRs.  Perhaps not a problem right now, but it >>will<< cause you head scratching if you start to do port D manipulation in the mainline.
But why do the ISR and toggle at all?  Put the output channels on the OC0x pins, and let the timer do the toggling.
