Failed to enter programming mode. Error 0x03
6 posts / 0 new
I am new to using atmel studio first time really, always used arduino's ide.
when i open the device programmer select tool as atmel ice, device as attiny20, interface TPI
it says "this interface has no settings" i think this is the problem in photos that i seen of it there is a sliding bar ISP speed or something
i can read the voltage its 5v but when i go to read device signature i get the error
Failed to enter programming mode. Error status received from tool: 0x03.
Unable to enter programming mode. Verify device selection, interface settings, target power, security bit, and connections to the target device
Atmel-ICE
Debug host        127.0.0.1
Debug port        51346
Serial number     J41800084580
Connection        com.atmel.avrdbg.connection.cmsis-dap
Features          1
Firmware Version  1.26
Hardware Version  0
yah im stupid i wired up the programing board ISP and not TPI but i got a blinking light with my code excited
 * GccApplication1.c
 * Created: 7/27/2017 9:39:32 PM
 * Author : jeff
#ifndef F_CPU
#define F_CPU 1000000UL
#endif
#include <util/delay.h>
    DDRA |= (1 << PA1);
	   while (1)
		PORTA ^= (1 << PA1);
		_delay_ms(500);
	return(0);
Congratulations!
And welcome to the forum.
thanks Jim!
If I am supposed to mark this as solved I don't know how. lol
Jeff
Every post above has [mark as solution] that you can use. I'd do that on #2 if I were you.
Moderator
I had this same error when trying to program my ATTiny10 that was controlling some Charlieplexed LEDs. I would get the error in Atmel Studio, every time I tried to read the chip ID.
The problem was that the Charlieplexed LEDs were pulling down the TPI pins
I solved this by removing the resistors to the Charlieplexed LEDs and it programmed the chip no problems. I then resoldered my resistors and the board worked fine after that.
.: Daniel :.
