PWM issue in TC6 in SAMDA1E
2 posts / 0 new
I have been trying to develop PWM in SAMDA1E on TC6 and on IO PA28. I'm able to see the timer part working(Could see the timer count change) but no Waveform output on the pin. Below is the code. I deeply appreciate any help.
void HAL_GPIO_Pin_PmuxEn(uint8_t port, uint8_t pin, uint8_t mux)
    PORT->Group[port].PINCFG[pin].reg |= PORT_PINCFG_PMUXEN;
    if ((pin & 0x01) == 0x01)
        PORT->Group[port].PMUX[pin>>1].bit.PMUXO = mux;
        PORT->Group[port].PMUX[pin>>1].bit.PMUXE = mux;
void Timer6_Init(void)
    HAL_GPIO_Pin_PmuxEn(GPIO_PORTA, PIN_PA28, TC_PMUX);        /* PORT - assign the pin to timer */
    PM->APBCMASK.reg |= PM_APBCMASK_TC6;
    GCLK->CLKCTRL.reg = (uint16_t)(GCLK_CLKCTRL_ID(TC6_GCLK_ID) |
                                GCLK_CLKCTRL_CLKEN |
                                GCLK_CLKCTRL_GEN(0U));
    /* Disable TC before configuring the timer */
    TC6->COUNT16.CTRLA.reg = (uint16_t)(TC_CTRLA_SWRST);
    /* Wait for sync */
    while ((TC6->COUNT16.STATUS.reg & TC_STATUS_SYNCBUSY) == TC_STATUS_SYNCBUSY) {};
    /* Setup CTRLA register
    - Mode     : 16_BIT
    - Wavegen  : Match PWM
    - Prescaler: DIV1
    - PreSync  : GCLK (Reload or reset the counter on next generic clock)
    TC6->COUNT16.CTRLA.reg |= (uint16_t)(TC_CTRLA_PRESCALER_DIV1 |
                              TC_CTRLA_MODE_COUNT16 |
                              TC_CTRLA_WAVEGEN_MPWM |
                              TC_CTRLA_PRESCSYNC_GCLK);
    TC6->COUNT16.CTRLBCLR.reg |= (uint16_t)TC_CTRLBCLR_DIR;
    /* Wait for sync */
    /* Setup CTRLBCLR register
    - Clear all commands
    TC6->COUNT16.CC[0].reg = 16000;
    TC6->COUNT16.CC[1].reg = 200;
    TC6->COUNT16.COUNT.reg = 0x0000;
    TC6->COUNT16.DBGCTRL.bit.DBGRUN = 0x1; /* Debug Control Enabled */
    /* Wait for sync */
    /* Enable the timer */
    TC6->COUNT16.CTRLA.reg |= (uint16_t)(TC_CTRLA_ENABLE);
    /* Wait for sync */
Jayanth
I found out the problem. Its the error in Datasheet. PA28 is not associated with the TC6.
Old Datasheet - http://www.atmel.com/images/Atmel-9349-SMART-ARM-based-MCUs-SAM-DA1_Datasheet.pdf and it has error in datasheet
New Datasheet corrected available at http://ww1.microchip.com/downloads/en/DeviceDoc/40001895A.pdf
Jayanth
