Begging for code....
8 posts / 0 new
HI,
I need a code to capture and compare pwm signals of 50 hz frequency. I'm using xmega a3bu xplained board and I'm new to this xmega family.
Could anyone please help me in finding out the solution.
Chethan kumar
Welcome to the Forum.
"Begging for code..." won't get you very far.
The way this Forum works is that you explain, very carefully, what you want to do, show what you have tried, explain who what you did failed to work, and then others will likely give you some guidance in the right direction.
If you are, instead, just asking for a completed, debugged, program then you can post your request in the "Marketplace" Sub-Forum, and hire an embedded designer.
Next, assuming you wish to work on this yourself:
How much experience do you have with microcontrollers?
What language are you using?
What have you tried so far?
"Compare" means measure the PWM signal and compare it to something else, what else? (another PWM signal, a threshold, etc.)
What is the output of the system?
What else does the micro have to do, (displays, user interface push buttons, etc.).
Lastly, the Xmegas have Timer/Counter hardware modules, and these can be useful for measuring pulse widths.
Start by reviewing that section of the Xmega manual.
Also, know that there are TWO manuals for each Xmega chip, one for the Xmega Family, and one for the specific chip.
You will need both in order to complete your project.
The original post was appended to another thread and was split, some moderator must have chosen the appropriate title......
Could someone explain (or just speculate about) why we've had an influx of "I need code for measuring frequency and/or duty cycle" lately. What are the applications? I'm guessing it's not school work because there has been so many now that a solution should be "on the market".
100 or more companies/individuals competing for the same project? Maybe they have quoted a rent-a-coder project?
still think it is school project.
and the questions are again showing that the students do not attend classes, or do not pay attention.
and inline with that are way to lazy to either read a datasheet, or so a simple search on the subject and find a solution that is getting close and then tweaking it a bit to make it work for them.
It is all in line with what I see at my work today, youngsters that are just plain lazy and do whatever they need to do to get on with the next thing as fast as possible.
Yeah - it's just the time of year that the projects are handed out
way to lazy to ... so a simple search on the subject
As illustrated here - in a recent similar thread: http://www.avrfreaks.net/comment...
Well, many employers just want the product marketed as fast as possible. So they end up with people being sloppy, hammering a few random libraries together until things seem to work.
