Can i even sense the pulse duration whit Input Cpature?
6 posts / 0 new
i maded program that senses the duration beetwen 2 rising or falling edges of a pulse on Atmega328. I also have an distance sensor that outputs distance in a form of a pusle length (147us = 1inch). But now i cant figure how to config ICP to capture first rising edge and then also the falling edge of the signal. Is the ICP even capable of doing this? Or should i simply read if input pin on MCu is high and count timer pulses until the pin goes low?
Search for Atmel App Note AVR135
first hit on the above search!
cool
Thanks all, the post about SFR04 solved it.
