Adding watches - AVR dragon and EVK1101
3 posts / 0 new
Hi all - I am using an AVR Dragon, Jtag programming and an EVK1101 board.
I am happily programming, but would like to use debugging and add watches to the watch window.
Is this possible with the (limited) debugging offered by the dragon?
In particular, when setting a breakpoint - I get :
the breakpoint will not currently be hit. unable to set requested breakpoint on target
 In particular, I am trying to get the value of F_CPU - not sure if my delay is delaying as  it should. (added the delay service from ASF)
earlier in the code I tried
volatile int freq;
and further down after main:
	freq = F_CPU;
to see if this would make it visible.
In the watch window I get: Unable to evaluate the expression
thanks
Russell
Sorted the F_CPU issue - but seriously how do I add breakpoints? Anyone??
Click on the side bar next to the line where you want the breakpoint or use the Menu from the Debug tab.
