help with some ASM
9 posts / 0 new
What I'm looking to accomplish here is a bit of a hack to the v-usb project. Normally the assembly will return on interrupt. I need to make it return regardless if the interrupt bit is not set. The test here is to see if the driver will return and send NAK instead of doing nothing when the interrupt is disabled.  Note: before disabling interrupts I run the busy command that will return NAK. So if this works, it should return from this code and then return NAK as it was told to.
normal code
sofError:
    POP_RETI                    ;macro call
    RETI
test code
sofError:
    brne EIMSK >> 2;if not set branch (int0 is pd2 on my chip)
    RETI;was set
    RET;was not
Will assembly do a bit wise calculation like that or do I need to use the OP commands and put it in a register.
A few things:
1) you haven't shown POP_RETI
2) As you have RETI then RET presumably you meant some kind of SKIP not BRANCH
3) If it is really meant to be BRNE then the operand should be a label not a bit number (or even shifted bit number)
4) Is EIMSK in the bottom 32 registers? If so then maybe "SBIC EIMSK, 2" ?
5) Other wise you likely need to IN (or even LDS) from the register and then SBRC
SBIC was the op code I was trying to recall, been far too long, I need more ASM excuses to code...
Ok, yes SBIC EIMSK, 1  would be in the correct place.
bit 7 6 5 4 3 2 1 0
EIMSK INT1 INT0
macro POP_RETI     ; 5 cycles
    pop     YL
    out     SREG, YL
    pop     YL
endm
so I'm looking more at
sofError:
    SBIC EIMSK, 1 ;if not set branch (int0 is pd2 on my chip)
    RETI;was set
    RET;was not
Which AVR? Is EIMSK in range for the SBIC opcode?
Sorry atmega328 in this case. I believe its a global interrupt bit mask.
"Are those shoes made of leather?"
"I believe they are brown."
328P data says EIMSK is 0x3D (IO 0x1D) so it should be in range of SBIC
YUp, I didn't not understand that question right.
Ok, ill give this code a try and see if this works. Thx.
In the past I have had this code at the end of a subroutine :
sei
ret
If you run both instructions it become a reti.
The instruction after sei will be executed so there won't be bigger stack use if there is a waiting ISR, the only problem could be under debug where you use that.
I have never disabled a ISR that way, but sometimes enabled it, (init ISR rutine by calling it).
