AS7 Dependencies - Can I add a 'Dependency?'
7 posts / 0 new
Hi, I installed AS7, and using my STK500, and writing code to blink an LED on the ATMEGA168.
I realized I don't have a delay routine and I'm not sure if I can added one (Dependency ?) that will contain a delay function that I can call in my code.
Attached is a screen capture of the Dependency .h files that are in my project.  I looked at all of them and noticed there's no delay routine.
Can I create a .h file with a delay routine and add it to my project?
Brian
Spin-loop delay routines are available using util/delay.h. See the avrlibc documentation for details.
EDIT: Correction of include directory.
Rather than attach a PDF, it would be better to simply embed the image - instructions here: http://www.avrfreaks.net/comment...
The "Dependencies" is something that AS works out for itself - not something that you manually create or adjust.
As Johan suggested, you simply
#include <avr/delay.h>
and AS will spot that as a Dependency
Because this is a standard part of the toolchain, that is all you have to do - the implementations of the library functions are included in the distribution.
When adding 3rd-party code, you will also have to add the implementations to your Project.
There was a similar question a little while back - but I can't seem to find it at the moment ...
EDIT
Johan has now corrected his post; it should actually be:
#include <util/delay.h>
see following posts...
You will have more success with:
Oh, darn.. That's what happens when posting from the PAD. I'll correct it.
