SAMD21 USB MSC Device + SD Card
3 posts / 0 new
I am trying to implement the USB MSC Device stack  + SD Card on a SAMD21J17A board so that when the board with the 2GB microSD is connected to a PC (Host) using a USB Cable, I can directly access the files on the SD card.
I started with the USB MSC Device example and made some clock and pin changes.
When I run the program, the USB attaches to the host and the device is also displayed in the Device Manager under Universal Serial Bus Controllers as a Mass Storage Device.
But it takes a very long time to show up in available drives and gives the error "Please insert disc" when opened.
Any help is appreciated. Thank you.
Duplicate: http://www.avrfreaks.net/comment...
Probably better asking in the Cortex-M forums ...
