bootloader for atmega1284p
6 posts / 0 new
I'm trying to write a bootloader for atmega1284p, for OTA (using wifi ESP8266) updates of the firmware.. I've done quite a few research and trying out but can't seem to get it to work properly. Appreciate any help here.
I've successfully done the firmware stuff and the wifi works..
Fuses:
Boot flash size=4096, boot address=$F000, enabled HighBootrst
0xFF, 0x98, 0xF7
Flash segment shows=".text=0xF100"
Linker shows
<-nostartfiles -Wl,-s -Wl,-static -Wl,-Map="$(OutputFileName).map" -Wl,--start-group -Wl,-lm  -Wl,--end-group -Wl,--gc-sections -mrelax -Wl,-section-start=.text=0x1e200  -mmcu=atmega1284p -B "C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.2.150\gcc\dev\atmega1284p" >
.hex file shows:
:020000021000EC
:10E2000011C0466C617368204352433D2000417049
:10E2100070204352433D20004156524150007265E8
:10E22000733D0000CF93DF93CDB7DEB763970FB692
I based my code around http://spaces.atmel.com/gf/proje... but instead of sd, it would be wifi.
Some questions.
I have the following code:
void UART_put(uint8_t c) {
    while (!(UCSR1A & (1 << UDRE1)));
    UDR1 = c;
void UART_putstr(uint8_t *pStr)
    while(*pStr)
    UART_put(*pStr++);
UART_put('A') works but the below doesn't
const uint8_t * words = "DE";
UART_putstr(words);
Is it because this is in the .text region instead of the .data region?
In my wifi.c below, i have the interrupt to receive the data from the wifi but this does not seem to work.
ISR(USART0_RX_vect)
	wrxString[wrxIndex++] = UDR0;
For my firmware application, should i build it with
-Wl,-section-start=.text=0x200? or something more than 0x000?
 Thanks in advance for any help
Nice to hear that you are doing this. I am also thinking to do so. but no idea about boot loader.
const uint8_t * words = "DE"; UART_putstr(words);
I think UART_PUTSTR doesnt implemented properly. I mean conversion of pointer to string and then string to char?
    UDR1 = c;
    while(*pStr)  //I think there is mistake
    UART_put(*pStr++);
use like:
   uint8_t i;
     while (i=*pStr++)
     UART_put(i);
No wonder when using -nostartfiles.
Remove that -nostartfiles and make sure your bootloader includes proper IVSEL handling.
  No!
Stefan Ernst
In my bootloader I was programming to try and get an entire FAT stack into 1K (sometimes 2K) so I had to use -nostartfiles so I wouldn't waste space with an interrupt vector table. But as Stefan says a consequence of it (and my "dummying" of do_copy_data() and do_clear_bss()) is that you cannot use .data or .bss variables. such as your "words" variable.
I *think* in the modern compiler you can probably continue to use -nostartfiles if required (but then you cannot use ISR()!!) but don't dummy the do_copy_data and/or do_clear_bss if you plan to use .data or .bss
  No!
Thanks! I removed that (-nostartfiles) and with IVSEL handling and it seems to work.
	MCUCR = (1<<IVCE);
	MCUCR = (1<<IVSEL);
	sei();
However, I had another thinking.. I may look to do an OTA (wifi) at the end of the actual application and save any new firmware into a flash... On load of bootloader, it will check the flash only and load the most recent one? Would this flow be better?
Should I load the firmware at 0x0000 and 0x8000?
  No!
Why no to this? i saw a few online that does this? Just wonder whats the best practise.
weeyoung wrote:
Why no to this?
Because the application can't use interrupts then. At least not without extra effort done by the bootloader.
Example?
I don't see why one would want to do that in the first place.
Stefan Ernst
