ATtiny417 / ATtiny814 / ATtiny816 / ATtiny817
338 posts / 0 new
Pages
There are several reasons why the mEDBG does not perform to the same level as the EDBG/Atmel-ICE.
I can't really list everything here, but the short answer is that the EDBG/Atmel-ICE are more polished products than the mEDBG.
It has nothing to do with deliberately keeping it slower for the sake of sales, but rather the time spent on the mEDBG implementation vs the EDBG/Atmel-ICE implementation.
Edit: Even though the firmware binary is 28657 bytes, keep in mind that there is also a 4k bootloader in there, which leaves about 15 bytes of flash :)
Ah-ha. That was my understanding. i.e. the 32u4 was full.
At some time in the past, I had an XMINI that or AS version that would not update the firmware.
I had to solder a 0.05" header and replace the firmware directly with an ATMEL-ICE. As far as I can remember the binary was almost the full 32kB.
Anyway the XMINI updated properly after this. In practice it is easier to develop with ATMEL-ICE and regular external AVR board.
For a trivial mod, the XMINI works well enough.
That's still 11 bytes more than the STK500 has free - put it to good use!
The STK500 has only got an 8kB AVR. To fit encrypted bootloader as well as the application firmware.
The real mystery is the Dragon. It seems to have "big enough" chips. But moderate performance.
This datasheet doesn't have the memory map diagram in section 6.2, while this one has a ridiculously small diagram. These are the new Microchip style datasheets, I suppose they decided they must be less than 500 pages at any cost. I'm all for more compact documents, but not sacrificing readability like this.
[never mind...]
"Read a lot.  Write a lot."
I guess they use the same cut and paste guy as Atmel :(
Fig 8-4 has addr of registers (that don't exist), so this is still cut and past  cut and paste ............
duzern wrote:
El Tangas wrote:
About the encryption, it seems only the "good stuff", like Atmel-ICE firmware, is encrypted.
Oh no, you figured out our big secret that the mEDBG is not encrypted :)
vidmo wrote:
Atmel gave us all answer:
Though, there is minor "thing" with EEPROM, which I'm gonna save for myself for now...
This may or may not be the EEPROM map for the mEDBG, the aboslute address for each field in the EEPROM is (512 * bank) + address.
The important one to get right for homebrews is FIRE register which tells Atmel Studio which firmware image to use when the tool is upgraded.
The serial number, kit name, manufacturer name and target name are ASCII '\0' terminated strings.
I made EEPROM files for UPDI, TPI, SWD and DW/ISP according to duzern's map. UPDI and ISP works, I didn't test rest. They are uploaded with FLASH files on my google drive: https://drive.google.com/open?id=0B3VyJZzWwjj5UU5xem1mUDRHaUU
I think that's not the right binary, it seems like a test file.
I edited link in previous post. You have to upload FLASH hex first, and than corresponding EEPROM binary dat file.
@edit I added elf files for simplicity. They contain both FLASH and EEPROM.
  • Precise ULP Timing P4 (ATtiny416)
The board itself with a coupon code that expires 30-Nov-2017 :
Microchip Technology Inc
Microchip
AVR P4 Field Engagement Board (FEB)
http://www.microchip.com/Developmenttools/ProductDetails.aspx?PartNO=ATAVRFEB-P4
So, anyone knows what are those? How many are they?
Sheet, page 19:
General Purpose I/O Registers
The ATtiny417/817 devices provide four General Purpose I/O Registers. These registers can be used for storing any information, and they are particularly useful for storing global variables and interrupt flags. General Purpose I/O Registers, which recide in the address range 0x1C - 0x1F, are directly bit-accessible using the SBI, CBI, SBIS, and SBIC instructions.
(The spelign eror is Microchip/Atmels, not mine.)
Man, how did I miss it?...
El Tangas wrote:
Then we could use avrdude to program these new chips.
AVR Downloader/UploaDEr - Patches: patch #9482, Add support for UPDI and AVR8X
http://savannah.nongnu.org/patch/?9482
by Jan Egil Ruud
09 Nov 2017
Add support for the UPDI interface. This programming and debugging interface is used in the AVR8X (2017->) series of devices and is supported in JTAGICE3, AtmelICE, EDBG, mEDBG, nEDBG and PowerDebugger.
Specification is located here: (will post a link when it finally goes public)
By adding support for UPDI it opens up for supporting the AVR8X range of devices; ATtiny212 - ATtiny416 - ATtiny817 - ATtiny1617 - ... (To be continued)
via http://lists.nongnu.org/archive/html/avrdude-dev/2017-11/msg00010.html
Let's see how it goes. I'm working on something like that too, but if the avrdude guys make it talk UPDI, so much the better.
New arrivals at Mouser :
https://www.mouser.com/new/microchip/microchip-avr-devel-boards/
ATAVRBLE-IoT Development Board (tiny1617)
ATAVRFEB-P4 Development Board (tiny416)
ATtiny416 Xplained Nano Evaluation Kit
https://www.mouser.com/new/microchip/microchip-attiny416-816-mcus/
http://www.avr-asm-tutorial.net/gavrasm/v37/ReadMe.Txt
Versions and Changes
October 2017: Version 3.7
- Added: Support for several newer AVR types
(tinyAVR 1-series, 2kB to 32kB inclusive)
Januar 2017: Version 3.6
- Added: Support for ATtiny80 und 840 (datasheet not yet available),
  ATtiny102, 104, 417, 814, 816 und 817, def.inc as of Studio version
  7.0-1188
via
Logo
Gerd's AVR Assembler
http://www.avr-asm-tutorial.net/gavrasm/index_en.html
Features
View the ReadMe.Txt for more informations on features. ...
YouTube
New AVR® ATtiny MCUs Increase System Throughput & Lower Power Consumption in Embedded Applications
Nov 22, 2017
https://www.youtube.com/watch?v=pG7eoXYyC94 (1m7s)
via https://plus.google.com/+MicrochipTech/posts/LmVrNEGxVz7
KitCarlson wrote:
CodeVisionAVR plans to support the new parts.
HP InfoTech
CodeVisionAVR V3 Revision History
http://hpinfotech.ro/cvavr_revision3.html
V3.32 Commercial Release
  • Compiler
    • Added compiler support for the ATtiny212/214/414/416/1614/1616/1617/3214/3216/3217 and ATA8510 chips
gchapman wrote:
And further down that release note...
  • Chip Programmer
    • Added support for the USBASP programmer
    • The chip programmer now supports AVRISP MkII, AVR Dragon, STK600, JTAGICE mKII, JTAGICE3 and AT ATMELICE without the need for Atmel Studio to be installed
(my bold)
Microchip New tinyAVR Microcontroller Series promo page http://www.microchip.com/promo/t...
"Make XMEGA Great Again!"  - Greg Muth
Well, that shows what THEY think is important.
I found a small error in the datasheet, in the UPDI chapter.
This is part of the procedure to program the User Row on a locked chip, via UPDI:
But in the relevant register, this bit is described as read only. This is an error; I've verified that this bit is indeed reset by writing a '1' to it, so it should be R/W in the datasheet, with the usual note that it is cleared by writing a '1', like several other AVR flags.
Reported (TPUBSTINY-441).
:: Morten
Nice.  Assuming that the procedure was written correctly to begin with, and that the error is indeed an error based on that assumption, then the same applies to the ATtiny1614/1616/1617 datasheet as well.
You found it, have you written up a support ticket yet?
EDIT: Morten please add the ATtiny1614/1616/1617 datasheet to the report.
Actually, I'm not exactly sure of the best way to report datasheet errors. I don't feel so comfortable sending this to some generic Microchip mail, will they read it?
I know some former Atmel people are active here, so I report them here, at least they are visible to everyone.
There is a specific "channel" for reporting errors in technical documentation. Go to microchip.com, then Contact Us (at bottom of page), then under Literature Requests there is a specific link for reporting document errors.
Ah, ok, i see it.
And if you do, include the tracking number I mentioned (just so that support can connect the dots).
:: Morten
It's ok, you already reported, so no need to duplicate. I'll remember the procedure for the next error I find.
If you look in the microchip AVR selector guide these xtinys EEPROMs are called HEF where all others are just EEPROMS.
I checked the data sheet but it don't have HEF in the text!
Does anyone know what it stands for?
HEF = High Endurance Flash
edit:http://www.microchip.com/design-...
David (aka frog_jr)
"HEF" just died, didn't he?  https://en.wikipedia.org/wiki/Hu...
I'm glad you got what you really needed from the frog, sparrow, as when I used Google for the "hef" I found all kinds of meanings...
HEF
From Wikipedia, the free encyclopedia
Hef or HEF may refer to:
No flash memory among the choices.  ;)
Pages
