How to set fuse with atprogram.exe
5 posts / 0 new
I know my question sounds stupid, but I have there a Problem to Setup the fuse in the rigth way without stop the Interface working.
I use the AVRISPmk2 and can read back the fuse with the command:
atprogram.exe -t avrispmk2 -i isp -d ATmega16 -cl 100000 read --fuses
The answer would be:
Firmware check OK
:02000000811F5E
:00000001FF
The FUSE should be set to 0x1F and 0x81 which I can see in the answer but with an Overhead which is not really descript in a docu.
My Problem is that I can write the fuse to the value 0x1F and 0x99 but then the ISP Interface is broken...
With this change I go from 1MHz RC inside to a ext. lower Crystal with 4MHz.
I have use the command:
atprogram.exe" -t avrispmk2 -i isp -d atmega16 -cl 100000 chiperase write -fs --verify --values 991F
The answer is:
Firmware check OK
Chiperase completed successfully
Verification of write OK
Write completed successfully.
But after this I'm unable to use the ISP Interface anymore. I have Switch to an Atmel ICE with JTAG and can read that the fuses are set in the rigth way, but the ISP don't work anymore. When I set back the fuse to internal RC the ISP Interface is working without a Problem.
I can't reach the device by ISP anymore and the atprogram tell me that there is a Problem.
Firmware check OK
[ERROR] Could not establish connection to device. Please check input parameters, hardware connections, security bit, target power, and clock values.
Failed to enter programming mode. ispEnterProgMode: Error status received: Got 0xc0, expected 0x00 (Command has failed to execute on the tool). (TCF Error code: 1)
Do you have there some idea's or a bugfix?
ISP requires cpu clock.
Is the 4MHz crystal oscillating normally?
Yes, the Crystal is working fine. I have checked it with the oszilloscope. It looks like that only the ISP Interface is disabled.
But the Fuse I can read with the JTAG told me, that the ISP should be enabled.
Now I have two AVR's with this Problem.
The AVR work's fine with the Atmel Studio and the ISP Interface, with the RC inside and the Crystal, but after I have set the Fuse once with the atprogram.exe
I have the Problem that the ISP work's only with the inside RC and not with the Crystal.
The Crystal is running on both AVR's ...
what happens if you set the fuses to 3F 99
Problem is solved now.
The STK500.exe use the "HighFuse" "LowFuse" combination.
The Atprogram.exe use the "LowFuse" "HighFuse" combination.
Thanks for your help
