I2C scanner for SAM E70
7 posts / 0 new
I am looking for a utility to scan all the addresses on the I2C bus on a SAM E70. I seem to find AVR code, but I am not  too familiar with porting and conversion.
Frank
I ended up just using an external hardware tool to do the I2C bus scanning.
You can do this by slightly modifying the TWI example code for SAME70.
Even though am no expert in atmel studio, but this is something that i have done.
You may tweak the code to ping in every address & see if you get an acknowledgement to any.
Silly beans are always silly
Else if you are looking to listen to IIC chatter thats happening in the bus, you better create a program with ext int & timer modules to decode everything thats happening in those lines.
Maybe using ASF3, I could check the  status return of  twihs_master_write() to all the values in packet.chip   and put a packet.buffer = 0.
Why not use:
 * \brief Test if a chip answers a given I2C address.
 * \param p_twihs Pointer to a TWIHS instance.
 * \param uc_slave_addr Address of the remote chip to search for.
 * \return TWIHS_SUCCESS if a chip was found, error code otherwise.
uint32_t twihs_probe(Twihs *p_twihs, uint8_t uc_slave_addr)
From twihs.c
Thanks for mentioning twihs_probe()
I scanned the whole range with:
void scan_all_device_ids(void){
    uint8_t i;
    puts("Scan all I2C addresses\r\n");
    for (i = 0; i < 128; i++){
        if( twihs_probe(BOARD_BASE_TWIHS_EEPROM, i) ==0){
            printf("Found at %#02x  (%#02x) \r\n", i, i*2);
    puts("scan done\r\n") ;
I include the capture for the 0xAC (not present) and  0xAE (present) for the ATSAME70-XPLD. i2c scan results
