STK500 Will not enter programming mode
61 posts / 0 new
Pages
Good Evening All,
I believe we have a eureka moment....The Tiny26 (that worked on the "new programmers" had a 10k pull down resistor on the reset line. The non working ATMEGA168V had a 4.7k pull down on it. Once I changed to a 10k pull down the new STK500 programmers worked! Now I need to convince others to change the pull down value on the offending ATMEGA168V targets.
-jw666
I hope you don't really have a PULL DOWN resistor on the reset line!!
Sorry! Pull up.
 Here's an idea:
Does your circuit board share MOSI, MISO, SCK or reset with other chips or circuits (or have pulldowns, caps, etc on the lines?)   It could be the working stk is just barely able to program it, but maybe the new stk's can't quite handle the extra loads.
I'm sure this qualifies for a free t-shirt or fountain pen cheeky
so does that mean that you never checked the chip using the sockets on the board?
ref to #23 ?
Methinks you have not read AVR040?
Sorry I didn't have the means to insert a 32TQFP​ in the socket.
-jw666
But from your answer one would say that it can't be a problem with reset!!!
Add:
And how long would it take to solder the needed pins on a chip? 5-10 min and that would have worked
Clawson,
Obviously, I have not. Thanks
-jw666
All,
Thank you all for your kind support.
-jw666
Pages
