silly interupt flag question
28 posts / 0 new
I'm doing a bunch of things with several IRQ's (turning them on/off, changing edge modes, etc)...but I've encountered some real craziness.
Part of what I am doing is, before setting irq parameters (such as timer overflow value), is to always write "1" to the irq flag bit, to 100% ensure that irq is not pending (ie: clear any pending of that irq), to ensure irq eventually fires as desired.
However, now with all the madness, I'm wondering when the flag IS zero, does writing a one actually SET the irq? The manual only states writing a one clears it (which is what I'm going by)...maybe I'm actually causing my irqs to fire, when I'm just trying to be safe.
For clarity, such as
ldi temp , (0<<INTF1)|(1<<INTF0) ;ensure any IRQ glitches cleared on IRQ0
out EIFR, temp
so before writing a one to clear a pending, does the bit need checked, or can it simply be written to one?  If this is not an issue, I will look at other (many) possibilities.
Normally I wouldn't do this clearing at all, but with so many things happening, thought it would be a benefit
Which AVR model are you talking about?
Writing to the flags won’t set them. Only the interrupt source can set the flag.
Your words match my original premise, so my setting of the bits is probably fine. I need to bark up another tree, but was somewhat hopeful I had found the issue!
mega328
What craziness?  Show the code which elicits this craziness.
"Read a lot.  Write a lot."
From my understanding writing a '1' to an interrupt flag clears the flag.  The other way an interrupt flag is cleared is by the hardware when it executes the ISR that corresponds to the flag.
From the Mega328 datasheet Timer0 section RED is how the flag is SET, YELLOW highlighter on how to clear the flag:
Hi JGM,
Yes no question about clearing the flag, it is very explicit.  What they fail to mention or clearly call out (and I started to dwell upon), was if the flag is NOT set in the first place, does writing a one SET it?  I don't see this circumstance mentioned anywhere. ...seems logical, that could be the case (therefore acting like a flip flop ..write 1 to set, write one to reset)....but apparently  ONLY the irq condition can set it (at least that is thee going theory).
I was thinking my constant "clearing" of the flag (whether already set or not), might have actually been causing lots of false irq's to occur.
It certainly does explicitly say what sets it AND what clears the flag.  The yellow highlight in my post tells how it's cleared, and the red outline says how it is set.
Now, what you could do is write a simple program for say the timer, and run it in the simulator and see what happens.
JIm
I generally agree, though they should specifically cover the mentioned condition
They specifically say: Alternatively the flag is CLEARED by writing a one to the bit ....(I take verb cleared as meaning it went from 1 to 0)
....This would certainly make a lot of sense perhaps:
An irq condition occurring sets the corresponding flag bit
Alternatively if the flag bit is zero & you write a one, it becomes one   ...they fail to mention what happens in this condition.
Alternatively if the flag bit is one  & you write a one, it becomes zero
What they should say is: Regardless of its state, the flag bit becomes zero when a one is written to it.
Exactly.
They have TOLD you....the flag is cleared when you write a one to it.  Incidentally I wrote that program I suggested and ran it in the Simulator.  If the Flag is a zero, and you write a one to it NOTHING happens.
OK, OK, OK...I'll mention it at the Moderators Convention in the spring.  Happy now?
If I write a "1" to this thread will it be cleared? winkcheeky
Is it in the usual place in Hawaii this year? I havnen't got my ticket yet.
I thought you were headed to Bali this year!?
David (aka frog_jr)
I think you are stretching things.  Surely, if assigning one to the unset bit then set the bit, there w0ould be a note about that somewhere.
I think it is logical that if you try the assignment of a 1 to an unset interrupt flag bit that the effect will be a hard between Vcc and Gnd, with attendant overheating and possible fire.
Just so long as it's not the same place it was last year....  My ticket has not arrived yet either, and I also hope it's not for the same airline either.
JIm
No thanks, too many crazy people there. Anyway I have the Hawaiian shirt ironed now.
Exactly.
Think this through...
Well, if the verb clearing a bit means going from one to zero, then saying writing a one clears the flag , means when a one is written when the flag is one, it will become zero
However, that does NOT necessarily preclude the case of when a one is written when the flag is zero, it will become one. So it is NOT being TOLD or addressed.
A completely independent statement is made about some event setting the flag to one, but it is not stated therein that this is the only way it is can be Set to one.  So their description seems to have a hole .  However, I concur with our normal interpretation & try not to think about this situation.
maybe or maybe not...I would think in the realm of logic that writing a one to something would (surely) & very commonly produce a one/set condition, unless told otherwise.  And there is nothing directly in the datasheet to refute it.
Playing devils advocate, why would I expect to need a note saying that setting a one results in a one?  I'd certainly like a note when it does not do that.
I'm informing Atmel that I found a hole in their description & won't tell them what it is unless I get a complete set of their latest databooks. smiley
Clearing a bit means >>making<< it zero, not necessarily >>changing<< it to zero.
Seems you're jigging madly on the head of a pin.  The problem is surely in your code, not in a semantic re-interpretation of the datasheet.
avrcandies wrote:
Think this through... Well, if the verb clearing a bit means going from one to zero, then saying writing a one clears the flag , means when a one is written when the flag is one, it will become zero. However, that does NOT necessarily preclude the case of when a one is written when the flag is zero, it will become one. So it is NOT being TOLD or addressed.
I have a better idea.....STOP thinking about it.  I even tried a small program that writes a one to the flag when it's a zero, and it stayed zero.
Good Grief.....
You will be waiting a VERY long time as Databooks went bye bye a long time ago.
Jim.
Thanks Jim, that's what I always assumed to be true, (until I started playing the what-if I've been wrong all these years game).
Does this mean this thread has a solution to your question, the post with the solution can be tagged as such, and we can move on to other more pressing items?  Like Johns Shirt....cheeky
JIm
Yes please mark it, as from here on out, I can't let my progress be interrupted angel
YOu have to mark the post with the solution  None of us can.
I'm pretty sure that in the hardware world, you get to say you've cleared a bit, whether or not it was set to start with.
Consider your various flipflops and latches with "clear" input...
FlipFlop with clear and preset
Horse dead. Cease beating. ;-)
I generally agree with the hardware analogy.  Atmel's description left a smidge of ambiguity (If you have a register bit that can be set to one when desired (or automatically by an event), but cleared by writing another one, it would still fit their description.)
When you are grasping at possible straws, you go hmmm, is that the cause?   I finally found what the real issue was (related to the timer mode).
Time to close this one down!
Which someone here might have been able to help with if you had responded at the time to:
or the later:
joeymorin wrote:
Lots of threads here are about people "grasping at straws" - the classic being the inability to read UDR or UCSRC when a UART is not working. Because they can't see the 8N1 value in UCSRC they think that MUST BE why their UART connection is not working and then long threads focus on that particular red herring while the actual problem (as we all know: "it's the wrong clock") could have been solved if they had an open mind about what might be wrong (probably attempting 9600 on 1MHz!).
So, no, when something doesn't work and you come up with your first theory as to why it is then don't waste a lot of time trying to prove that it MUST be the reason, keep an open mind and consider other possibilities.
(and when someone asks to see the code or for an explanation of the problem it might be an idea to share those so others can take a look at EVERYTHING involved).
